Old 19th June 2005, 11:48   #46
speedsatya's Avatar
Thanked: 712 Times
Originally Posted by protege
Hey Revtech,
I got the pricol recommendation from Satya only.. the zen guru. According to him, it's really easy to fit. need to bore two holes for mounting.. and costs about Rs 800.. from his pm it seemed it's easily available everyhere.. and it doesn't have many electronics so can be callibrated easily by mechanic.. me thinks.
hahahha zen guru.
i am no guru dude,its just that i have faced similar problems ,so i can answer some more of them.hehehhe.
i have been using a Pricol tacho since day 1 in my mpfi zen.and even after 4 years its doing very well.
the fitting takes about 30 minutes and all it requires is connecting 4 wires black-ground,red -battery +,yellow -park lite so that the lite inside the tacho will glow,green coil - -ve of coil
about changing gears,the zen can do 40kph easily in 5th gear once you have the momentum.but if u floor the accelerator at 40kph in 5th gear ,the engine will knock.
speedsatya is offline   Reply With Quote
Old 19th June 2005, 14:03   #47
revtech's Avatar
Thanked: 35 Times
thanx satya and one more thing will there be any cutting of the dash or something required ?? and this will work on a carb zen too right ??
Rev
revtech is offline   Reply With Quote
Old 19th June 2005, 19:13   #48
speedsatya's Avatar
Thanked: 712 Times
yeah u have to drill a small hole on your dashboard for the wires to pass into the engine compartment.
for the wires to go into the engine bay,there is a small hole through which all the wires come into the passenger cell.and to prevent hot engine air from entering into it,there is black rubber seal.so make sure that the wires pass through them,otherwise for convenience sake,the garage guys pass the wires just by removing this seal adn anot through it.
if this is done,then your AC cooling will be affected by the hot engine air.
so remember to pass the wires through this seal.
Old 19th June 2005, 23:26   #49
Default Gear shift RPM for Getz GLS
Can someone tell me the ideal RPM for Getz to get optimal mileage. I have the Tachometer, but the manual is not clear about when to change the gears. I try and keep it below 2000 rpm most of the time. With the rising fuel prices it is important to keep the consumption to the optimum level.
Subodh
subodhchand is offline   Reply With Quote
Old 20th June 2005, 12:43   #50
Rice_tuner's Avatar
Thanked: 13 Times
i'm with satya on this one...get the basic pricol one for 800 bucks....works well...have had one for 2 yrs on my zen... (after the "expensive" tach with the OVERRATED "SHIFT LIGHT" CONKED OFF in 6 months)
no alterations on the dash needed...
cheers
Rice_tuner is offline   Reply With Quote
Old 20th June 2005, 12:46   #51
Rice_tuner's Avatar
Thanked: 13 Times
subodh... gettin a decent fuel economy depends more on how light/heavy ur foot is while driving...
if ur in 5th gear at 45Km/h and at bout 1200 revs...n u floor the pedal to get to 60, it'll consume more fuel than being at 2200 revs in 3rd gear n gettin to 60 with a slight depression of the throtle
cheers..
Old 22nd June 2005, 00:01   #52
Thanked: 103,629 Times
@ Steeroid
An example of mechanical over-revving would be me redlining the Vtec in 3 gear, and then having a mis-shift into 2nd instead of 4th (should go well over 10,000 rpm).
Here the revv limiter wont help since the over-revv will be supported by the drivetrain. Most probably, the result would be a blown engine.
Old 22nd June 2005, 12:36   #53
Thanked: 64 Times
I remember reading in one of the posts long back (around Dec. 04), that during an accident, cousin of our T-BHPian blew up engine of Opel Astra, as he tried desperately tried "engine braking" in order to stop the car.
RX135 is offline   Reply With Quote
Old 23rd June 2005, 11:55   #54
kooldude's Avatar
GTO[/quote]
hey gto is this the same in the case of carb esteems i know there is no rev limiter carb esteem but i used to take my car uptil 70 in the first gear and the car would make insane noise i dont know what rpm it is running since the rpm meter is not working so i was curious if it would have a blown engine
kooldude is offline   Reply With Quote
Old 25th June 2005, 12:29   #55
Shan2nu's Avatar
Thanked: 89 Times
those maruti guys tell me to put 3rd at 20kmph and 4th at 40 kmph and fifth at 45 kmph...
do you think its possible with those long gear ratios, unless i want some bullock cart to overtake me..
Our Wagon R is pretty comfortable at those speeds, in those gears. 45kmph in 5th is around 1500 rpm (which is fine).
Shan2nu
Old 25th June 2005, 12:34   #56
Shan2nu's Avatar
Thanked: 89 Times
More like 10,890 rpm.
Shan2nu
Old 25th June 2005, 12:44   #57
v1p3r's Avatar
Thanked: 27 Times
I don't understand why the limiter won't kick in on a mechanical over-rev. Can someone please explain how it gets bypassed?
Old 25th June 2005, 13:07   #58
Shan2nu's Avatar
Thanked: 89 Times
Didn't get that. On the Vtec, the limiter kicks in everytime the revvs cross 7100 rpm.
Shan2nu
Old 25th June 2005, 14:49   #59
Thanked: 1,642 Times
Shan2nu
So how is it possible to hit 10,000 rpm and blow an engine? I get cut off at 7K.
Steeroid is offline   Reply With Quote
Old 25th June 2005, 17:49   #60
Shan2nu's Avatar
Thanked: 89 Times
Well, firstly we haven't tried downshifting a Vtec into 2nd at 150-155kmph (redline in 3rd). It was just a therotical explaination.
The limiter has to kick in at 7100 rpm (no matter what). What really kills the engine is the revvs it gains when you down shift to 2nd at 150kmph.
The limiter only stops fuel supply to the engine after 7100 rpm. When you red line while accelerating, there isn't much decelerating load on the engine, since your speed is still within the max speed allowed in that gear.
But down shifting to 2nd at 150kmph puts tremendous load on the engine which is forced to keep revving even though the fuel supply is cut off. The limiter only works when engine revvs are supported by fuel supply, in this case it's the velocity of the vehicle that's causing the overrevv and that can/will damage the engine.
Shan2nu
tachometer ... problems cooldude585 Modifications & Accessories 9 9th January 2009 15:23
tachometer-help!! hot_rod Modifications & Accessories 42 23rd September 2008 10:09
purpose of tachometer jagjeet Technical Stuff 3 27th June 2008 16:12
tachometer for my zen hellspawn Modifications & Accessories 20 12th June 2006 17:21
Tachometer Pricing dragger Modifications & Accessories 10 11th February 2005 17:47
