| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Mar 2007 Location: Bangalore
| Folks, I am facing sudden loss of power in power steering when I am slowing in 4th gear and I press the clutch to down shift. This loss of power though is just for a fraction of a second. 1. Is there a major issue? 2. Have any of you faced similar problems? 3. What is the best way to inform the service adviser of this issue? (I am nearing my 4th service schedule and would like to get this highlighted to the service adviser ). Your advise is much appreciated.
__________________ If you have not failed you have not tried enough. Swift Diesel VDI - Feb '07 onwards Santro LS- Mar '01-Feb '07(59000 KM) Sold. |
| | #2 (permalink) |
| BHPian | oh oh oh... One more "The Reliable" Swift with an issue. DieselFan, If I am right, all Maruti;s come with EPS and not hydraulic PS. In that case there should be no direct link between the engine;s power and the Steering (as would be the case in the Brake system). This may mean some issue with the EPS system, electricals, electronics, etc etc. Give some more description of your car and its history includings Tyre Mods, rims mods, accidents (if any), rough/good roads usage.
__________________ Dont wear Helmets & Seatbelts to reach Heaven Faster You hardly have any time left in this world to be a sinner |
| | #3 (permalink) |
| Yes Swift d comes with a EPS. No Mods done on the car. The car did have a ECU issue initially which maruti replaced. This was an year back. No accidents. Road usage is on good roads and mostly highways (an FE of >20 kmpl is evidence to this ).
| | #5 (permalink) |
| BHPian | have not had that happen in any of our EPS cars 3 from maruti, 1 from hyundai. what happens when you say you lose power steering? does the steering go completely rigid and become almost impossible to turn, like when you switch off the engine?
__________________ Dieselhead DDiS - 19k CRDi VGT- 20k |
| | #6 (permalink) | |
| Quote:
Yes the steering goes rigid for a fraction of a second and then I get it back.
__________________ If you have not failed you have not tried enough. Swift Diesel VDI - Feb '07 onwards Santro LS- Mar '01-Feb '07(59000 KM) Sold. | |
| | #8 (permalink) |
| Kuttapan, Nothing wrong with the fuse. EPS works fine all the while except once in a while it freezes for a fraction of a second. I was not able to simulate the condition to Maruti hence was not corrected during my service. It happens very infrequently (Once in a fortnight. Now even less) and only for a fraction of a second.
| | #9 (permalink) |
| BHPian Join Date: Feb 2008 Location: Pune
| this had happened to me twice while driving but both these times my engine had turned off and this issue had occured... may be because of bad clutch timing by me... So as far as i know if there is some power loss in between to the EPS in the form of your engine shutting down suddenly etc then it happens....
__________________ _________________________ Swift DDIS ABS Silky Silver__ Achtung Baby__ |
| | #10 (permalink) | |
| Quote:
Yes that is the standard case. In my scenario engine doesn't shut down but the power steering doesn't function for a fraction of a second. Most of the time I faced this issue was when I had depressed the clutch and was about to go to a lower gear.
| Thread Tools | |
Similar Threads | ||||
| Swift VDI or Getz GLX-6L Budget EDIT: Bought VDI | agm | Hatchbacks | 29 | 11th April 2008 22:56 |
| Electric Power Steering Vs. Hydraulic Power Steering | joseph5600 | Technical Stuff | 3 | 19th November 2007 19:56 |
| Maruti Esteem - Non Power Steering to Power Steering | udit78 | Modifications & Accessories | 9 | 1st October 2007 16:27 |
| Zen Steering Issue | amtak | Technical Stuff | 8 | 6th August 2007 19:40 |
| Please suggest - power windows, power steering from one Esteem to another | pramodkumar | Technical Stuff | 4 | 1st September 2006 09:19 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
