Thread Tools
Old 2nd May 2008, 19:32   #31 (permalink)
Kaizer Sozay's Avatar
Originally Posted by Shankyz View Post
Did you get the AC serviced ? If not get it done, should make things better. Also, get the gas topped up etc.
Also, you could get window film/front windscreen film installed.
There is a ton of info on Front windscreen and window films on the forum, try searching for it.
Got the Ac serviced last year, got tint as well as the front glass has suncontrol. but Delhi heat is terrible compared to bombay.
__________________
"The greatest trick the devil ever pulled was convincing the world he didn't exist ."
Kaizer Sozay is offline   Reply With Quote
Old 4th May 2008, 15:47   #32 (permalink)
trrk's Avatar
Hi anand
A little off topic!
> The idling RPM for my NHC is 800. The RPM at 80 kmph in 5th gear is 2500
Are you sure about the RPM at 80kph in 5th? In my CVT it is just about 2000RPM at 80kph.
The petrol consumption will be more if you are running the engine at 2500RPM instead of idling at 800RPM when stationary.
__________________
Rajesh
-Marina LS, Oct 05, 44223 (44771) kms, 13.94 kpl
-City CVT, Sep 07, 15423 kms, 13.23 kpl
trrk is offline   Reply With Quote
Old 4th May 2008, 22:10   #33 (permalink)
Originally Posted by trrk View Post
Hi anand
A little off topic!
Yes, I agree.
CVT seems to be more efficient in it's final gearing. In Gxi (manual), it needs 2500 RPM for 80kmph (in 5th).
And yes, you are correct, petrol consumption will be more at 2500 than 800, so in absolute terms, there will be more pollution. But what about combustion efficiency? I read somewhere that combustion efficiency will be highest in the range of 2500 rpm (this varies from engine to engine). If that's true, then should we have something like pollution per ml of petrol??? Just thinking...
__________________
Aerodynamically speaking, a bumble bee should not be able to fly, but it does not know this, so it flies.
anandpadhye is offline   Reply With Quote
Old 5th May 2008, 19:43   #34 (permalink)
Originally Posted by Kaizer Sozay View Post
The Heat in delhi is unbearable, the AC in my zen just doenst cool any help guys?
pressure test check should be done, if no gas make sure to vaccum it, add oil, add gas and you are kewl. do change the dryer if never done.
but this all is simple as it sounds only if the pressure test holds for at least 10mins.
if not finding the leaks with soap water can be easy or a real pita.
__________________
Zindagi ek rangmanch hai aur humsab kathputliyan hain
Sabki dor uparwaleke hatho mein hai kab kiski dor khch jaye koi nahi jaanta
Jr Godzilla is offline   Reply With Quote
Old 6th May 2008, 12:02   #35 (permalink)
trrk's Avatar
So theoretically CVT should give more mileage, but it needs an extremely light foot to get the RPM correct. Surprise that the auto has higher gearing! The CVT comes with a seven speed manual select mode elsewhere. If that waould have been available here, it would have beaten the manual for mileage.
> rpm
I don't know about combustion efficiency, but the mileage is most at the RPM where the maximum torque is developed and that is around 2500 RPM in the City.
__________________
Rajesh
Old 20th July 2008, 02:36   #36 (permalink)
gaurav_diavolo's Avatar
Default Weird Question On A/c Cost
Note from Mod - Post moved to a thread where the answers seem to already have been mentioned.
Guys! I have been doing a lot of tours and I get reimboursed a decent amount on hotel stays. I do my travels to Delhi (250 kms) in my Ikon 1.6 instead of Volvo (for which I am given the fare by the company) because of the fun factor in self driving and non dependence on autowalas in the metro. Now, I also get paid Rs. 11500 per night for stay in hotels. I found that generally when I stay in hotels I only spend about 2-3 hours at the hotel and I can freshen up at my relatives place (which is in reality my own apartment rented to them!).
