Old 19th May 2008, 00:32   #16
wolfinstein's Avatar
too late for mine, filled up more than I should I have..now I have a splash corrossion on the battery side.
wolfinstein is offline   Reply With Quote
Old 20th May 2008, 13:18   #17
Thanked: 38 Times
Infractions: 0/1 (5)
Default new battery
Didn't want to start a new thread, hence using this related one...which is the best place to buy battery (exide) for 800 ? Could you please suggest places near to JP ngr (1st/2nd phase)/J'nagar/Kormangla/double road/jc rd/gandhi bazar etc would do.
A.S.S are quoting 4.5k and 5k for maintenance free battery with 4 & 5 yr warranty, I am looking for something around 2.5-3k with 2-3 yrs warranty/gurantee.
Am buying within 2 days.
ownerofazkaban is offline   Reply With Quote
Old 20th May 2008, 22:14   #18
maxj2005's Avatar
Smile Putting Coke to remove corrision
Guys,
I am not sure if you have heard this one whether it is a myth I don’t know.
But has someone tried putting coke to dissolve the corrosion off the battery terminals.I have heard it works.
Last edited by aah78 : 20th May 2008 at 22:57. Reason: Please don't use text tags. Copy-paste from Notepad instead of Word. Thanks!
maxj2005 is offline   Reply With Quote
Old 21st May 2008, 11:02   #19
gd1418's Avatar
Thanked: 656 Times
Never heard about this. All I heard, know and have tried is to put hot water on the terminals to remove the deposits etc.. It works..
Originally Posted by maxj2005 View Post
Guys,
I am not sure if you have heard this one whether it is a myth I donít know.
Replacing Existing Battery with a Cummins Shakti Truck Battery? condor Technical Stuff 14 30th June 2018 18:32
Battery dealer installs 3-wheeler battery in my car!! Now what? Soumyajit9 Technical Stuff 29 19th December 2016 11:06
PICS: SF Sonic Battery Factory. Detailed report on the making of a Car Battery S2!!! Technical Stuff 29 16th April 2016 11:39
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
