| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Nov 2007 Location: Hyderabad
| Hi, I have this basic doubt which became more intense when my better half made me wait outside her office for 45 mins yesterday . We know that the A/C cooling system becomes effective only when the engine is running. So what should be the best way to keep the car cool when you are inside with the engine off for a long time? - Should we start the engine or keep it just in On mode and make do with the heat? I can understand keeping the engine running if it's just a matter of minutes, but what about long waits? I have seen cab drivers sleeping inside their cars in the afternoon with the engine running to make the A/C effective. Is it the right thing to do? Which hurts the FE more?With the mercury rising rapidly these days, I think I need a good solution to this immediately. Thanks, Rahul |
| | #2 (permalink) |
| Team-BHP Moderator ![]() | In the current heat wave(Pune is 42 deg :() I dont think there is any alternative. You can off course park under shade & be slightly better off. Switching ac on & off will make the inside more humid & ac working double to compensate for the off time.
__________________ 180, 225, 150, ??? -> 159? |
| | #3 (permalink) | |
| Senior - BHPian | Best is to get out of the car & wait outside under a tree. Idling your car with AC for extended periods is certainly not a good thing for your car. Engine is bound to get more heated up.
__________________ Quote:
| | #4 (permalink) |
| BHPian Join Date: Apr 2007 Location: Pune
| Yes, if wait time is more, why wait inside the car? Kindly be considerate to mother nature as well. An idling engine with A/C on is definately going to cause a lot of pollution. The A/C is driven by the engine through a magnetic clutch. So even if engine is off, this clutch will be engaged as long as your battery has the charge, though the A/C compressor will not run as the prime mover (the engine) is off. Hence, if you need A/C to do it's job, you need the engine running.
__________________ Aerodynamically speaking, a bumble bee should not be able to fly, but it does not know this, so it flies. Last edited by anandpadhye : 25th April 2008 at 12:33. |
| | #6 (permalink) | |
| Senior - BHPian | The Office reception is a good place to wait than the car, if it is going to take longer. ![]() Quote:
__________________ Remember, its a machine | |
| | #7 (permalink) |
| Senior - BHPian Join Date: Dec 2005 Location: Weekdays at DetroitOfIndia (Chennai) & Weekends at VeniceOfTheEast (Alappuzha).
| I go with dadu here - the reception would be climate-controlled. Why waste fuel idling a car just to keep you cool, when you have better env-friendly options ? Or as others said, find some tree or shade (not shady place ) nearby. As a policy, I never ever idle the car just for the a/c. But recently have had to break it for my li'l kid due to the weather in Kerala being pretty hot and with no sign of any rains.
__________________ A bad worker blames his tools. Bad drivers blame the car's rattles for bad performance on track. :-) |
| | #8 (permalink) |
| BHPian | firstly , i am not sure what are the 2 options being suggested here to keep the car cool ? i always thought there is just one option - keep the engine on and the a/c running ? is there any other way to run the a/c ( not just blowers ) ? wheareas, a/c on idle causes pollution etc, i wonder whether that pollution is any different from pollution caused with car on the move and a/c running ? all though i normally dont do this, i did use the a/c with my engine on neutral for nearly 35-40 mins when we had to wait in the scorching delhi heat and no shad(y) place or office receptions nearby.. i did not notice any dramatic drop in FE for that particular full tank - in fact i almost got the same FE as i get otherwise... of course, if you have a diesel car, then its really easy on the wallet - ive seen many diesel car owners not even switching off their cars when they go to do some shopping !! |
| | #9 (permalink) |
| BHPian | I usually never switch off my engine and AC, when the waiting time is less than 20 minutes. Pune is getting hotter by the day and it is unbearable at times! Finding a shadowy place is not possible all the time. I never switch off my engine and AC at signals also. There is no dramatic drop in FE because I leave the engine on. Someone told me that the engine consumes approximately 1 litre of fuel for every hour of idling with AC. Is it true? During my past trip to Kerala, I slept for two hours in my car with the engine and AC on, because of the mosquitoes and humid weather!
__________________ Travelling ten thousand miles of world is better than reading ten thousand scrolls of books!! |
| | #10 (permalink) | |
| BHPian Join Date: Nov 2006 Location: Bangalore
| Quote:
Bangalore currently is like 33 degrees with 30% humidity and cool winds (winds are never warmer here anyway). | |
| | #11 (permalink) |
| BHPian | Sri, Its touched 37 degrees on Wednesday. I agree with you, Bangalore was never hot earlier. Using AC during Idling will only result in Engine Damage/Polluting environment and Global Warming. I see other options given by TBhpians more appropriate to act upon.
__________________ KADAM |
| | #13 (permalink) | |||
| Quote:
![]() Quote:
It is basically about the lower operating temperature being bad for the engine. To quote from one of the links, "In fact, idling longer than that could actually damage your engine in the long term. Because an idling engine is not operating at its peak temperature‚ the fuel does not completely combust, leaving residues in the engine that can contaminate engine oil and make spark plugs dirty. Excessive idling also allows water to condense in the vehicle’s exhaust, contributing to corrosion of the exhaust system."
__________________ A bad worker blames his tools. Bad drivers blame the car's rattles for bad performance on track. :-) | |||
| | #14 (permalink) | |
| BHPian Join Date: Jan 2007 Location: Trivandrum
| Quote:
If it is inside a closed enclosure, it is even more dangerous. One year back an incident happened in Trivandrum which killed three youngsters inside their car shed which had no air circulation. They had the car AC on and had some party inside the car. | |
| | #15 (permalink) | |
| BHPian | Quote:
My God!!! ![]() Thanks for the info bro!!! Really appreciate it! I slept in a petrol pump as no good hotel was available for the next 50 kilometres.
__________________ Travelling ten thousand miles of world is better than reading ten thousand scrolls of books!! Last edited by Chevy_lover : 25th April 2008 at 15:39. Reason: Typo | |
| Thread Tools | |
Similar Threads | ||||
| Engine switch-off procedure in cars | rr_zen | Technical Stuff | 60 | 9th July 2008 20:02 |
| Do you switch engine off soon after reaching destination? | vnabhi | Technical Stuff | 15 | 18th January 2008 16:24 |
| Do you switch your system off before shutting the engine down? | kb100 | Ask the Gurus | 29 | 17th June 2006 14:55 |
| Will Rossi make the switch to F1? | GTO | Motor-Sports!! | 14 | 2nd February 2006 17:07 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
