Thread Tools
Old 16th April 2008, 15:38   #1 (permalink)
Default Premier Padmini S1 : Valves leaking. Suggestions needed urgently !!
Dear Team-bhp members,
Ive got a 1995 premier padmini S1, clocked 59K, had a bad oil consumption habit (1ltr/1K), My mechanic has opened the head & found that the valves are leaking. This means a head job, which means a once in a lifetime (i hope so) effort.
Would want suggestions/advice-
1) On polishing of valves.
2) Any methods to improve efficiency & power
3) Anything else that can be done.
All suggestions are welcome.
My considerations are good fuel efficiency & decent power,would be using it for A/c application too.
p.s.- Recommend some reasonable & good turners in south mumbai.
kavesh55 is offline   Reply With Quote
Old 16th April 2008, 21:43   #2 (permalink)
ananthkamath's Avatar
The S1 head is much improved and already at its limit of efficiency over the standard issue head. I doubt much can be gained without sacrificing street driveability. If you have access to high-octane fuel, you might consider shaving the head about 1 mm. Again, everything else has to be setup correctly for this to work.
__________________
Miata Turbo Is GO!!
ananthkamath is offline   Reply With Quote
Old 17th April 2008, 09:30   #3 (permalink)
You can look at products from Xado. They have treatment for various problems, but I dont remember if they have anything for the valves specifically.
Check out this thread (OHC trouble after engine flush. EDIT : Now Solved!)for details.
__________________
Remember, its a machine
Thread Tools
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
Ambassador, Premier Padmini Specs ?? Technocrat The Indian Car Scene!! 25 14th March 2008 09:29
Modifying a Premier Padmini NOS Power Modifications & Accessories 8 13th January 2008 16:55
Need a Premier Padmini S1 kavesh55 Shifting gears 0 27th December 2007 13:48
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
