Old 30th April 2008, 13:11   #31
Sam Kapasi's Avatar
Thanked: 1,473 Times
Originally Posted by adityamunshi View Post
Sam, is this true ?? Difficult to believe !!
CD head unit
6.5" components 1 set in the front
6X9 1 pair in the rear
1 Pre boxed high power 12" subwoofer
1 MonoBlock amp
1 4 channel amplifier
Just the normal crap lol
Old 30th April 2008, 13:19   #32
Thanked: 294 Times
It is a ideal setup for a normal ICE car.
Old 30th April 2008, 13:22   #33
theexister's Avatar
Sorry for the OT but does having the reading lamps turned on for one whole night drain the battery enough to cause it to under perform?
I mean could this lead to an early slow drain out?!
theexister is offline   Reply With Quote
Old 30th April 2008, 13:34   #34
flipsyde's Avatar
Thanked: 62 Times
Originally Posted by nitrous View Post
The Safari's OE battery is Amaron.
But, mysteriously it comes with only 1 year warranty.
Makes me think they give inferior batteries for OE.
isnt this true for all branded stuff?? computers for instance?? normally your hard drive would carry a 5 yr warranty and most of the remaining components 3 yrs. but the manufacturer (HP, DELL, Compaq.....) all give only one year warranty..... its strange but i guess thats the way it works!
flipsyde is online now   Reply With Quote
Old 30th April 2008, 15:50   #35
DieselFan's Avatar
Thanked: 234 Times
CD head unit
1 MonoBlock amp
With so much of heavy weight ICE any battery will fail
DieselFan is offline   Reply With Quote
Old 30th April 2008, 16:36   #36
JayD's Avatar
Thanked: 2,008 Times
That was a joke right?? If not LBM would be be running a generator inside his car to keep its batt charged!
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
Help : Viva crdi or Verna crdi nitindangoria Sedans 15 10th March 2009 22:50
Verna CRDi or i30 CRDi ? Gangsta Sedans 16 12th July 2008 20:41
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
Swift DDiS vs. Getz CRDi or Verna CRDi??? Help!!!! roadwarrior Test-Drives & Initial Ownership Reports 12 12th February 2008 23:59
