Thread Tools
Old 12th May 2008, 09:22   #16 (permalink)
joe_mclaren's Avatar
Thumbs up
Originally Posted by Jr Godzilla View Post
could be a clogged orifice / expansion valve, if yes change it and would be good to flush for any dirt, metal which could screw up the compressor, vaccum refil gas. Also make sure to change the drier.
if its orifice its a tedious job to get under the dash for access to evaporator to get to orfice.
thanks Jr, ill make sure these things are taken care when im giving it for service
joe_mclaren is offline   Reply With Quote
Old 12th May 2008, 09:26   #17 (permalink)
Unhappy
Originally Posted by Gangsta View Post
Go for the AC service for your car and tuning. I'm not sure about Esteem's AC but in Accent if idle rpm goes below 600 then my AC Compressor will just trips off.
You need to checkout your thermostat too. It may cause such problems.
gangsta now since uve mentioned abt the RPM, i have a strange behavior there too
in fact when i start the car, its revs to 1.5K RPM and stays there throughout.
I restart the car and it comes back to 800~ RPM
Another behavior is that while driving when i press the clutch(de-clutch right?)
it revs from 800 -1.5K and back continously.
again on restart things are normal.
Old 12th May 2008, 11:02   #18 (permalink)
achopraa's Avatar
By the way, for which car you had been to Samara?
I was there for servcing of my i10.
__________________
Main Aa Gaya....Main Chaa Gaya....
achopraa is offline   Reply With Quote
Old 12th May 2008, 13:34   #19 (permalink)
Gangsta's Avatar
It happen always or whenyou start the car for the first time in the day. Because engine is cold wait for few min till the engine gets optimum heat. Make sure your throttlebody and injectors of the car is cleaned properly. Also, go for the high scan for the Oxygen Sensor in your car.
__________________
Respect The Man's Car and the Man will respect You.
Hyundai Elantra CRDi
Hyundai Accent 1.6L GLS
Maruti Suzuki Wagon R
Maruti 800
Gangsta is offline   Reply With Quote
Old 12th May 2008, 14:00   #20 (permalink)
High scan for Oxygen sensor???
More light on this please
Old 12th May 2008, 15:10   #21 (permalink)
Gangsta's Avatar
We don't have a scanning for Oxygen Sensor?
A Graphical Scanning will show if the oxygen sensor is working properly or not.
__________________
Maruti 800
Old 24th May 2008, 13:37   #22 (permalink)
hi guys
updates on my AC
gave it for servicing.. he cleaned the AC system, refilled the gas and then i took it for a ride . the cooling is awesome now, chills in seconds
but after 2 days the same problem seems to persist, cooling stops randomly.
Now the problem he says seems to be with the thermistor valve and needs to be replaced. The reason being that coolant circulation is not happening, which in turn stops the AC.
Took it to my local workshop to remove the thermistor valve, but he says that a valve was bent, which stopped circulation and so he straightened that.. after 2 days back comes our problem. Took it back to the local workshop and he confirms the issue by saying that the AC sensor which cuts-off the cooling is problematic.
now showed it to another AC workshop, he checks and tells me that the AC system is still blocked because the compressor is working all the time but there is no cooling
He says that the whole system needs to be checked
I told him about the sensor, but he says that if the sensor was problematic, then the AC would work full time and would never cut-off.
Man am i confused
Old 26th May 2008, 00:01   #23 (permalink)
Gangsta's Avatar
hi guys
updates on my AC
Man am i confused
see as far as the sensor is concerned. If oxygen sensor, then it will be a problem if car is in idle form. like your rpm going up and down.
Thermostat can be the problem... But beware i don't trust local guys now unless i know him personally.
By the way what's rpm of your car at idle and which car your own bro.?
__________________
Maruti 800
Old 26th May 2008, 07:35   #24 (permalink)
an esteem vx2001 model MPFI
800 rpm when idle
Old 26th May 2008, 10:01   #25 (permalink)
wolfinstein's Avatar
The Underpower problem should be rectified with adjustment to the flow of Gas in the Intake, In summers the Gas Expands leading to more inflow by volume,making the mix Rich.-coupled along with Dry Hot air from the Air Intake.
Simple adjustement to decrease the flow of gas would help,at the same time I suggest please get the Air filter and Spark plugs cleaned and adjusted.
Although a Lamda controller is self adjusting, One visit to retune the controller using the installer OBD would help.
Ideally My car is adjusted well enough to partake the weather differential.
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 29th May 2008, 10:45   #26 (permalink)
The continous revving and the high rev while starting the car is not observed after replacing my battery from Exide to Amaron 42B20R. Looks good now.
Back to my AC problem though..yet to be taken to the AC guy
Old 13th August 2008, 14:33   #27 (permalink)
A/C compressor busted completely.. the pistons are bend and the shaft has alll been scrapped..
So I got another compressor immediately, since they said the belt runs both A/C and power steering together...
Spending nearly 15K for compressor , drier and filter.
Old 13th August 2008, 16:44   #28 (permalink)
Gangsta's Avatar
Oh damn sorry to hear that, havnt ya checked up your ac in previous days?
__________________
Maruti 800
Thread Tools
Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? mclaren1885 Modifications & Accessories 50 26th March 2008 10:55
Indica V2 DLS - Engine overheating/AC issues ajaysurfs Technical Stuff 6 22nd March 2007 20:37
Help ... Need High Output Alternator TOO MUCH LOAD low_bass_makker Ask the Gurus 44 14th March 2006 09:14
High engine Noise subbarao Technical Stuff 3 3rd March 2006 12:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
