Old 18th April 2008, 08:15   #1
clevermax's Avatar
Thanked: 445 Times
Question What's that sound from my front suspension?
Hi Bhpians,
I searched the forum, but could not find this discussed anywhere.
Car: Fiat Palio 1.2 ELX
2 Years, 24000 Kms
Problem:
When I negotiate a hump (those annoying metallic ones attached to the
tarmac) at slow speeds, There's a 'tak' sound coming from the car's front RH suspension. (This seems to happen when the tyre rolls down from the peak of the hump, but before it hits the road again.)
This is not happening while driving normally through a rough road
or when going over small potholes. Even while going over the hump dead slow, there's no sound. But, the faster I run over the hump, the louder this sound gets. (This could suggest that it depends on how far the coil spring gets compressed?)
Experts, please comment on what could be the problem. Caliper pins? Lower ball joint? Or something else?
Thanks In Advance.
clevermax is offline   Reply With Quote
Old 18th April 2008, 08:29   #2
It might be the steering rack dude..get it checked by your mechanic
Even i faced the same problem in my zen wheni got it checked it was the steering rack which got play in it and got it changed ,for me it costed 2k
zenopio is offline   Reply With Quote
Old 18th April 2008, 09:22   #3
airfoil's Avatar
Thanked: 67 Times
Could be your caliper pins. To check, kick your car's right tyre and listen for sounds of a rattle.
airfoil is offline   Reply With Quote
Front wheel .steering column ticking sound.. Need urgent help!! DRC Technical Stuff 34 27th April 2015 11:31
Ritz - Sound from front suspension funda2max Technical Stuff 6 15th October 2013 21:27
Jarring noise front brand new left front speaker skrules In-Car Entertainment 13 26th December 2011 10:53
Baleno Front suspension sound Revvhead Technical Stuff 28 22nd November 2011 15:00
Yamaha Gladiator - sound from front suspension Hashim Motorbikes 8 20th June 2011 19:03
