Old 28th April 2008, 13:56   #1
Default Screeching noise from tyres/wheels
Hello Friends,
While driving my SWIFT,I have noticed a strange screeching noise from the wheels/tyres (like they show in movies).The noise is heard usually when I am turning my car into my society internal roads,taking a uturn on roads and while I am taking it off on first gear on a not so good surface road.
This has started about a month back.Till this time there was no such sound.
I am slightly worried.Please let me know what may be the possible causes of this and what action should I take.
raja748 is offline   Reply With Quote
Old 28th April 2008, 14:18   #2
iraghava's Avatar
Thanked: 156 Times
Raja - From your description I gather this only happens on the interior roads of your colony & not out on the normal roads, right??
If that is the case, there is no problem with the tyres, it's just that some surfaces make the tyres emit that sound sue to their construction. (I don't have the technical details on this) And this is nothing to be worried about.
Old 28th April 2008, 14:23   #3
It also happens on the main roads when I am taking an u-turn or turning my vehicle.
Old 28th April 2008, 15:09   #4
Have you upgraded your tyres? If so what is the size? This will atleast help the experts out here to rule out any tyre fouling with the wheel wells or so.
Bala_R is offline   Reply With Quote
Old 28th April 2008, 15:32   #5
Originally Posted by raja748 View Post
i understand that this problem occurs when you are taking sharp/u turns . in that case, just get it checked if your tyres are rubbing against the mud flap or any other part within the wheel arch.
harsha.cs1 is offline   Reply With Quote
Old 28th April 2008, 16:21   #6
No.I have not upgraded the tyres.I am using stock ones.
Old 28th April 2008, 16:53   #7
vinit.merchant's Avatar
Thanked: 939 Times
Wheel Alignment should do the trick. It is usually required every 6 months when the roads on which the car is usually driven aren't good.
vinit.merchant is online now   Reply With Quote
Old 28th April 2008, 16:54   #8
Jaggu's Avatar
Thanked: 8,686 Times
a) yup some times the squealing sound can come due to the surface, esp concrete inside malls etc.
b) what kind of speed do you take turns? stock tyres can squeal at slightest provocation.
c) check wheel alignment, have seen this helping to get rid off some squeals.
Old 28th April 2008, 16:54   #9
Thanked: 939 Times
It costs Rs. 1000 max.
Old 28th April 2008, 17:07   #10
rajshenoy's Avatar
Thanked: 762 Times
I think this is common to all swifts.. i usually notice it while climbing in my office parking(multi floor)
what i feel is, when a new tire moves on a smooth surface this sound comes..but not sure why only when it moves in u turn or a loop
JK tires perhaps ?
rajshenoy is offline   Reply With Quote
Old 28th April 2008, 20:56   #11
kkdelhi's Avatar
Thanked: 15 Times
U-turns & noise? Are you sure the sound is coming from the tyres and not from another part of the vehicle? It could be the suspension, or (God forbid) the axle. Did your swift run over a deep pothole at high speed a month ago?
Either way, better go show it at the Maruti workshop, they'll sort it out.
kkdelhi is offline   Reply With Quote
Old 28th April 2008, 21:04   #12
Jaggu's Avatar
@vinit: are you referring to wheel alignment for Rs 1000? No way, it will max cost 200 to 250 bucks. Even if balancing is also done along with it will come to some 800 bucks.
Old 29th April 2008, 11:45   #13
DieselFan's Avatar
Thanked: 234 Times
800 is on much higher side Jaggu. Wheel alignment and balancing should not cost more than 450-500 rs. 250 for alignment and 200-250 for balancing (Based on weights used (Alloys are expensive) and if all the 5 tyres are balanced or not).
DieselFan is offline   Reply With Quote
Old 29th April 2008, 11:49   #14
wanderernomad's Avatar
Thanked: 806 Times
Get wheel allignment done. The problem is there with my Indigo Marina too and I'll be getting the allignment done one of these days. Not a serius issue at all.
wanderernomad is offline   Reply With Quote
Old 30th April 2008, 06:56   #15
Shashank.A's Avatar
Rs 100-200 for alignment and Balancing depends on the weights used..it also depends on the car..
My vendor, charges 100 for Esteem, and 150 for OHC.
Shashank.A is offline   Reply With Quote
Brake Pads "cheen-cheen" Screeching Sound While Braking vebmetal Technical Stuff 74 16th February 2013 07:26
My screeching Alto Vivekphadnis Technical Stuff 26 25th January 2011 13:01
Screeching Noise in my Palio GTX Radnam Technical Stuff 13 11th August 2010 10:04
Indica Turbo --Screeching sound while starting?? werfish Technical Stuff 8 4th March 2007 14:18
screeching sound from the rear while going over bumps... amitverma Technical Stuff 16 30th August 2005 14:29
