| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Feb 2004 Location: New Delhi
| We have an Innova G3 and does a lot of highway driving where we have encountered under-carriage scraping over bumps and minimal bad roads. we want to raise the ride height using 20/25 mm aluminium spacers (had done the same successfully on a Fiat Uno). The Innova is a far more complex vehicle and would like to know if the steering/suspension geometry will be affected by this procedure. any suggestions guys ? Hatari |
| | #4 (permalink) | |
| Senior - BHPian | Quote: IMO adding spacers would seriously affect the handling and stability and that is not something you wanna do to a car that is used alot on highways. | |
| | #5 (permalink) |
| Super-Admin | Hatari, have you encountered this problem since the car was new or has it cropped up only recently? Your post indicates extensive highway use and loading, so it could be that the suspension is worn out / sagging. Maybe an overhaul is the solution here? I don't recommend spacers at all. It can potentially ruin the onroad behaviour.
__________________ GTO Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
| | #6 (permalink) | |
| Quote:
the spacers worked very well on the Uno and just want to add 1 inch spacers.. | |
| | #7 (permalink) |
| Super-Admin | If larger wheels / tyres fit without scraping, that may be an option to consider. You can easily get some mm of ground clearance with bigger rubber. EDIT : You could also consider the options listed in this thread.
| Thread Tools | |
Similar Threads | ||||
| Suspension and engine Mods for Alto LX! | speedzak | Modifications & Accessories | 128 | 18th July 2008 15:46 |
| mods and performance mods for unicorn please give your views | rider60 | Motorbikes | 101 | 25th March 2008 19:04 |
| Gwalior To Nagpur - Via Bhopal. Is it doable in a day? | Zappo | Route / Travel Queries | 5 | 8th October 2007 11:14 |
| Mods for Innova 2005(petrol, VVTi) | Mr.Bangalore | Modifications & Accessories | 4 | 8th February 2007 15:32 |
| Suspension Mods for Gypsy | MexXxentric | Modifications & Accessories | 8 | 23rd August 2006 14:47 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
