Thread Tools
Old 12th April 2008, 22:01   #1 (permalink)
sreenivass's Avatar
On my 3 yr old Petra I have started hearing slight humm and a little metal grinding sound from engine when I release the gas pedal. Seems relatively prominent in 1st and 2nd gear. I am planning to go to Malik motors. Apprehensive about opening the engine, this is what the service adviser told me.
My present service engineer (a generalist, Maruti/ Tata authorized guy) told me it may have to do with bearings for tensioners in the engine. Malik service adviser told me the same thing. The generalist could not work on this because the Fiat engine apparently needs automation equipment for this kind of issues.
Can Gurus throw some light on why this could be happening? I am not sure about competence of Malik Motors in even regular services for Fiat models, leave aside opening the engine.
Any experiences and technicalities will help. I have an appointment with these guys on 14th morning, advices before that are greatly appreciated.
Any help would be appreciated folks
__________________
I have one dream, Fiat with great A.S.S.
Last edited by Rehaan : 13th April 2008 at 00:37. Reason: merged. No need to follow up a topic within 1 hour of posting. Please wait for a while.
sreenivass is online now   Reply With Quote
Old 13th April 2008, 08:23   #2 (permalink)
harry2223's Avatar
if am not wrong generally grinding noise are made by worn bearings .
__________________
harry
harry2223 is offline   Reply With Quote
Old 13th April 2008, 12:33   #3 (permalink)
sreenivass's Avatar
I will be surprised if this has happened in just under 25K KMs run.
__________________
Old 13th April 2008, 22:30   #4 (permalink)
sreenivass's Avatar
Another input. This humm/ slight metal sound seems to be coming only when gears are engaged, if gas pedal is pressed without gears engaged I do not hear any thing.
__________________
Old 14th April 2008, 06:22   #5 (permalink)
ananthkamath's Avatar
If you hear it only on deceleration it might be your CV joints. I dont know about the Palio, but in some cars this can also be caused by a broken rear engine mount (if its occurring when you repeatedly go on/off the gas).
__________________
AK: BOOST is the secret of my energy.....
(Turbo Miata interrupts): OUR energy.....
ananthkamath is offline   Reply With Quote
Old 17th April 2008, 22:29   #6 (permalink)
sreenivass's Avatar
Went to Malik Motors today at 9 A.M. I was asked to be there by 9:30 A.M. The workshop looked clean and neat, the service folks looked more professional. In to details of service requests:
problems:
1. Seat belt anchor not returning properly many times: no parts, need to replace seat belts package completely.
2. Noise probably from rear seat upon going over curves: Thinks its the seat not unfolded correctly, the problem resurfaces while returning from there.
3. Metallic sound and a little hum upon engine braking: Waited for team lead, TL does not show up until 10 A.M. I asked if the guy himself can check it out, gives some vague explanation. So the guy gets a manager. We go on a trial, I am surprised if the guy heard the same noise I heard. Had to point him many times and request him to focus. Finally says its return bearing in clutch, not a problem. I am still not sure if he heard the noise I heard and understood the problem at all, not confidence inspiring. Wants me to replace the whole clutch assembly, praises Petra 1.6 engine.
After returning to workshop these guys want to do general service (or 25K service), mention the same thing quite a few times. I tell them I will come back after a pending long trip, may be after 15 days or so. These guys wanted to know if the car needs oil change, told them not required now.
Overall experience:
Workshop looked well equipped and neat.
Clean and neat toilets and customer lounge.
Service and knowledge of folks: not confidence inspiring yet.
__________________
Old 7th May 2008, 19:31   #7 (permalink)
sreenivass's Avatar
A little vibration and shudder felt at times, one of the workshop guys tells me to get engine mounts checked. Can any one let me know if this is a high skill job or a slam dunk one.
__________________
Old 7th May 2008, 19:41   #8 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Engine mount change takes around 5 minutes and is an easy job, atleast in the indica(go) family
__________________
My DCMAG Portfolio!
tsk1979 is online now   Reply With Quote
Old 7th May 2008, 19:58   #9 (permalink)
maestro's Avatar
Do you have any issues with changing gears - grating sound etc? From symptoms described, first suspicion would be the synchromesh cones in the gearbox, usually it is the 1st and 2nd gear cones which goes first, and if loose, could cause some noise, along with a difficult gearchange.
maestro is offline   Reply With Quote
Old 9th May 2008, 23:25   #10 (permalink)
sreenivass's Avatar
There is no difficulty in changing gears, nor there is a grating sound. The sound is a very low pitched metallic one while releasing gas pedal, the guy suspected it is return bearing in clutch. I seem to be sold off on engine mounting becoming weak because I feel there is a little shudder from stop to move, after changing gears and probable movement/ shift of weight in the nose (of course the car's). Not sure if it is psychological.
__________________
Old 12th May 2008, 17:28   #11 (permalink)
vipul_singh's Avatar
I had the exact same 'soft' grinding sound problem in my GTX at 25,000 KM. The clutch release bearing was changed and the problem was sorted. The total cost was about Rs. 800 or so. So I am not sure why the A.S.S. people are telling you that the whole clutch assy has to be changed, as it sounds like a lot of money.
Another check you can do to figure out it the 'faulty release bearing' theory is true: try taking the clutch through its travel range when the sound is coming. If the sound changes in pitch and intensity as you do so, it is another indicator that the release bearing is the culprit.
vipul_singh is offline   Reply With Quote
Old 17th May 2008, 20:05   #12 (permalink)
sreenivass's Avatar
Vipul I will try what you said. At present it seems this could have been due to low grade oil 10W40 used instead of recommended 15W40 and brand. Malik guys did full oil changes and checked the ECU, etc.. every thing seems fine per them. There are signs of the same noise going down. I tend to believe with this theory because the engine oil was almost turning black when I checked it on the dip stick. Infact the other workshop folks filled 1 litre more of engine oil some time ago. I will be trying the route you took if the noise does not go away.
__________________
Thread Tools
Slight Hissing sound from ICE meconi Ask the Gurus 9 29th January 2008 09:18
Swift : Making metal rubbing sound : Help manjubp Technical Stuff 8 14th July 2007 13:02
slight rattle in the driver side corner of Petra sreenivass Technical Stuff 16 2nd May 2007 09:15
how to get the hum sound? hellspawn Modifications & Accessories 20 4th August 2006 04:31
One of its kind snoopy41 Shifting gears 5 16th November 2004 15:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
