Old 16th September 2009, 20:43   #241
Thanked: 253 Times
Originally Posted by gigy View Post
If there is such a product then its best to ask for a demo. you can get a written off battery from the local battery shop guys for testing and see if the active material comes back to life and regains its original chocolate brown color, gas freely and not heat up in the process.
If reduced specific gravity gets restored, would that indicate that the job has got done?
Old 16th September 2009, 22:07   #242
gigy's Avatar
Thanked: 41 Times
Positive confirmation of a charged battery is a capacity test only. specific gravity can be manipulated.
Consider a example of a battery lying around discharged with half filled electrolyte due negligence, it can be refilled and charged to show proper specific gravity but it will not have the capacity for its size. the submerged part will be sulfated to much higher level than the portion which remained dry. only the top part will involve in the voltage generation, voltage will be there but current capacity has gone down by half.
Old 17th September 2009, 08:39   #243
Thanked: 253 Times
Thanks a lot, Gigy, for the knowledge!
I'll try to work out some kind of deal to test that product before putting money down for it!
Old 17th September 2009, 09:14   #244
gigy's Avatar
Thanked: 41 Times
Do let us whats this product, if it works out. My car battery has started to show signs aging. ther are two more batteries from friends car.
Old 17th September 2009, 09:23   #245
I had some horrific memory of battery problems in my Indica. It used to stop in the middle of road and doesn't start at all. What a worst battery it was!
funda2max is offline   Reply With Quote
Old 17th September 2009, 09:33   #246
mavrick's Avatar
My 2006 Alto's EXIDE OEM battery lasted 22 months only. Got it replaced with Amaron,I drive my car everyday.but why my OEM battery didn't last long like other regular car users.MY experience with Exide OEM's r not good.
mavrick is offline   Reply With Quote
Old 20th November 2009, 10:45   #247
Default Battery life in Skoda Laura L&K AT
Dear friends,
I want to know what is the battery life in Laura L&K AT should be expected from your past experiences?
Which is the best make and model that should be used to replace the original one supplied by Skoda?
Thanks a bunch
kshirekar is offline   Reply With Quote
Old 20th November 2009, 18:22   #248
Thanked: 103,411 Times
Most German electronics-laden cars need a new battery every 3 years (approximate). All the Merc & BMW OEM batteries in my circle have gone kaput around 36 months (or slightly less, the lowest being 2.5 years).
Old 21st November 2009, 08:59   #249
MileCruncher's Avatar
Thanked: 357 Times
Even our Alto's OEM battery went kaput in 18 months even though it was Amaron. I think there is something wrong with OEM batteries in general from Maruti, may be they are built to price and slightly sub standard quality.
P.S: The car in question drives daily
MileCruncher is offline   Reply With Quote
Old 23rd November 2009, 10:28   #250
Thanks GTO. So which is the best make and model for the replacement?
Old 8th January 2010, 21:25   #251
humm's Avatar
Most imp way to maintain the battery is to regularly add battery water to it. My swift battery is running strong almost 2.9 months. Battery condition is excellent.
humm is offline   Reply With Quote
Old 8th January 2010, 21:41   #252
Thanked: 9 Times
In my Wagon R, it lasted for 18 months, Esteem - I only owned it for 12 months and then I sold it, no problems with battery. For past 3.5 years, I have NHC Zx and the battery is performing excellently
punkuz is offline   Reply With Quote
Old 9th January 2010, 13:38   #253
vrprabhu's Avatar
Thanked: 368 Times
Bought my Palio in March 2005. Had to replace the OEM battery in Nov. 2007. Replaced it with the same EXIDE. Now the replacement battery is also showing signs of weakness. Average life works out to be two and a half years. Planning to replace with Amaron...
vrprabhu is offline   Reply With Quote
Old 9th January 2010, 14:16   #254
Awaiting Email Confirmation
Thanked: 4,225 Times
Both the OE batteries [Exide] in my previous vehicles, Maruti Suzuki Omni [10 years], and then, Versa [5.5 years], were hale and hearty and kicking for more than 5 years in both the cases. At the first instances of starting trouble, I replaced them with the same brand. However, the replaced batteries of the same brand in Omni had a life of about 3 years each. But, I know, I cannot expect the same spectacular performance in the same brand in case of my present features-rich Fiat Linea.
J.Ravi is offline   Reply With Quote
Old 12th January 2010, 04:09   #255
StreetAddict's Avatar
Thanked: 45 Times
The OE Amaron has been in my car for 2+ years. Seems to be running strong as of now!
StreetAddict is offline   Reply With Quote
Your new cars suspension: How long should it last on our roads? Rtech The Indian Car Scene 102 15th November 2015 07:23
How long will a battery last without being used ? mithun Technical Stuff 12 2nd October 2015 14:44
Did this last weekend - Chennai-Trichy-Dindigul-Kodaikanal-Madurai-Trichy-Chennai srikanthpotluri Route / Travel Queries 2 2nd November 2011 02:20
When did you last get stuck and what were the learnings Baburajs 4x4 Technical 48 1st May 2009 12:01
Did your dealership tell you about ABS and Airbags during delivery of your car? amit Road Safety 24 10th February 2008 12:44
