| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Hi, As you all know i have swift Vxi from jan2007, till date odo shows 16500km's, at the 13,5oo km's above said problem started, i am the slow driver, i start move at 1st gear upto 10-15 km/h then to 2nd, between 20-25 i will move to 3rd, after 45 i will change to 4th, after 55 only i will push to 5th, Engine jerk[as per Mr. Lokesh, suraksha] start's at 3rd/4th gear, it's like cutting/stoppage of electrical supply to the spark plug for less than a second, it will continue for few jerk's & will be normal at high speed. On 8th of Mar.[at 15144km's on odo meter] at suraksha, they changed the all Spark plugs, & 2 no's of DDIL COIL POLE Joint with spring[pole with plug connector] in the test drive itself i found that the problem disappeared & become normal condition. Last saturday i went to Horanadu-shringeri long trip covering arond 750 km's, for 2 day's, while coming back in the slow traffic,[after dasarahalli] i started feeling above said problem again and got few jerk's in last 2day's in city traffic, Is thier any other TBHpian who own's swift & got like this problem?? or any suggestion please......... Last edited by subbarao : 17th April 2008 at 19:46. |
| | #4 (permalink) |
| BHPian Join Date: Mar 2007 Location: Bangalore
| not so clean fuel injectors can be one of the reason. use System G
__________________ If you have not failed you have not tried enough. Swift Diesel VDI - Feb '07 onwards Santro LS- Mar '01-Feb '07(59000 KM) Sold. |
| | #5 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| Have your ruled out clutch setting and idle rpm setting. Had same issue with the Petrol swift i use, some clutch play adjusting and things were fine. Otherwise, air filter, fuel filter and plugs should be checked first. Then move to throttle body and injector cleaning and finally to coils.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #6 (permalink) | |
| BHPian | Quote:
I would also like to narrate a similar thing happened to me on my M 800 a decade ago, but it was a non-MPFI car, so I am not sure if it is pertinent here. I got the same jerks in the same gears at speeds below 40 to 50, and was forced to drive at high speeds. On diagnosis, it was a faulty condenser, that cost only Rs 70. The problem disappeared on replacement.
__________________ ------------------------------------- Ford Fiesta 1.6 sxi 2007 WagonR LXi 2001 | |
| | #9 (permalink) |
| BHPian | It is a fuel additive available in Ford workshops. It costs Rs 250 for a bottle of 250 ml. You need to add 1 ml for each liter of petrol.I generally add 25 ml whenever I top up with 25 litres of petrol.
| | #10 (permalink) |
| System G and D are also available in most BPCL/IBP Petrol pumps. for more details and FAQ on System G or System D please refer to - IFTEX- fuel additives
__________________ If you have not failed you have not tried enough. Swift Diesel VDI - Feb '07 onwards Santro LS- Mar '01-Feb '07(59000 KM) Sold. Last edited by DieselFan : 18th April 2008 at 13:02. |
| | #11 (permalink) |
| BHPian Join Date: Feb 2008 Location: Coimbatore
| I had faced the same problem when i test Drove a Swift VXI. I got my Swift P 10 days back and i have faced the problem only once after running it for 400 kms !
__________________ Remember that nobody will ever get ahead of you as long as he is kicking you in the seat of the pants. |
| | #12 (permalink) |
| BHPian | Hi, After 4 months i opening this thread again to inform you that, the jerking problem has been solved allmost 99% in suraksha, from last 20 day's i have not experienced the jerk's, Total 7 visit's to surakshaa for the same problem. At first step they have changed the spark plug's, spark plug ignitors also replaced with new one, but jerking not stopped. All electrical connection's checked, & Tech 2 analyser has been connected to ECU, but No error found. Fuel Injector's cleaned.......... Throttle body cleaned at 6th visit..... after this no jerking found/experienced. Mean while i filled the fuel[only 5 ltr's at different bunk not regular bunk] & driven about 2km's from bunk, again 3-4 jerk's........ Next day i went to service station, they decided to check the fuel tank for any dust accumulation....below are the photo's which explains the same.... Last edited by subbarao : 18th July 2008 at 23:47. |
| | #14 (permalink) |
| Team-BHP Moderator ![]() | Fill in company owned/government operated bunks only, now that Shell normal is no more. It wont give you 100% protection against bad fuel but offers significantly higher chances of clean fuel over private bunks.
__________________ If you lose your temper, you’ve lost the argument |
| | #15 (permalink) |
| BHPian Join Date: Jan 2008 Location: Faridabad
| I saw this thread only now and fully agree with as similar happened with me on my GV. This was after I topped up a tank at a bunk near Bikaner and before I reached Nagaur (150km) the situation had become so bad that I was barely able to get it moving. Ultimately at Maruti *** in Nagaur I got the tank opened up and was greeted with similar scene of chicked up filter. Once it was cleaned no problems. Again about three months later I got fuel from another bunk near Bikaner and it was sense of deja-vu. This time I kept a sample of petriol and was suprised to see that after some time there was a layer at bottom. The query with Indian Oil (both times it was Indian Oil bunks) rvealed that they had started doing some additive mix recently and this was the likely result of that. BUT both times instead of normal fuel I had topped up with Premium as they did not have normal. Been to Biakener a few more times but no problem, only I have started using BP wherever possible and stick to normal, |
| Thread Tools | |
Similar Threads | ||||
| Aveo 1.4 Petrol Base Variant or Swift ZX Petrol | amitsethi100 | Hatchbacks | 23 | 27th October 2007 20:04 |
| Why does my bike jerk when throttling... | ramki067 | Motorbikes | 3 | 31st May 2007 14:00 |
| Maruti Esteem petrol engine to Diesel Engine | mituadas | Modifications & Accessories | 24 | 23rd May 2007 12:42 |
| Engine jerk/glitch | Abhay | Technical Stuff | 17 | 8th July 2006 22:34 |
| Which Petrol Engine For Safari ?? | shahmotors | Modifications & Accessories | 15 | 13th December 2005 22:21 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
