Old 19th April 2008, 17:23   #1
Unhappy Clutch replaced but still having vibration problem
Hi bhpians,
My OHC (2001 1.3 Exi) had a clutch plate replaced around a week ago.
My Kilometer reading is 57853 kms.
I am experiencing vibrations while releasing the clutch pad ...more vibration while the AC is on( which i was experiencing earlier too).
The vibration is not when the engine is cold (5 to 10 minutes after startup.)
I told the mechanic about it; but he says that since the clutch plate is new it will take some time for the vibration to go...is it true?
Does all cars have vibrations when warmed up with ac on?
Will increasing the RPM reduce the vibration?
My current RPM is around 1100 at startup and 700 when fuully warmed up.
help.
prasannapatil is offline   Reply With Quote
Old 19th April 2008, 19:28   #2
Thanked: 660 Times
Vibration while idle or on the move??
what ever he is saying about new clutch is wrong anyway??
Old 20th April 2008, 09:59   #3
Thanked: 655 Times
Was the cover assembly replaced? If not, that could be the culprit.
jyobeb is offline   Reply With Quote
Old 20th April 2008, 13:37   #4
iraghava's Avatar
Thanked: 156 Times
I have a feeling the vibrations are due to worn engine mounts, have you had them checked also? Also, is the vibration there at high-rpms also?
Old 29th April 2008, 01:08   #5
The vibration is only when i begin to move.
The mechanic says he has changed the clutch plate as well as the pressure plate.
Old 29th April 2008, 01:16   #6
How about increasing the RPM of the engine? Will it decrease the vibration ??
Old 29th April 2008, 08:31   #7
viper's Avatar
Thanked: 9 Times
The culprit is the flywheel. Another team bhpian had a similar experience in his OHC1.5 and the problem was solved by replacing the flywheel.
Viper
viper is offline   Reply With Quote
Old 15th May 2008, 15:29   #8
Originally Posted by viper View Post
Viper
How much does the flywheel costs?....have already spent around 5.5k on the clutch set.
Any specific make for the OHC model?
Pras
Old 15th May 2008, 20:19   #9
Jaggu's Avatar
Thanked: 8,685 Times
Flywheel and engine mounts need checking. It was a mistake if your mech didnt check flywheel when he downed the gear box.
Anyways no point in cribbing, you will have to remove the gear box now and then check if all well.
OHC guys please help on brand and approx cost of Honda fly wheel.
Old 15th May 2008, 20:44   #10
viper's Avatar
Thanked: 9 Times
Its best you fit the original Honda flywheel. How many kms have you driven after the clutch overhaul. Hope you havent damaged the pressure plate.
Viper
Originally Posted by prasannapatil View Post
Pras
Old 15th May 2008, 21:36   #11
Its best you fit the original Honda flywheel. How many kms have you driven after the clutch overhaul. Hope you haven't damaged the pressure plate.
Viper
Its been maximum 600kms after clutch and pressure plate replacement.
Was thinking of changing the air filter next month ...so was wondering how much would the stock or light-weight flywheel cost me (budgeting )
How much would a K & N filter along with intake pipes would cost.
Prasanna
Old 17th May 2008, 12:49   #12
Ford Rocam's Avatar
Thanked: 16 Times
I don't see any reason why a stock flywheel (which was working earlier) can cause vibration problem (after changing the clutch), unless it is shaved inappropriately to reduce weight causing imbalance, there is no serviceable part in a flywheel, looks like to me more of an fitting issue or the clutch itself causing jutter.
Ford Rocam is offline   Reply With Quote
Old 18th May 2008, 11:46   #13
Thanked: 1,415 Times
You said your OHC settles at around 700 rpm at idle. This appears very low. Shouldn't correct idling rpm be 850-900? Try doing that and may be your problem will go away.
pgsagar is offline   Reply With Quote
Old 12th May 2009, 11:27   #14
Unhappy Got another OHC clutch problem or should I say gear shifting problem.
Got the clutch plate changed recently.
I got a strange problem in my OHC (1.3 Exi). Many times the gear gets stuck (on any gear) and I am not able to shift the gear back to neutral. When I again and release press the clutch pedal then I am able to shift the gear smoothly. I had this same problem even before changing the clutch plate. What could be the problem guys. I hope this doesnt affect my clutch plate.
Have driven around 600 kms after replacing clutch plate.
having a lowprofile tyres higher rimsize Vs having high profile tyres smaller rimsize rider60 Tyre & Alloy wheel Section 26 12th September 2017 23:28
Gettings brothers Accent VIVA CRDi but a mysterious issue and clutch plate problem... ajai_dev Technical Stuff 1 3rd December 2009 22:17
Clutch vibration in new i10 AntibiotiX Technical Stuff 2 1st December 2009 17:03
Booked a Swift VDi but having second thoughts after TD Switch Hatchbacks 60 30th April 2009 07:22
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
