Old 28th July 2012, 18:39   #31
swarnava.m's Avatar
Thanked: 268 Times
Default Re: Severe Gear problem in i10
Originally Posted by wartikars View Post
Sorry for not giving complete information. The car was bought in 2008 and has travelled arroung 25K Kms. And want to ask you something ... What is an ECU?
Engine Control Unit - Wikipedia Link
It is a computer chip present in the car that control many parameters of the car's operations, especially those of the engine. These include air-fuel ratio, idle speed, valve timing in case of VVT cars, ignition timing, etc. It has replaced the use of carburetor, which was used to handle these things in older cars. However, carburetor is still very commonly used in most bikes (at least those sold in India), and recently some ECU controlled bikes are appearing in the market.
swarnava.m is offline   (1) Thanks Reply With Quote
Old 29th July 2012, 01:48   #32
TaurusAl's Avatar
Thanked: 329 Times
What is an ECU?
You can always google it. An engine control unit (ECU), is a type of electronic control unit that controls a series of actuators on an internal combustion engine to ensure the optimum running. It does this by reading values from a multitude of sensors within the engine bay, interpreting the data using multidimensional performance maps (called Look-up tables), and adjusting the engine actuators accordingly.
Before ECUs, air/fuel mixture, ignition timing, and idle speed were mechanically set and dynamically controlled by mechanical and pneumatic means. One of the earliest attempts to use such a unitized and automated device to manage multiple engine control functions simultaneously was the "Kommandogerät" created by BMW in 1939, for their 801 14-cylinder aviation radial engine.
Source - Wikipedia
EDIT - Oops Mods, im sorry!! I jus replied to my quote, I did not see the above reply, please delete my post. Thanks
TaurusAl is offline   (1) Thanks Reply With Quote
Old 3rd August 2012, 10:40   #33
wartikars's Avatar
Thanked: 12 Times
Originally Posted by TaurusAl View Post
One of the possibility is maybe the ECU needs re-mapping. You haven't mentioned how much the car has been driven and what year it is manufactured. If it is a brand new car, 90% chances that the ECU is the culprit and will need adjustments. If it is well-driven (past 40k - 50k Kms), then there may be many factors to consider for poor performance.
Thanks for the valuable input. My friend was telling me that if he changes from 2nd gear to the 3rd gear when the speed is 50 kmph or more the problem does not occur. I guess we are on target.
wartikars is offline   Reply With Quote
Old 3rd August 2012, 11:14   #34
TaurusAl's Avatar
Thanked: 329 Times
My Pleasure. More than me you should thank our lovely forum who has brought us all together to share our knowledge.
Cheers!!!
TaurusAl is offline   Reply With Quote
Old 9th August 2012, 01:00   #35
wartikars's Avatar
Thanked: 12 Times
Cheers!!!
Yes you are absolutely right! The whole Team BHP family rocks!
We had taken to the car to the Hyundai Service Centre and the guy refused to accept that its not a clutch problem. We almost ended up in an arguement.
Severe back pain and driving! shivmarwaha Technical Stuff 281 11th March 2018 09:21
i10 gear stuck in reverse gear drkunaldas Technical Stuff 33 23rd November 2009 02:21
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Severe fogging of the windscreen kirans Test-Drives & Initial Ownership Reports 4 8th August 2009 16:52
Severe Judder in traffic crawl conditions tsk1979 Technical Stuff 45 29th June 2008 13:21
