Thread Tools
Old 10th February 2005, 05:28   #16 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Ok,
Let me just get something straight here. When you look at a quoted ground clearance figure in a magazine or wherever it does NOT accurately indcate how likely it is that your car will bottom out on a speedbump.
For example, it is possible that a car with a GC150mm will not touch a speedbreaker that another car with GC170mm touches!
Why? - well, GC is measured between the lowest hanging point of the car to the ground. The lowest point usually tends to be the bottom of the differential (or the exhaust system.)
Now, keep in mind that the differential is directly between two drven wheels, which means hitting the differential on a speedbreaker is an almost impossible task.
So since that is eliminated, what are we left with as a point of reference for GC? Nothing.
Usually when a car hits on a breaker, it hits somewhere between the front and rear wheels. This is where measurements should be taken for "speedbreaker ground clearance" imo!!
Its illinformed to assume that a octavia is more likely to hit a breaker than an esteem (134mm vs 160mm), because all that is likely to mean is that an octavia's lowest point is 26mm lower than the esteem's lowest point.
Now since Rtech says he has not had major problems with the octi bottoming out, i cant help but to assume that it has just one really low (134mm) point, and the rest reasonably higher.
cya
R
ps - GTO, C-class is apparently 130mm, any problems? (although i think it is overall a lower car, hence would still be a bit of a problem)
Old 10th February 2005, 07:30   #17 (permalink)
iceman91's Avatar
also the wheel base guys....that counts a lot. my baleno is higher then the sonata and i know a number of places where the baleno scrapes it underside and the sonata does not even touch.
__________________
...91 is back !!!!
iceman91 is offline   Reply With Quote
Old 10th February 2005, 08:25   #18 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Hey Iceman,
The wheelbase is another factor indeed...especially in more of a "rural" setting. However, this example is kindof the opposite to the general logic that might be applied... (take SWB jeeps as an example)
Also, when you say your baleno is higher than the sonata....how are you judging that?
cya
R
Old 10th February 2005, 08:26   #19 (permalink)
So, if the car has longer wheel base AND the lowest GC is somewhere the middle of the body, then typically the car will have its wheels before and after the speed breakers and bound to scrap the middle part. Look at the diagram below. @ is wheels and ^ is speed breaker (I could not draw much better :-))
______________
_@____^____@_
On the other hand, if the lowest GC is on the axle side or very near to the wheels, there is no problem then.
But how to know where is the lowest GC of a car? . We can't expect that info from the sales staff
skamb is offline   Reply With Quote
Old 10th February 2005, 09:08   #20 (permalink)
Team-BHP Moderator
Rtech's Avatar
Spot on with the explaination there rehaan. Going by figures alone will not give you an accurate representation of the "real world" GC.
Just bend down and take a looksi under the car. The lowest hanging point would be the point at which the ground clearance is measured.
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 10th February 2005, 11:26   #21 (permalink)
Team-BHP Moderator
navin's Avatar
SUVs are now coming with written warning about roll overs. ideally the CG of a car should be in the same plane as the axles. this is not realistically possible with the possible exception of the HumVee. Also wider cars have less roll. in fact Daimler benz got the A class to pass the Elk test by using wider tyres. as far as potholes and speed breakers go the entire suspension has to be considering holisitically. stiffness, independance, cross supports, shock absorbers, and height. From what i have learnt about speed breakers is that there is a LAW dictating the max height and width and H/W ratio and even location of a speed breaker but as is true with everything else there is poor execution of this law. Our traffic dept has great laws. they even have a law governing those large grills you see on tata sumos and toyota quallises. execution is the key.
Old 10th February 2005, 11:32   #22 (permalink)
Team-BHP Moderator
Rehaan's Avatar
The TMC had then stated it would reassess and level all the speedbreakers as per Indian Road Congress standards, which is four inches in height and 3.5 metres in width.
Source
4 inches!! hahaha..wouldnt that be a dream!
cya
R
Old 10th February 2005, 11:35   #23 (permalink)
Red face
______________
_@____^____@_
Skamb, I am getting impressed by you everyday all your topics and postings are thought provoking, you got the problem spot on. The wheel-base and ground clearance both come into play when dealing with speed breakers. My friends maruti 800 would glide over speed-breakers that my zen would scrape.
man23ish is offline   Reply With Quote
Old 10th February 2005, 12:28   #24 (permalink)
speedsatya's Avatar
Originally Posted by dceite
whats the problem with raised ride heigt rtech??
i had to increase my ride ht in the rear by using rubber pads as my tire used to touch the body with 2 people on board.
as a result,i have to be more careful on turns as the car does tend to oversteer.
same with the corolla
speedsatya is offline   Reply With Quote
Old 10th February 2005, 12:49   #25 (permalink)
well i would say definately 170mm or more.... espically with the work going on on the highways....
__________________
push it to the limit
sanket12 is offline   Reply With Quote
Old 10th February 2005, 14:08   #26 (permalink)
Rehaan has said it quite rightly that almost in most of the cases it is the differential which is the lowest point of the vehicle that hangs down..and GC alone may not be the only point!
we are discussing speed breakers arent we? one important point to consider is that the load in the vehicle( how many ppl ) and the speed at which you go over the speead breaker may cause the suspension to get activated and the body may dip a bit along with the tyres which may get compressed a bit..this may have something to do with the actual scraping..
Assuming a speed breaker is like this:
A) ^ i.e, 2.5 feet wide in cross section(profile view) and 1.5 feet heigh
b) 4 feet wide in cross section(profile view) and 1.5 feet high
The 4 wheeler which goes over the speed breaker is more prone to scrape its body if it is point A. 2.5 feet wide/1.5 feet high
__________________
When I have a flyswatter in my hand, everything around me looks like a fly.
muni is offline   Reply With Quote
Old 10th February 2005, 18:18   #27 (permalink)
Thanks man23ish, These are my car research queries and you guys are doing great in providing the inputs. Thanks to you all :-)
Old 10th February 2005, 19:44   #28 (permalink)
Are you an automobile engineer doing some research for a PHD??
Old 10th February 2005, 20:35   #29 (permalink)
Deeps's Avatar
Its strange how most people think that its the silencer that scrapes the bumps. But in reality, in mots cases, its the underbody that gets scraped.
Deeps is offline   Reply With Quote
Old 10th February 2005, 20:59   #30 (permalink)
speedsatya's Avatar
Originally Posted by Rehaan
Ok,
cya
R
,hey rehaan ,
that was terrific.ur explanation was spot-on.hehe i always used to wonder about these cars with 130mm Gc do not have problems ,while my zen with 165mm GC scraped everything that is raised along the road.
Thread Tools
Ground Clearance cartech Technical Stuff 20 6th August 2008 17:53
A good used MUV or SUV or Car with high bonnet and good ground clearance vijaypalrana SUVs, MUVs & 4x4s 23 10th June 2008 21:31
Increase ground clearance of Civic & improve mileage vivek_sharma20 Modifications & Accessories 27 15th January 2008 18:35
Increasing ground clearance pathfinder Modifications & Accessories 11 15th December 2006 04:03
NHC ZX - Ground Clearance venkatrx The Indian Car Scene!! 14 18th August 2006 17:25
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
