Old 28th September 2009, 20:11   #136
R2D2's Avatar
Thanked: 1,249 Times
Originally Posted by MuzzledMoose View Post
Mine is a 12V 60AH battery. Forgot the model number though.
It's an Exide Matrix DIN60.
Rgds,
Old 29th September 2009, 01:06   #137
Raccoon's Avatar
Thanked: 105 Times
Actually only the Matrix is a bit pricey. That's coz it's the only batt other than the Tata Green using Calcium doped +ve and -ve plates. Other low maintenance batts have calcium only on +ve OR -ve but not both. The only other mfr to offer this type of batt is Tata Green. They call them green batts coz they're supposed to last about 1 lakh Kms which would translate about 5-10 years of use for a majority of car owners which in turn saves the environment by reducing the frequency of batt replacements.
Rgds,
Hmm... ok. Would be interesting to know how long these green batteries perform in real. If they really do last 10 years, then you gotta stop thinking of batteries as consumables... they would last almost till the time a lot of people keep their cars.
But I dont see how they are considering their life in terms of kilometers. Batt life is more time dependent rather than how many kms you have done on the odo. That is of course if the battery does not encounter adverse conditions while in working service.
Old 29th September 2009, 09:09   #138
R2D2's Avatar
If you ask me Tata Green's 1 lakh Kms claim is only a marketing gimmick. It has no basis in fact (or science) but only via assumptions.
And yes, as you correctly said, if batts lasted 10 years you could definitely stop thinking of them as consumables. V few folks retain their cars more than 10 years. Will I consider a TG for a batt replacement? No, not just yet. Let the brand prove itself.
Rgds,
Old 29th September 2009, 11:37   #139
MuzzledMoose's Avatar
Thanked: 28 Times
Hmm either way the old day maintenance type batteries last for more than 5 years if maintained properly. But that needs religious checking of water level every fortnight. I had a 12v 5AH battery in my KB100 that lasted for 5 years!!!
MuzzledMoose is offline   Reply With Quote
Old 29th September 2009, 14:50   #140
Raccoon's Avatar
Thanked: 105 Times
Rgds,
Not to beat the dead horsie too much, but my logic is that a brand like Exide has consistently "disproved" itself, whereas one like Tata Green is yet to prove itself. So my chances are much better that I get lucky with Tata Green. If forced to choose between the two, I'd go for TG without a second thought.
As I have mentioned earlier, the OEM Amco Yuasa that came with my Shogun lasted 7 years!! The dealer could hardly believe his eyes when the battery was given back to him for exchage! I would once again emphasise - it was "Amco Yusa" and not "Amco". The Amco of today seem to be crap and the stock one in my CBZ-x leaks as shamelessly as Exide and has spoilt its metal bracket, and the swingarm! I have been behind the dealer/HH to take responsibility for this mess created by their substandard batteries. They have agreed to repaint both the things. But I am insisting on replacing the bracket and painting the swingarm. Replacing the swingarm I want to avoid, as I'm pretty sure the baffoons at their service centrer will mess up something or the other and maybe even screw up the alignment and make scratches elsewhere. Lets see what happens.
Based on my experience, I have this feeling that Amcos might be made by Exide... does anybody know better? Amco don't make their own batteries, do they?
Old 29th September 2009, 16:42   #141
It seems they have a manufacturing plant at Bangalore.
Batteries, (AMCO Batteries Ltd., India): TRIM Products Services
janitha is offline   Reply With Quote
Old 29th September 2009, 17:54   #142
Raccoon's Avatar
Thanked: 105 Times
Ya, but that dosen't mean they manufacture them from scratch...
Old 29th September 2009, 19:54   #143
mithun's Avatar
Thanked: 49 Times
Same pinch !
My Crompton Greaves on my old 4S Champion also lasted for 7 years !
Old 29th September 2009, 23:49   #144
Raccoon's Avatar
Thanked: 105 Times
Crompton Greaves had a battery??
Old 3rd October 2009, 07:06   #145
mithun's Avatar
Thanked: 49 Times
Now, they are not having any batteries !
Old 29th December 2009, 17:07   #146
HotChillyPepper's Avatar
Thanked: 215 Times
Just called up BOSCH dealer in JC road and got a quote of 11K for a BOSCH Silver 100AH battery for my Optra Magnum(With old battery exchange). Is this quote reasonable?
HotChillyPepper is offline   Reply With Quote
Old 16th February 2010, 17:43   #147
Thanked: 1,271 Times
Battery in my Indigo (Diesel) conked-off today. Had got it checked recently and the mechanic told that one cell was weak, but the car was cranking in the first go, so thought will run for sometime. The battery is a factory fitted Exide and was going to complete 4 years in early March this year. The car has clocked 62k kms.
Please advise a replacement - am thinking of Amaron or Tata Green. Please someone suggest the real-life prices. The base Tata Green as per website is for Rs.4000-odd (50k kms maintenance free). I feel this is a bit on the higher side - please advise if this indeed is the price range for good batteries in Delhi and what will be the net cost after exchange.
jessie007 is offline   Reply With Quote
Old 16th February 2010, 18:42   #148
whitemm550's Avatar
Thanked: 63 Times
expensive. try Amaron Pitstop
whitemm550 is offline   Reply With Quote
Old 17th February 2010, 11:40   #149
ishotmydog's Avatar
Thanked: 16 Times
the battery on my accent diesel died after 97k Kms, which battery should i look out for?
ishotmydog is offline   Reply With Quote
Old 17th February 2010, 15:13   #150
Raccoon's Avatar
Thanked: 105 Times
^^^Dude, this has been discussed so many times on tbhp. In short, the best brands are - Amaron, Base Terminal/Panasonic, BOSCH.
Bat Mobile - Exide on road Service amtak Technical Stuff 65 23rd April 2017 22:50
Free Jump starts & Battery help - Exide Batmobile, Mumbai (and other cities) GTO Mumbai 36 28th April 2016 23:50
Battery goin dead... again and again... COUGAR 4x4 Vehicles 21 1st August 2009 18:27
A minor but irritating issue after getting a new Exide battery finneyp Technical Stuff 11 13th February 2009 12:48
FS: EXIDE 32Ah Battery shrivz Shifting gears 3 24th July 2008 20:27
