| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Mar 2004 Location: Ludhiana
| Car:- 07 Alto LXi Mileage:- 15k kms Just noticed when I took out car to highway this weekend. Constant knocking whenever accelerator is depressed. Especially after 80. Had to continue by journey at 60-70 till I reached my destination. Car doesnt knock much when not fully warmed up. But starts doing it after a few kilometres. Will knock in 1st gear also on sudden acceleration. Sometime if you pump the throttle hard while engine is idling, you will feel a faint knock sometimes. Car was serviced one month ago. Injectors were cleaned. I always use IOC xtra premium 91octane. Tanked up before this drive. Fuel Pump is the same from where I always fill. Any possible causes? P.S.>> When I drive alone, knocking is reduced. But goes up to alarming levels when friends/family travelling alongwith.
__________________ Punjabi for Life. |
| | #2 (permalink) | |
| Senior - BHPian Join Date: Sep 2005 Location: In the Hood Near You
| Quote:
I could be wrong here but this is what i have observed personally.
__________________ For every idiot there is an equal and opposite gender idiot. Singles are people with incomparable intelligence! | |
| | #3 (permalink) |
| Senior - BHPian | The knocking is not related with Xtra Premium. I'm using Xtra Premium for the last 40,000 KMS on my Alto. The drive is silky smooth. Change the pump from where you're filling.
__________________ Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly. |
| | #4 (permalink) |
| Why not premium fuels? What's wrong with them. My Karizma, almost refuses to run on anything less than 91octane. My earlier 800 also felt better on this fuel. Anyways, the pump is one of the most reputed one here. Still, I'll try changing as soon as this tank finishes. So fuel is the culprit then? (Seems a bit unlikely though seeing the reputation of the pump...)
| | #5 (permalink) |
| Team-BHP Moderator ![]() | check the timing if Fuel is not the culprit. This is the most common cause. And get fuel filled from the IOC on ferozpur road just after the Canal bridge(Opposite Verka)
__________________ .--- ..- ... - - .-- --- -- --- .-. . -.. .- -.-- ... - --- --. --- !! |
| | #7 (permalink) |
| @ TSK - Yes. Same petrol pump. How come timing? The base plate needs to be rotated too to adjust timing in a fuel injected car? @ Srijit- Details please. How come "retuned" ? I dont think there is an option to play around with maps or stuff, neither do I see any wide band O2 sensor with them....
| | #11 (permalink) |
| Newbie Join Date: Jun 2006 Location: Bangalore
| I think it is Premium Petrol which is the reason for this knocking. Earlier, sulphur was added as an additive to induce anti knocking properties. With the advent of Green marketing, the same additive is considered as an impurity and premium gasolenes take this out of Gasolene. Reduction of knocking is done by car makers. I do not know whether alto manual prescribes Premium Gasolene. Check this aspect. This knocking is not heard in cities and are heard only on Highways because of ambient noise in the city. Sukhesh Kumar BR |
| | #12 (permalink) | |
| Senior - BHPian | Quote:
Edit: The knocking could also be due to some blockage in the fuel supply,and the car may be running a lean mixture. Check fuel filter, fuel pump, fuel lines and injectors in addition to the ignition timing. Fuel quality could also be the culprit, as pointed out by others. Last edited by rks : 1st May 2008 at 17:12. | |
| | #13 (permalink) | |
| BHPian Join Date: Jan 2008 Location: Trivandrum
| Quote:
Or maybe, he mentioned timing, which I misheard/mistook for tuning.The info from the service bill (free) is:
These were the things they did, and it reduced the knocking. I use only Premium petrol, so that doesnt come into play yet. Alto has run about 15,000 Kms in 2 years. Hope this helps ![]() | |
| | #14 (permalink) | |
| Quote:
Not sure about the EGR too. Will check and get back to you. Thanks guys. I think I'll observe this tank of fuel to see. Currently very VERY frustrated. Put in regular 87octane to check if what difference it makes to my Bike. It's refusing to accept anything more than 30% throttle without knocking. ![]() Extremely pissed off right now. Car is knocking after refill. Bike is knocking after filling regular 87octane from the other most reputed pump in town.. Scooter is grounded because I forgot to renew insurance on that. Damn!!!!!
__________________ Punjabi for Life. | |
| | #15 (permalink) |
| BHPian | get your valve tappet clearances checked. secondly ask them to check the settings of ECU by using tech2. thirdly ask them to check the timing in front of you. they will show you a white flashing light which has to match perfectly with the marking near the pulley of the alternator. at the last one sincere advice. stop using premium fuel for low compression engine like alto. i have suffered a lot due to this which i have discussed in other threads. stick to normal unleaded fuel only from a good reputed fuel station.
__________________ " I dont Drive Fast , I Fly Slowly " |
| Thread Tools | |
Similar Threads | ||||
| Knocking Sound in Santro | Vys De BlUR | Technical Stuff | 0 | 5th March 2008 17:38 |
| Knocking in Baleno | mariaprabhu | Technical Stuff | 10 | 23rd May 2007 14:49 |
| Vtec knocking - | chetanhanda | Technical Stuff | 8 | 23rd October 2006 23:57 |
| Synchromesh / Constant Mesh - What is the basic difference | esteem_lover | Technical Stuff | 9 | 28th August 2006 23:00 |
| Knocking | SLK | Technical Stuff | 18 | 2nd June 2004 13:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