Suddenly this question came to me that since I can fully avoid my hotel stays and save 11500 per night and if a couple of hours or even three or four hours I have to spend in my car in the hot afternoons of Delhi (I would love to coz of the ICE playing soothing music and jet black tints for my sleep or relaxation in private) and if I keep my car ON for a/c blowing at full speed, how much would it cost me per hour. Lets say for a Ford Ikon 1.6 giving me a mileage of 10 combined, and in good engine shape. or how many litres of petrol is burnt per hour with car on and a/c full-on working?
__________________
Ford Endeavor XLT 2005
Ford Ikon 1.6 Zxi 2005
My garage is incomplete without a Mondeo!
gaurav_diavolo is offline   Reply With Quote
Old 20th July 2008, 12:29   #37 (permalink)
bblost's Avatar
Gaurav.
The first thing that comes to my mind is that it will be a lot lesser than 11,500.
Since you drive long distances you will be keeping a clear tab on your milage.
So after your drive and CarStay (my word) simply calculate the reduction in FE.
Then its simple maths to calculate your CarStay charges.
__________________
Be your own Hero.
RE TBird 2003, no speedo, no range limits.
Wagon R, 2004.
Old 20th July 2008, 13:36   #38 (permalink)
Originally Posted by bblost View Post
Gaurav.
Thanks! But then my CarStay (your word ) varies from trip to trip. A clear consumption figure is what I wish to know. Lets say: For smaller engine cars, three box cars, luxury sedans and diesel cars. If an expert can tell xx Litres / hour kinds for these......
__________________
Old 22nd July 2008, 19:14   #39 (permalink)
NO replies guys? Some experts needed to attend this thread!
__________________
Old 23rd July 2008, 00:13   #40 (permalink)
RedMM340's Avatar
Gaurav,
Don't spend hours in a stationary car that is running. You could end up DEAD from carbon monoxide poisoning.
This is no joke, it happens all the time.
As an alternative, why don't you go to one of the nice malls in the NCR and catch a movie in a nice air conditioned hall?
RedMM340 is offline   Reply With Quote
Old 23rd July 2008, 10:32   #41 (permalink)
Team-BHP Moderator
Rehaan's Avatar
.... If an expert can tell xx Litres / hour kinds for these......
Have you not read this thread?? The figures you are looking for seem to be mentioned quite clearly earlier.
cya
R
__________________
The memory of you will ride by our side forever.
Rehaan is online now   Reply With Quote
Old 23rd July 2008, 12:48   #42 (permalink)
supremeBaleno's Avatar
Location: Weekdays at DetroitOfIndia (Chennai) & Weekends at VeniceOfTheEast (Alappuzha).
This not only varies from segment-to-segment, but also within cars in each segment itself. When you are talking Rs.11500 kind of figures in hotel-rent savings, I would think it not worthwhile to even bother calculating the exact figure, if just money is the factor. But if you wish to find the exact figure, tank up just before you plan to spend time in the car for whatever hours and then tank up again to see the fuel consumed.
As a thumbrule, it is like 100ml consumed for 10mins of idling. So, if you are spending 3 hours in your car, it would be approx 2 litres - 100bucks. Not much in money terms, but then neither good for you (as mentioned by RedMM340) nor for the car or the environment. As someone suggested, better get into one of the a/c malls or movie theatres.
__________________
A bad worker blames his tools. Bad drivers blame the car's rattles for bad performance on track. :-)
Thread Tools
Engine switch-off procedure in cars rr_zen Technical Stuff 60 9th July 2008 20:02
Do you switch engine off soon after reaching destination? vnabhi Technical Stuff 15 18th January 2008 16:24
Do you switch your system off before shutting the engine down? kb100 Ask the Gurus 29 17th June 2006 14:55
Will Rossi make the switch to F1? GTO Motor-Sports!! 14 2nd February 2006 17:07
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
