| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Nov 2007 Location: Mumbai
| Dear Team-bhp members, Its my '95 premier padmini S1 yet again with some trouble. This time with its front suspension. Got the front suspension overhauled a couple of months back. Replacement included wornout bushes, front wheel bearings & trouble maker coil spring. The coil spring was replaced as the springs had done their due for over 12 yrs & 59K kms. As I went for parts shopping I picked up a coil spring too. Told the shopkeeper that needed a coil spring for an 95 model S1. My mechanic too nodded his head and gave his approval. Finally, when fitted walla, my car got turned into an SUV with the front high enough to climb in. My mechanics version it will level out in time. For the final test took it to a friend also a team-bhp member, wont take his name as his work takes 48 hrs out of a day. Wont burden him much. His take was as expected it changed the entire front suspension geometry, and replace it soon. Went back to the shop keeper asked him about the spring, he had given me the springs for Premier Padmini Diesel !!! as per him Petrol S1 & diesel have the same springs. Got regular fiat springs now the ride height increased, & suspension bouncy, going over 60 km/hr meant galloping. Changed springs again. The dictat told by friend, ' If it is not original they will simply not work '. Told my mechanic to get a second hand original springs, hes got them but the ride height is seriously compromised and the car stands just as it was pre overhaul. Wondering what do I do, as the springs were made inhouse by PAL and the company has closed down & demolished. Last week drove through the site, nothing but a couple of sheds and a power house left. Would need advice and a source for a couple of Original Coil springs if possible. |
| | #3 (permalink) |
| Distinguished - BHPian ![]() | New springs need a few weeks to properly set in place. It looks odd. It rides bouncy. Depending on your wheel alignment, it could be handling crazily as well. On top of it, the rear leaf's being carried over. So giving that drop back look. Would advice contacting BEHRAM.DHABHAR, it will transform you.
__________________ ________________________ Every Ferrari is always a Fiat |
| | #4 (permalink) | |
| Quote:
@1100D- I have taken your advice before you told me. Which other friend has work occupying him for 48 hrs a day. Furthermore, does the high spring settle in a couple of weeks ? | |
| | #5 (permalink) | |
| Quote:
![]() @1100D- I have taken your advice of contacting Behram, before you telling me. ![]() Which other friend you think im telling has his work keeping him busy for 48 hrs a day ? No offence meant. | |
| | #6 (permalink) |
| BHPian | The most wornout spiders (original suspension kit in all fiats) is a lac times better than a new duplicate. Unfortunatly you learnt it the hard way. Never replace original parts unless it is inviable Hence I always consult our common 'friend' (infact even pester his at times) before even touching the cars mechanical parts. Keep this in mind and you'll never ever have any trouble with troubleshooting your car. Regards, Adheesh Parelkar |
| | #7 (permalink) | |
| Quote:
| | #8 (permalink) |
| BHPian | Kavesh - you wont get original/new coil spring unless they are NOS with a fiat spare parts dealer. i did my car's suspension overhaul in Dec '06 and the coils were not changed. i hope your mechanic used the correct suspension bushes - VIR. can you upload a side profile pic of your car?
__________________ Planet, Sonja, ETC - "Elements of Life" Last edited by planet_rocker : 30th April 2008 at 16:53. |
| | #9 (permalink) | |
| Quote:
will upload images shortly. | |
| | #10 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Drive around for a couple of weeks, to settle the front suspension.
__________________ ________________________ Every Ferrari is always a Fiat | |
| | #11 (permalink) | |
| Quote:
| Thread Tools | |
Similar Threads | ||||
| Used Maruti800, premier padmini , premier 118ne ? | sakharamcool | Hatchbacks | 8 | 27th May 2008 11:17 |
| Lowering suspension(ground clearance or ride height) for the SX4 | dharmana | Modifications & Accessories | 27 | 29th April 2008 22:34 |
| Modifying a Premier Padmini | NOS Power | Modifications & Accessories | 8 | 13th January 2008 16:55 |
| Need a Premier Padmini S1 | kavesh55 | Shifting gears | 0 | 27th December 2007 13:48 |
