Old 17th November 2011, 14:41   #391
Thanked: 114 Times
Default Re: OEM car battery life - How long did your OE battery last?
My baleno OEM battery lasted for 5.5 years . Changed it just for peace of mind.
m8002? is offline   Reply With Quote
Old 17th November 2011, 18:10   #392
jacs's Avatar
Thanked: 961 Times
Below are my updates.
  • Amaron battery which came with Palio lasted till I sold the car which is after 6 years. Not sure whether its still running.
  • Exide which came in Accent CRDI lasted only for 3 years and it was replaced with an Amaron which lasted for 4 years. Got replaced with another Amaron recently.
jacs is offline   Reply With Quote
Old 17th November 2011, 19:03   #393
pr_ans's Avatar
Thanked: 7 Times
Exide Freedom OEM battery which came with my Verna CRDI lasted for 4.5 years. Recently replaced it with Amaron.
pr_ans is offline   Reply With Quote
Old 21st November 2011, 15:59   #394
Raccoon's Avatar
Thanked: 105 Times
You may have wasted a good battery which may have lasted months/years more! Normally batteries don't die without warning. You could have just tested the battery instead, for your peace of mind.
And if its ment to die suddenly, its perfectly possible that even a brand new battery can die suddenly.
Old 21st November 2011, 19:40   #395
M.R.Boruwa's Avatar
My Indica’s OEM Exide died after 5.5 years. As correctly said it does give warning. In my case one cell was gone at 5 yrs, but it was working. But when I tried to crank after an idle time of 3 months I found it to be dead. It was Exide MF50Z.
M.R.Boruwa is offline   Reply With Quote
Old 21st November 2011, 20:22   #396
SushilBajpai's Avatar
Thanked: 116 Times
The Santro OEM lasted for more 4+ years, which were replaced with Amaron. 5 years later the Amaron continue their service without any complaint.
SushilBajpai is offline   Reply With Quote
Old 21st November 2011, 20:52   #397
rahul4640's Avatar
Thanked: 308 Times
My OEM battery was Exide, which lasted for almost six years. But then the car refused to start at the first attempt. One evening just a fortnight ago took the car to one roadside Exide dealer while returning home from office, for a load test. The mechanic showed me that while the battery voltage as well as the alternator charging was good, the battery was not behaving properly under load test. And after two or three such loads, the car refused to start. They helped me to start my car with a spare battery.
Although the next morning the car started at the first twist of the key, took the car at the same dealer for a battery replacement. This dealer was possibly the largest dealer of Exide in north Calcutta and for an Exide ATB battery they charged me Rs 4380/-, with an exchange of my old battery.
rahul4640 is offline   Reply With Quote
Old 22nd November 2011, 14:18   #398
DerAlte's Avatar
Thanked: 2,879 Times
Changed my Safari's OE Amaron battery with another Amaron. Could have lasted 5 years or more, but decided to change it after 4.5 years when the cranking RPM started coming down. Didn't want to face a situation on the road so played safe.
Old 22nd November 2011, 15:24   #399
vu2pmc's Avatar
Thanked: 32 Times
I have a Honda city which I bought new in 2007 March. Till date, I still use the same OEM battery. I guess it is Amaron. I also have a 60 Watt VHF transciever directly wired from battery. Hence many a time, I have used the radio on full power even with out engine one.
I must confess, the battery still works perfect. it is almost 5 years now..
Same has been my experience with my previous wagon R which I used for a good 7 years, with only one battery replacement.
vu2pmc is offline   Reply With Quote
Old 22nd November 2011, 17:15   #400
Freewheelin_KD's Avatar
Thanked: 68 Times
We changed our Indica Turbo's OEM Exide after 5.5 years and 100,000+ kms. However we had to replace our Accent CRDi's OEM Exide after 1.5 years and 20,000 kms as it became flat after 3-4 days of not using the car. This was mostly due to some fault in the electricals (which BTW the service centre could never diagnose).
Freewheelin_KD is offline   Reply With Quote
Old 27th November 2011, 17:58   #401
shankar.balan's Avatar
Thanked: 5,349 Times
my OEM Amaron was on its last legs when my Scorp went for its 50K Kms service. The Scorp was taking time to crank at start up time every day and I was beginning to wonder when the battery would kick it.
As it happens there was a bit of life left in it - 3 years and 9 months of use.
good enough I think.
I ve replaced it with a brand new Heavy Duty Exide before selling my Scorp on, to my pal.
Old 27th November 2011, 18:27   #402
Thanked: 11 Times
My OEM exide battery on my M800 lasted a good six years before giving up her ghost. The replacement Amaron did not make it past 1.6 years and afterwards I switched back to exide. I think Exide is a better option. Just be sure it is an original and not some refurbished stuff.
superlux is offline   Reply With Quote
Old 4th December 2011, 00:00   #403
beanstalk_230's Avatar
OEM battery on my Optra lasted 6 years (Around 20000kms) and for the Indigo it lasted around 4 years (More than 100000kms).
beanstalk_230 is offline   Reply With Quote
Old 4th December 2011, 07:00   #404
the OEM Amaron on the Scorp lasted 3 years and 9 months. changed it last week for a brand new Exide Heavy Duty one as I was selling the vehicle.
The Amaron would have gone on for a bit longer according to the service chaps but it was on its last legs and I prefer preventive maintenance rather than disaster maintenance.
Old 5th December 2011, 09:17   #405
gpa
gpa's Avatar
Thanked: 282 Times
My Alto is currently running on the OEM Exide which was given with the car. The battery is over 3.5 years old now and the car has covered 50,000 kms.
During the recent service the mechanic mentioned that one cell in the battery is weak. Cranking (on a cold start with ambient temperatures of 12-13 deg C) takes a little effort now, but I reckon that it should be good to last through this winter.
Static volt reading on the battery with a multi-meter shows 12.35 volts down from 12.53 volts when the car was at 30,000 kms.
Your new cars suspension: How long should it last on our roads? Rtech The Indian Car Scene 102 15th November 2015 07:23
How long will a battery last without being used ? mithun Technical Stuff 12 2nd October 2015 14:44
Did this last weekend - Chennai-Trichy-Dindigul-Kodaikanal-Madurai-Trichy-Chennai srikanthpotluri Route / Travel Queries 2 2nd November 2011 02:20
When did you last get stuck and what were the learnings Baburajs 4x4 Technical 48 1st May 2009 12:01
Did your dealership tell you about ABS and Airbags during delivery of your car? amit Road Safety 24 10th February 2008 12:44
