Old 9th June 2010, 20:09   #301
h14
h14's Avatar
Thanked: 1,528 Times
Corolla H5 - March 2006 - Exide. Lasted for exactly 14 months!
Replaced with Bosch and its still going strong after 3 yrs.
Last edited by h14 : 9th June 2010 at 20:12. Reason: updated replacement battery detail
h14 is offline   Reply With Quote
Old 9th June 2010, 20:27   #302
mTorque's Avatar
Thanked: 34 Times
My Swift VDi OEM battery is weak, sometimes it takes two tries to get her started.
Its 2.5 yrs since I bought my swift. The technician says the batteries for Diesel engies needs to be replaced between 2nd and 3rd year.
Looking for a replacement shortly, will update the price when I replace it - prorbably by this weekend.
mTorque is offline   Reply With Quote
Old 10th June 2010, 12:04   #303
bhp_maniac's Avatar
Thanked: 96 Times
Smile
My 2006 Indica Xeta had the OEM battery till I sold it just a couple months back. While checked in the last service, the A.S.S people told its still strong
bhp_maniac is offline   Reply With Quote
Old 10th June 2010, 13:08   #304
trrk's Avatar
Thanked: 12 Times
Off topic here, but
This could be due to a faulty glow plug too!
trrk is offline   Reply With Quote
Old 10th June 2010, 13:08   #305
ad75's Avatar
Thanked: 20 Times
my esteem's OEM exide battery lasted 2 yrs and 8 months.
have replaced it with amaron flo.
ad75 is offline   Reply With Quote
Old 10th June 2010, 13:17   #306
jacs's Avatar
Thanked: 715 Times
OEM Battery which came on my Palio 1.2 is 6 years old now and still working fine. Its the trusted Amaron.
Wherein my accent's OEM was Exide and lasted less than 3 years now its the second Exide running fine since past 2 years.
jacs is offline   Reply With Quote
Old 10th June 2010, 15:40   #307
aditya.86's Avatar
Have a 2006 march santro which is still running on the OEM battery and still goin strong.
aditya.86 is online now   Reply With Quote
Old 20th June 2010, 20:04   #308
Thanked: 37 Times
Ford motorcraft lasted 3 years out of which 8 months were in standstill)
next Bosch DIN 44 4 years and 2 months.
toms_2191 is offline   Reply With Quote
Old 20th June 2010, 20:21   #309
vinaydas's Avatar
Thanked: 85 Times
OEM on the palio is still running strong after 5+years.
vinaydas is offline   Reply With Quote
Old 20th June 2010, 20:29   #310
R2D2's Avatar
Thanked: 1,239 Times
Default Exide OEM - Built to a price
My Altis' OEM Exide battery worked perfectly for 20 months before showing signs of failure. And this after perfect maintenance. Completely unacceptable.
Read about it here - http://www.team-bhp.com/forum/techni...oes-again.html (Oh No! Exide battery woes again)
Cheers!
Old 20th June 2010, 21:44   #311
Thanked: 117 Times
I haven't retained cars for more than two years so cant comment on my own experience.
But can share my mothers experience.
Jan 96 1996 M800. OE Exide NS40. Lasted till 2001 May.(required regular topup of distilled water)
Replaced with Amaron Pro-LIfe: Lasted till 2007 December
Replaced with Tata Green MF battery which still running strong.
The Secret behind the life of the batteries, My guess:
1. Daily Use, Car rarely left idle till date.
2. No Electrical Accessories/Modifications.
3. Regular periodic service by MASS
sureshkishore is offline   Reply With Quote
Old 20th June 2010, 21:57   #312
condor's Avatar
Thanked: 4,421 Times
aditya.86 : Have a 2006 march santro which is still running on the OEM battery and still goin strong.
@Aditya, it will help you specify the make & model of the battery, and how much you have run + load (additional ICE etc)
Old 20th June 2010, 22:09   #313
akshay4587's Avatar
Thanked: 1,629 Times
Exide Battery in my Accent Gave up today.
According to the Manufacturing date,it ran for 63 Months
Old 21st June 2010, 01:17   #314
ghpk's Avatar
Thanked: 192 Times
Mine OEM battery, Exide which came in my santro Apr-2006 works fine till date. Used my car almost daily, Extensive use of A.C. in summers.
Yesterday i got battery water checked/topped up at Exide dealer and he says it still looks good. volt before and after crank was checked.
However he added that 1st battery, the OEM one would certainly out-perform your 2nd battery cause the car alternator, engine, starter motor, A.C. electrical parts, puts less power loads in initial years and after initial 4-5 years, as these parts are not services as they should be, or they cannot perform like they did, when they came from factory, hence the 2nd battery would have to deal with more loads and the battery would last little less than your 1st battery.
I think the logic applied by him is quite true, what others say ?
Old 21st November 2010, 19:21   #315
Thanked: 161 Times
Maruti Van, bought September 1986, the battery lasted me for 8 (eight) winters. Used to regularly top up with pure Delhi tap water and keep the car in decent shape. Japanese brand, forget the name, friends at MUL then were not surprised since the batteries were lasting 5-6 years. Non airc-on car, weak stereo.
Other cars since then, typically 3-4 years. Exception: Chevvie Optra 1.6 petrol October 2004, original OE DELCO still going strong, vehicle serviced exclusively at Auto Vikas.
However, newer Maruti Swift Diesel Feb 2008 with Exide OE, went for 40k service yesterday, came back with weak battery and will need to buy a new one tomorow as winter rushes in.
So, I guess a lot of it is luck of the draw, and how much the service station guys fiddle around?
malq is offline   Reply With Quote
Your new cars suspension: How long should it last on our roads? Rtech The Indian Car Scene 102 15th November 2015 07:23
How long will a battery last without being used ? mithun Technical Stuff 12 2nd October 2015 14:44
Did this last weekend - Chennai-Trichy-Dindigul-Kodaikanal-Madurai-Trichy-Chennai srikanthpotluri Route / Travel Queries 2 2nd November 2011 02:20
When did you last get stuck and what were the learnings Baburajs 4x4 Technical 48 1st May 2009 12:01
Did your dealership tell you about ABS and Airbags during delivery of your car? amit The Indian Car Scene 24 10th February 2008 12:44
