| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Nov 2007 Location: Gurgaon
| Hi Guys I puchased a Hyundai i10 in Feb. '08. For the first 1 month it drove very well. Since the last month after the its first service, it has developed a wierd thud and rooling sound in the front wheels whenever it encounters bad roads. It took it to Safdarjung Hyundai in Gurgaon, the service agent told me that its because of loose caliper pins in the front right wheel. He took the car for a day and told me in the evening that the repair has been done. When I drove the car after that everything seems fine. After around 3-4 days the sound came back, I again went to the service station and found that the agent has resigned . Another agent looked into my complaint and told me the same thing, he also took the car for a day and in the evening told me that the problem is with the caliper pins. He then told me that he has got the repair done again but if the sound continues he would replace the caliper assembly. Again the car drove well in the intitial 3-4 days, after that the sound is back. I still have to go back to the showroom for the repairs/ replacement. I do not understand how can such a problem develop a new car keeping in view that this kind of a problem if found only after much wear and tear in the car. Since this is my first car, I am not sure how to inform Hyundai about this issue. Any suggestions?
__________________ Good Guys Get Good Goals |
| | #2 (permalink) |
| Distinguished - BHPian ![]() | Can't diagnose the actual problem like this but since your car is new I suggest you visit Hyundai Motor Plaza on Mathura road near Haldiram's. They are a Company Owned-Company Operated dealership & they would be able to solve this problem better than the other dealers. Also, when you go carry the Job cards of the last two times when this repair was carried out at Safdarjung Hyundai.
__________________ There is a very fine line between "Hobby" and "Mental Illness". |
| | #5 (permalink) |
| BHPian | dont worry man. this problem occurs when there is play in the pins and lack of greasing. this happens with me too. ask the service station person to replace the pins in front of you. also there is one rubber cover which covers the grease when put inside. the grease shouldnt leak from it. get those replaced too. this noise comes mainly on cement roads and bad roads.
__________________ " I dont Drive Fast , I Fly Slowly " |
| | #6 (permalink) |
| Thanks guys for all your suggestions. Amit, this sound goes whenever I put my foot on the brake padel slightly. I will visit the service station again on this saturday and will do as you guys have suggested. Will update the thread accordingly.
| | #7 (permalink) |
| BHPian | that is obvious,when u press the brake pedal the calipers actuate over the pins and grip the pins. so no noise will come. dont worry its a very minor issue. i have faced this many times. just remember. ask him to open the brake calipers in front of you. fill in lots of grease and put the rubber cover over it so that it doesnt drip out again easily.
| | #8 (permalink) |
| Finally Safdarjung Hyundai has informed me that Caliper pins are not available as a spare part and they will replace the full Caliper assembly on both the front wheels. Now I m not sure if I just give the car away to them to replace the caliper assembly or be present there when they do the job, m not sure if they would allow me to be present in the service bay....
| | #9 (permalink) |
| Senior - BHPian Join Date: May 2007 Location: Vadodara
| I am not sure wheather they will allow you in service bay. Hope that this solves your problem. However, was the braking performance affected ?
__________________ EVENTUALLY FATE DECIDES EVERYTHING. |
| | #12 (permalink) | |
| Super-Admin | Quote:
Insurance regulations prohibit you from being present in the service area. You needn't worry. Just drop the car off.
__________________ GTO Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
| | #13 (permalink) |
| Newbie Join Date: Jan 2008 Location: Bangalore
| Hey I also had a similar issue and informed the service guys in the time of service, they said Hyundai has already addressed the issue and its because of the caliper pin and they did replace it..but still while going through bumpy roads i feel a thud in the steering wheel. I think i should go back again!!!! ![]() |
« Fuel siphon not possible in Elantra /NHC
5th Gear Slip at speeds higher than 120 - Palio 1.6 Gtx »
| Thread Tools | |
Similar Threads | ||||
| Hyundai i10 diesel | sajands | The Indian Car Scene!! | 94 | 2nd July 2008 12:55 |
| Severe Gear problem in i10 | amitjinds | Technical Stuff | 22 | 6th May 2008 19:18 |
| Is the Hyundai I10 VFM ? | khuz1979 | Hatchbacks | 14 | 20th November 2007 08:48 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
