Old 18th July 2014, 02:16   #601
Thanked: 22 Times
How come same battery lasts shorter or longer in same/different cars?
IronH4Wk , Typically OEM batteries are built to cost so they last shorter than aftermarket batteries which are relatively better built.
Originally Posted by deepv View Post
My Fabia OEM battery seems to be dead since last couple of days, needs to be checked for how is the condition.
Never gave a problem in 5 & 1/2 years till now.
Deepv , Your OEM battery has served you well for more than 5 years which is more than the average OEM battery life. It is better to replace it since a dead battery could leave you stranded anywhere anytime.
Please contact Exide batmobile service , it's free and these guys would come over to your place and let you know the condition of your battery.
Last edited by Aditya : 19th July 2014 at 13:31. Reason: Merging back to back posts
spookey is offline   Reply With Quote
Old 18th July 2014, 03:08   #602
Raccoon's Avatar
Thanked: 105 Times
Default Re: OEM car battery life - How long did your OE battery last?
Be very wary about Batmobile guys. They can be absolute vandals. Speaking from more than couple of experiences. You may well end up with other damage... and its not necessarily visible up front. But the guys keep changing and some of them are decent. Anyway, you don't really need them if you can do some basic DIY stuff.
And whatever you do, don't end up buying an Exide battery just because you called the Batmobile.
Raccoon is offline   (1) Thanks Reply With Quote
Old 18th July 2014, 14:25   #603
Thanked: 134 Times
Originally Posted by Raccoon View Post
Be very wary about Batmobile guys. ...
Thanks for your suggestions .. folks!!
I got the battery checked with an Amaron guy & it does seem dead, to be replaced - they apparently didn't have a ready replacement.
Racoon .. you are right, the person wasn't very soft on pulling out the battery case from the locks around, so I had to remind him to be nice .
Hoping he hadn't already done any damage.
-Deepankar
deepv is offline   (1) Thanks Reply With Quote
Old 18th July 2014, 17:17   #604
Raccoon's Avatar
Thanked: 105 Times
-Deepankar
They can be extremely crude. Last time the guy disconnected the battery while engine was running! One of the worst things you can do. Couldn't stop him in time... They are programmed to do damage in a flash. And I even got a lecture about why it's perfectly safe to do so because they do it all the time. Now I stay away from them, like I do with their low quality products.
Old 20th July 2014, 11:26   #605
Thanked: 50 Times
My exide freedom OEM with Innova 2007 model ,died today....after an incredible 100k and 7.3 years !replacing with Exide mileage!
subbu567 is offline   Reply With Quote
Old 21st July 2014, 20:29   #606
Thanked: 134 Times
Amaron seems to be having a shortage of 60AH battery - apparently they are manufacturing more of inverter batteries. Still waiting for one since 3 days.
Wondering should probably go for Exide!!
deepv is offline   Reply With Quote
Old 22nd July 2014, 11:32   #607
Geo_Ipe's Avatar
Thanked: 361 Times
Originally Posted by arin_12 View Post
Just two days back I changed my car battery from OEM to EXIDE. It was fully dead and stopped in middle of the road. It lasted 7.6 years with all the music and display system.
Does a car stop in the middle of the road owing to a dead battery??
Or did you mean the car didn't start after being switched off, in the middle of the road??
Geo_Ipe is offline   Reply With Quote
Old 24th July 2014, 11:50   #608
Thanked: 134 Times
Just two days back ...
I suppose it should be the second case, would like to know if its otherwise .. Arindam!!
On a different note, what do you really do if its stuck in the middle or on a signal?
Mine went dead last week, luckily in my parking at home.
A neighbors driver suggested push starting it at second gear but didn't work out.
Old 24th July 2014, 11:58   #609
arin_12's Avatar
Thanked: 20 Times
Basically I have given the car to my friend. He told me that he stopped the car and switch off the engine. After 2 min when he tried cranking the engine again it did not start.
arin_12 is offline   Reply With Quote
Old 24th July 2014, 14:39   #610
Thanked: 134 Times
I thought so.
What did he do then .. how did you revive the car there?
Did you guys have to tow it to service/battery station?
Old 24th July 2014, 15:24   #611
tud
tud's Avatar
Thanked: 31 Times
It is easily available with Chennai retailers. I got mine 2 weeks back for Rs 5000.
Did you check out Amaron online store?
tud is offline   Reply With Quote
Old 24th July 2014, 15:55   #612
djay99's Avatar
Thanked: 491 Times
OE Exide battery in my Getz Crdi lasted for over 4 years and around 45K KM. Later changed it to Exide Matrix which has some 5 year warranty. This costed around 10K.
djay99 is offline   Reply With Quote
Old 25th July 2014, 01:24   #613
Thanked: 134 Times
Hmm .. I got it yesterday.
This vendor is distributor for central part of Hyderabad, so I didn't go for online one.
Old 25th July 2014, 21:30   #614
joybhowmik's Avatar
Thanked: 1,907 Times
Back to the thread title.. My car was delivered in November 2009, so the battery in it must at least be 1-2 months older. It's still running strong. Exide.
Old 17th August 2014, 12:20   #615
joybhowmik's Avatar
As of today morning- August 17, 2014, the Exide suddenly gave up.
Cajoled the car with a jump-start and it started just fine. Left it running for close to half-hour to get it charged up.
Then turned off the ignition. Cranked the ol' girl back again. And she purred to life. Repeated. Dead as a door nail.
Time for a new battery....and so in an hour's time an Amaron 95D26L with 3Y warranty was fitted by the local battery guy for Rs 4000/- . Home delivered.
And the Exide has gone to meet its maker. RIP. And thanks for a glorious 5 years of service!
Your new cars suspension: How long should it last on our roads? Rtech The Indian Car Scene 102 15th November 2015 07:23
How long will a battery last without being used ? mithun Technical Stuff 12 2nd October 2015 14:44
Did this last weekend - Chennai-Trichy-Dindigul-Kodaikanal-Madurai-Trichy-Chennai srikanthpotluri Route / Travel Queries 2 2nd November 2011 02:20
When did you last get stuck and what were the learnings Baburajs 4x4 Technical 48 1st May 2009 12:01
Did your dealership tell you about ABS and Airbags during delivery of your car? amit The Indian Car Scene 24 10th February 2008 12:44
