Old 25th April 2007, 20:04   #46
Roshun's Avatar
Thanked: 24 Times
My Wagon R's battery just died. It was an Exide OEM battery. It lasted 4 years 11 months and 8 days to the dot. That's a nice long and uneventful life.
I'm wondering whether to get the same one or switch to an Amaron. I've had good experiences with both on different cars.
Rgds,
Roshun
Roshun is offline   Reply With Quote
Old 25th April 2007, 22:00   #47
wolfinstein's Avatar
Whichever you choose- Amaron and Exide both are the Best you can find-Plus OEM fittments on different cars..!
If you have a High Audio or Heavy Electrical Accessories, then you can opt for the Yellow Top from Amaron-But they are damn expensive compared to regular battery.
wolfinstein is offline   Reply With Quote
Old 25th April 2007, 22:09   #48
nitrous's Avatar
Thanked: 283 Times
Just remembered.
Ford Service guys have the OEM battery as replacement that thing costs a measly 1450 bucks!
No warranty though.
Old 25th April 2007, 22:11   #49
rks
rks's Avatar
My Santro's OEM battery has a date stamp of Nov. 2000. It is still going strong. It seems to have plenty of charge capacity, as I can fill up substantial amt. of air with my air compressor in all my tyres using the car battery without running the engine, and the car starts easily afterwards. This is the test that I use to check the battery's status. The day the battery goes dead upon filling air, I will get a new one. I do not have any stereo system and I run the car to Mumbai and back every week. This probably keeps the battery well charged. I do not want to get the battery checked by some dealer, as they will almost certainly try to pressure me to get a new one.
Old 25th April 2007, 23:19   #50
razor4077's Avatar
Thanked: 252 Times
Used Exide Freedom in my old Santro - had to buy that since the car was second hand, and came with a really abused battery! Anyway, the Exide did its job - hassle free, no issues, till i sold it a year later.
My new Santro has an OEM Amaron battery. Car's going on two years, and no issues (touchwood). It's worthwhile to mention that the car was very rarely used for about 10 months when I was out of the country - got my dad to start it in the odd weekend. Never any issues... never died or went "down". I'm impressed.
razor4077 is offline   Reply With Quote
Old 26th April 2007, 15:07   #51
Roshun's Avatar
Thanked: 24 Times
Here's an update. I jump started my Wagon R with my Scorp in the morning & went and bought myself and Amaron Maintenance Free - 4 year warranty battery. Cost me Rs 2,850/-. Was sad to see that faithful Exide Freedom go. But anyway, as they say, Ting Tong!
Thanks for the advice folks.
Rgds,
Old 4th June 2007, 10:38   #52
Rtech's Avatar
Thanked: 217 Times
So. Went to start the car this morning. All warning lights flash on as usual. But, it cranks slow and doesn't start. Pull out my jumper cables and start it off another car. But the battery is on its last legs now. So that means the OE battery in my Skoda Tdi lasted 3 years & 4 months. About right I guess.
Old 4th June 2007, 10:46   #53
esteem_lover's Avatar
Thanked: 447 Times
Originally Posted by Roshun View Post
Rgds,
Roshun
My brother is running his oem battery (exide) in his wagonr till date. He bought the vehicle in July 2002.
Old 4th June 2007, 11:07   #54
bruty's Avatar
Hi
I have ZEN LX MPFI and my OEM battery lasted for 4 yrs, never given any problem till the date it died suddenly:(. it was not maintenance free may be at that time there were not common in market but i have changed to maintenace free Exide and it is working fine for last 2 yeras.
bruty is offline   Reply With Quote
Old 26th June 2007, 11:25   #55
Surprise's Avatar
Thanked: 131 Times
OEM batteries in my Swift gave me tough time this morning. Car refused to crank up & I checked the lights. All the lights working properly (including 100 W head lights) & I pressed the horn (upgraded one) to find out the sound generated is way way below its capacity. Started the car after pushing it & took it to the nearest battery shop.
Battery guy told me that it has to be put in for charge & replacement battery will be provided.
Car is 25 months old.
Does this recharging really help & is that dependable?
Is there any advantage with going higher capacity battery?
Surprise is offline   Reply With Quote
Old 26th June 2007, 14:23   #56
Thanked: 1,030 Times
What's the difference between a normal battery and a maintenance free battery? How to identify whether I have a maintenance free battery or not?
I have a 2004 NHC that will complete 3 years in August and the OEM battery is working.
anandpadhye is offline   Reply With Quote
Old 26th June 2007, 14:45   #57
Thanked: 294 Times
I my swift it is a amron. I dont know about yours as you did not mentioned it.and 25 months is a average life for a OEM battery. I think you need to replace the battery as it will not hold the charge for long.
this is advantage only if you have extra load in your car and you use that for longer than normal times with engine switched off.
Old 26th June 2007, 14:53   #58
Thanked: 294 Times
the regular battery need refill of distilled water regular intervals but in a maintenance free one there is less often need to top up the level.
Old 26th June 2007, 14:55   #59
OK. But how do I identify looking at the battery if it is of the type maintenance free or not?
Old 26th June 2007, 15:01   #60
Thanked: 294 Times
the regular one
maintenance free type
the regular will have holes to put distilled water and the maintenance free will be a closed one.
Your new cars suspension: How long should it last on our roads? Rtech The Indian Car Scene 102 15th November 2015 07:23
How long will a battery last without being used ? mithun Technical Stuff 12 2nd October 2015 14:44
Did this last weekend - Chennai-Trichy-Dindigul-Kodaikanal-Madurai-Trichy-Chennai srikanthpotluri Route / Travel Queries 2 2nd November 2011 02:20
When did you last get stuck and what were the learnings Baburajs 4x4 Technical 48 1st May 2009 12:01
Did your dealership tell you about ABS and Airbags during delivery of your car? amit The Indian Car Scene 24 10th February 2008 12:44
