Old 5th May 2008, 23:19   #31
nitroxx's Avatar
Thanked: 26 Times
This is where a new era of racing performance begins, I'm stacking up on barrels of this stuff for the speed run..And I'm gonna throw them on the other track before I line up..LOL!
nitroxx is offline   Reply With Quote
Old 5th May 2008, 23:35   #32
Awaiting Email Confirmation
Thanked: 319 Times
Default The contents of Wd40
WD-40 - Wikipedia, the free encyclopedia
Formulation
Main ingredients, from the material safety data sheet, are:
drpullockaran is offline   Reply With Quote
Old 6th May 2008, 09:02   #33
Rehaan's Avatar
Thanked: 25,042 Times
Note from Mod :
Guys, lets please get back to the topic without letting fantasies run too wild.
Thanks,
R
Old 29th July 2011, 02:03   #34
Chewbacca's Avatar
Thanked: 121 Times
Default Re: WD 40 = Performance Increase?
WD 40 is available in any hardware shop.
If bolts are jammed then spray it on the thread (if possible) and leave it wet for couple of hours before trying to unscrew it. Another method is to tap it lightly with a hammer, then spray again. Do it couple of times. Also try heating it with a hair dryer.
Chewbacca is offline   Reply With Quote
Old 29th July 2011, 03:05   #35
kailashnj's Avatar
Thanked: 281 Times
Chewbacca thats a very old thread that you have restarted. hope by now the thread starter might have already realised this.
kailashnj is offline   Reply With Quote
Old 30th July 2011, 02:10   #36
Chewbacca's Avatar
Thanked: 121 Times
Someone else did, not me.
There was a query here yesterday from a CBZ owner who couldn't find WD-40 anywhere in Delhi. Somehow that post has vanished, maybe the mods can explain.
Old 22nd November 2011, 11:30   #37
Thanked: 237 Times
I used WD-40 for my dead firewire port in PC. It started working. Firewire port was giving problems due to rust and dust. All USB ports, SATA cables work properly when they get a wash of WD-40.
My cars seat was squeaking previously but spray fixed it. Same goes with Bonnet as well.
It is really useful spray. It was hard to find it in Pune hardware shop but I found it in my hometown and it is available in every hardware shop in my small town.
Here is the link for usage of it in automobiles Chip Foose Hot Rods & Collectable Cars | WD-40 SEMA Cares Project
1) Lubricates Moving Parts and protect them too. Can be used on Suspension and other moving parts
2) Useful for getting shining black tires and for shiny metal parts
3) Of course for removing bolts and nuts
4) Can be used for cleaning Dashboard, upholstery too
5) If sprayed on engine or other parts removes rust, grease marks and protects them further.
From http://www.wd40.com/news/in-the-news...h-wd-40andreg/
WD-40, which works wonders as a lubricant, is also a multi-purpose cleaner, penetrant, moisture displacer and rust preventative. The product has been reported by many consumers to be a great product to keep a car clean, both inside and out. It's effective in removing tar, mud and other deposits from chrome and painted surfaces without harming the finish.
WD-40 also works great on a car’s grill to remove or prevent build-up of splattered bugs and grime. It will even remove old bumper stickers with ease. A spray of WD-40 on the hood or roof and a rinse with soapy water will also remove tree sap or bird droppings.
WD-40 also works well in the car's interior. If the upholstery or carpet has been soiled with crayon or greasy fingerprints, a spray of WD-40 on the affected area and a gentle rubbing with a cloth can remove the stain. It is also used to remove gum stuck in carpeting or between seats. It is suggested to wash with soap and water after removal.
So skip the expensive car care products for now and take care of many car cleaning needs with this one versatile product that is probably already somewhere around the house.
And while cleaning the car, other needs such as lubricating hinges, stopping annoying squeaks and freeing a stuck antenna can be handled with WD-40 as well.
sushantr5 is offline   Reply With Quote
How does unichip increase performance? Midi_Amp Modifications & Accessories 56 14th November 2010 20:01
76mm Honda performance pistons, baleno performance cam & NOS kit for sale. mclaren1885 Shifting gears 6 16th September 2007 14:02
Does a stinger / chamber increase performance? rankoz350 Motorbikes 18 8th March 2006 07:27
Does a TC increase the CC of an engine? Shan2nu Technical Stuff 8 20th October 2004 03:40
Increase Speedometer Reading abdriver2000 Motorbikes 13 11th October 2004 13:30
