Old 2nd July 2015, 16:01   #676
Thanked: 89 Times
Default Re: OEM car battery life - How long did your OE battery last?
My car battery is yet to be replaced, only during last service in may'15after 9 years ive been recomened to replace. Maybe in next 2-3 months will go for a new one.
ODO reads 50,000 kms.
varunanb is offline   Reply With Quote
Old 2nd July 2015, 17:16   #677
prashant316's Avatar
Thanked: 68 Times
My Nissan micra's battery lasted for 2 years and 10 months with 40000 on the odo. It came with exide. Now I have changed to amron flo. Let's see how long does this go.
But one question, I see an increase in the mileage after the battery change. Does battery somehow impact mileage?
prashant316 is offline   Reply With Quote
Old 2nd July 2015, 17:22   #678
Recently replaced the stock battery. Disappointed with its life.
Car: Fiat G. Punto MJD
Battery: Exide DIN50
Lasted till - 1.5 Years
KMs Run - 38k kms
Replaced with - Exide DIN50
balavj27 is offline   Reply With Quote
Old 2nd July 2015, 17:38   #679
FuelInjector's Avatar
Thanked: 257 Times
Originally Posted by Sudipto-S-Team View Post
I am not too sure if your sound system sounds better because of the Sonic battery, per se. I think it is because of a new battery under the bonnet :-)
yup. just put that in for the fun
for the benefit of other Honda City owners doing a 20K service..attaching my service invoice.
FuelInjector is offline   Reply With Quote
Old 16th July 2015, 15:27   #680
lipaul's Avatar
Thanked: 138 Times
My OE battery, Amaron, on Swift VXi lasted 7 yrs & 3 months. I changed it today with an Amaron Pro from BatteryBhai. The car has run 42K.
lipaul is offline   Reply With Quote
Old 21st July 2015, 11:57   #681
Default Ford Ecosport T (o) battery died in 2 years
Hi All,
My ford ecosport T(o) is exactly 2 years old as of today, car didn't start today, roadside assistance came and saying battery is dead. Car has clocked 20000 km. Will the OEM battery only last for 2 years? I have extended warranty on the car. IS the battery covered in this?
Srini
switz is offline   Reply With Quote
Old 21st July 2015, 12:28   #682
Soumyajit9's Avatar
Thanked: 1,669 Times
Car: Chevrolet Beat LT Petrol - 2011
OEM Battery: Exide 12v 50AH
Clocked: 36,000 kms
Years: 4 years 2 months
What happened, forcing me to change the battery is a funny story.
Read Here: http://www.team-bhp.com/forum/techni...-now-what.html (Battery dealer installs 3-wheeler battery in my car!! Now what?)
Soumyajit9 is offline   (1) Thanks Reply With Quote
Old 10th August 2015, 15:09   #683
mahesh_sn's Avatar
Thanked: 147 Times
OEM Exide 55 Ah battery on my car died suddenly last month (51k and just above 4 years) without any showing any symptoms. Got it replaced with another Exide battery for 5,500 after a discount of 1,500 for old one.
mahesh_sn is online now   Reply With Quote
Old 17th August 2015, 16:07   #684
Thanked: 85 Times
Modern-day batteries last longer, have more 'cold crank capacity' etc., but when their life is over, they give up the ghost suddenly, mostly without warning. I remember, when dear friend and Guru Uday Bhan Singh first pointed it out to me, I wasn't fully convinced. I had seen the old black hard-rubber shell batteries give plenty of signs before dying, and one could shop around and choose before changing. But that is not the case anymore. In my last Gypsy 1000cc I found the battery dying one evening, and had to push-start the next morning, and rush to the battery shop before everything else. keeping the engine on at even long stops !
Very inconvenient, and downright dangerous, under certain circumstances !
SnakemanJohny is offline   Reply With Quote
Old 3rd September 2015, 23:01   #685
bijubalan's Avatar
Thanked: 32 Times
I changed OEM battery on my i10 last month. It was an Amaron 40B20L. It lasted a good 4 years but with minimal usage of 30K kms. Battery test was not all that bad, still went by the service center advice. Did not want to take a risk as I had already jump started once. Power windows were slow as well (not sure whether reason was a low battery).
bijubalan is offline   Reply With Quote
Old 25th September 2015, 22:00   #686
Thanked: 50 Times
My OE battery is still in use after 5 years of completion of using the car and the ODO is around 48k mark. The previous owner drive only 8-9k in the first 3 years while I took the ODO from 9 to 48 in a matter of 2 years!
I am facing this terrible problem where the car does not start in the first go. I have to crank at least twice to get the car started. No problems once it starts. This, I am reporting after the servicing has been done and the adviser gave an OK to the battery! I guess it is time to change for sure as reading through the thread I see most people have had the change around 50k mark. I am using a Fiat Punto 1.2 Active.
Any suggestions, online experiences or so on battery?
ameyawaghmare is offline   Reply With Quote
Old 4th October 2015, 13:34   #687
NPV
NPV's Avatar
Thanked: 4,871 Times
Recently got the 60K service done for my Dire and the battery report says it is bad and needs to be replaced. It is still the same Amaron OEM battery that is just 3 months short of 7 yrs Still starts with the first crank but the crank seems just a bit longer, is it time to replace the battery ? Posted the details with the last 2 battery test reports - here (Signs that battery needs a replacement).
Last edited by ampere : 2nd November 2015 at 21:13. Reason: Fixed typo as requested
NPV is offline   Reply With Quote
Old 4th October 2015, 13:46   #688
dpkbehera's Avatar
Thanked: 206 Times
Car: Maruti Wagon R
Battery: OEM
Lasted till - 5 Years 2 Months
KMs Run - 45k +
Replaced with - Exide Max
dpkbehera is offline   Reply With Quote
Old 4th October 2015, 17:57   #689
Gansan's Avatar
Thanked: 883 Times
The OEM battery on my Alto lasted for 4.5 years. Did not conk out, but was changed because one cell had become weak.
Old 20th October 2015, 14:04   #690
auto_enthusiast's Avatar
Thanked: 332 Times
Default OEM car battery life - How long did your OE battery last?
The OBD in my Figo shows the battery charging of 13.6-13.8 whilst running. Earlier it was 14.0 but off late it has reduced. On cranking, the voltage touches 11.2 but does not go below that.
Is this a cause of concern?
Has the battery become weak or is the alternator not charging properly?
Please advice.
auto_enthusiast is offline   Reply With Quote
Your new cars suspension: How long should it last on our roads? Rtech The Indian Car Scene 102 15th November 2015 07:23
How long will a battery last without being used ? mithun Technical Stuff 12 2nd October 2015 14:44
Did this last weekend - Chennai-Trichy-Dindigul-Kodaikanal-Madurai-Trichy-Chennai srikanthpotluri Route / Travel Queries 2 2nd November 2011 02:20
When did you last get stuck and what were the learnings Baburajs 4x4 Technical 48 1st May 2009 12:01
Did your dealership tell you about ABS and Airbags during delivery of your car? amit The Indian Car Scene 24 10th February 2008 12:44
