| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Sep 2006 Location: Mumbai
| Hi, I own an indica v2 dls model and have done 39552 kms on the same. Last week i gave my vehicle for sevicing at Fortune Motors for servicing. I had complained about poor pickup in both scenarios (AC and nonac). I had also complained about the car knocking (jerking) during changing from 1st to 2nd and so on. I got my vehicle serviced on the same day and after satisfactory trial tun took delivery of the vehicle. When i reached home at jogeshwari (40 kms) from nerul, i noticed that the car was jerking again and the pickup also dropped. I called fortune and told them about the problem and i fixed up an appointment for 15th april. On 15th after lot of adjustments, they told me that the fuel injector pump will have to be opened as they found nothing wrong with the vehicle. The cost for the same is approx Rs. 8-10000. In the meanwhile i did 2 long trips of 300 kms each and found that the vehicle would run nicely at high speeds with ac on without jerking but as soon as it slowed down it jerked even after gear changes. Please let me know as to what could be the problem. Thanks Fariborz |
| | #3 (permalink) |
| Team-BHP Moderator ![]() | Fuel Pump overhaul is a good way of making money by TASS. Don't let them touch the fuel pump. This is a typical clutch adjustment problems. Try a different dealership
__________________ .--- ..- ... - - .-- --- -- --- .-. . -.. .- -.-- ... - --- --. --- !! |
| | #4 (permalink) | |
| BHPian Join Date: Mar 2008 Location: Bangalore
| Quote:
Hi, I think the problem is with the Nozzles(fuel injector).There must be some kind of dust or something which might block any holes in any of the four nozzles so the pressure at which the nozzle spays diesel will be less and it causes the jerking ,low pick up and the engine knocking sound.IMHO please take your car to any MICO fuel pump service shop and ask them to clean the Nozzle(injectors).Once it is cleaned this problem should be rectified.Please be careful that that Fuel pump service center guys might tell that it is the problem with the fuel pump but just ask them to clean the nozzles and set the correct pressure for the nozzle.They might charge you a maximum of 200-250 for this.So IMHO please do this before checking your clutch.I said this from my experience because we own a MICO service center and these A.S.S guys approach us with Fuel pump and nozzles and almost 95% times the problem is because of the nozzle and not pump. | |
| | #6 (permalink) | |
| Quote:
IMHO-In my humble opinion ![]() | |
| Thread Tools | |
Similar Threads | ||||
| Old Indica LEi / New Indica DLS / New Alto LXi | shuvc | Hatchbacks | 20 | 19th February 2008 16:31 |
| Indica DLS / DLS TURBO / DICOR?.....What BUY? | musicmanaman | Hatchbacks | 18 | 11th August 2007 19:38 |
| Indica NA DLS vs Turbo DLS vs Turbo DLG | greenhorn | Hatchbacks | 10 | 5th May 2007 17:20 |
| Indica V2 DLS missing problem | tsk1979 | Technical Stuff | 7 | 4th January 2007 23:05 |
| Indica DLS vs Palio 1.9D EL - help !!! | hkanitkar | Hatchbacks | 36 | 23rd September 2005 23:54 |
