Old 17th February 2010, 16:34   #151
AbdulRahmanM's Avatar
Thanked: 7 Times
I was using EXIDE battery in my Pulsar self-start, the next day when the warranty got over, battery died. I was so surprised to stumble upon this thread to hear many similar stories. And EXIDE provides only 15 months warranty while amaron provides 60 months. So i got an Amaron now for my pulsar.
AbdulRahmanM is offline   Reply With Quote
Old 18th February 2010, 16:20   #152
ishotmydog's Avatar
Thanked: 16 Times
Originally Posted by Raccoon View Post
^^^Dude, this has been discussed so many times on tbhp. In short, the best brands are - Amaron, Base Terminal/Panasonic, BOSCH.
had gone through the threads, thanks though
ishotmydog is offline   Reply With Quote
Old 20th February 2010, 16:39   #153
Thanked: 1,271 Times
Thought I should post this for the benefit of other members. Before I could get a battery, my father got it replaced. The previous one was an Exide O.E. and the new one is Standard Furukawa Sonic Jumbo JMB700 with 18 months free replacement warranty. The battery is rated 65 Ah battery and the cost was Rs.3500. I believe the O.E. battery was 60 Ah - not sure - if someone could corroborate??
Originally Posted by jessie007 View Post
Battery in my Indigo (Diesel) conked-off today. Had got it checked recently and the mechanic told that one cell was weak, but the car was cranking in the first go, so thought will run for sometime. The battery is a factory fitted Exide and was going to complete 4 years in early March this year. The car has clocked 62k kms.
Please advise a replacement - am thinking of Amaron or Tata Green. Please someone suggest the real-life prices. The base Tata Green as per website is for Rs.4000-odd (50k kms maintenance free). I feel this is a bit on the higher side - please advise if this indeed is the price range for good batteries in Delhi and what will be the net cost after exchange.
jessie007 is offline   Reply With Quote
Old 20th February 2010, 17:16   #154
panky12345's Avatar
Thanked: 127 Times
I recently got my Indica Xeta Exide 45Ah OE (lasted nearly 15-16 months) to an Amron 70Ah. Paid Rs. 2850/- along with the old battery.
Old 20th February 2010, 18:43   #155
I have two doubts. Is it realistic/practical to replace 45AH with 70AH?
Secondly if an Amron 70AH costs only that much how much it will cost if I have to replace my 55AH battery of Quadrajet? (The OEM Exide warranty was only for 6 moths and now it is over one year)
janitha is offline   Reply With Quote
Old 20th February 2010, 22:20   #156
Thanked: 68 Times
I was quoted around Rs. 8000 by Amaron for the same battery, maybe it was 74 Ah for my cousins Swift iDiesel
Are the prices of Amaron quite less down south?
rikhav is offline   Reply With Quote
Old 21st February 2010, 10:34   #157
panky12345's Avatar
Thanked: 127 Times
replacing 45Ah with 70 Ah would actually give extended "non-start" time for my ICE, along with a higher power to start my car (CNG). Only thing is that the charging time would be more.
Amron has verious lines to choose from : Pro/Blah Blah.. BTW, I'm based up north.
Old 22nd February 2010, 10:19   #158
Thanked: 91,681 Times
I recently upgraded my Jeep's battery to a 90 AH capacity. I believe the ampere rating indicates how much energy / charge the battery can hold (max) at any given point in time. As Phamilyman posted, the only disadvantage is that it will take longer to completely charge the battery.
Simple explanation : A 90 AH rating indicates that the battery will be able to supply 90 amps of power for an hour, or 45 amps for two hours, or 30 amps for 3 hours.
Old 22nd February 2010, 10:52   #159
panky12345's Avatar
Thanked: 127 Times
Post deleted by the Team-BHP Support : Please do NOT post one-liners that add little or no informational value to the thread. We need your co-operation to maintain the overall quality of this forum.
Please read our rules before proceeding any further.
Old 1st March 2010, 12:07   #160
Rocky_Balboa's Avatar
Thanked: 61 Times
The Exide on my SwifDy gave up yesterday, the car is 2 1/2 years old and the battery 2 years.
For the past week, I have been having long self-start durations in the evening times. When I tried to crank the car yesterday, the SVS light and other warning lights threw up. The exide servicemen checked and promptly said the battery is dying a slow-death.
They checked the cells and said the cells are weak (12.x rating was shown). I was also asked to crank, when they measured the amp's at the terminals. It threw about 8.8 when its supposed to be greater than 10. When I asked why wouldnt the alternator be culprit, they said it couldnt be.
This is my replacement battery after the OEM gave-up under 6 months. I dont have any replacement warranty on this except for the pro-rata.
Questions:
1) How do I ensure this is not an alternator problem? (During the 40K service, I did ask for alternator to be checked and the service reports AOK. I am on 44K kms only)
2) If I do have to replace, Can I look at Amaron batteries?
I suppose the OEM on SwifDys are DIN65 batteries - And I heard Amaron doesnt have one at DIN65.
3) Exide Matrix DIN65 costs about 6700Rs after 10% discount and battery buy-back, whereas Exide SF Sonic costs about 6200Rs. Both carry a 30month replacement warranty and 30 month pro-rata.
Help Phlease.
Rocky_Balboa is offline   Reply With Quote
Old 1st March 2010, 13:45   #161
Thanked: 61 Times
I was able to rule out the Alternator as an issue - at crank the battery showed 8.8 and after cranking it showed a healthy 14+.
Since I dont want to invest anything less than DIN65 (Amaron/Bosch etc), I am poised to buy Exide Matrix.
Old 6th March 2010, 08:18   #162
csateesh's Avatar
Thanked: 117 Times
Talking My OEM Exide lasted for 4.5 yrs
Hello All,
I am writing in to share my Exide OEM battery story. While I didn't like the way the battery died on me on one fine morning but it happened after 4 1/2 years. Now I know I can't complain about the duration but my Accent CRDi refused to crank. The starter motor didn't even turn. Darn !!
This happened in Chennai during my business trip
Amaron helpline wasn't very useful. Called them but they needed an hour or so for replacement. Walked around my parents place in chennai to find a Amaron dealer. Deal settled in 10 mins.
Catch here is for the Diesel battery you do not get 60 month option but get only the 48 month option.
Amaron dealer didn't believe I could get 4.5 yrs of life on Exide OEM battery.
Let us see if the Amaron battery delivers on the hopes and promises.
Sateesh
csateesh is offline   Reply With Quote
Old 6th March 2010, 16:49   #163
That's the general trend. Primary reason = Diesel car batteries suffer more vibration (for obvious reason) and hence, higher wear and tear.
Old 6th March 2010, 18:01   #164
csateesh's Avatar
Thanked: 117 Times
Hey GTO
Dealer says the main reason for this being the trend is the incorrect usage by the owners and poor maintenance.
Apparently they had Indica owners kill their battery due to poor maintenance. High wattage lamps, poor alternator (TVS make). The dealer indicated that the NipponDenso Alternator in my car was one of the key reasons for the longevity of the battery as I too run 100/90 headlamps with AC always
I am not too sure if this the case but I can't complain as I have an ND alternator
Sateesh
Old 20th March 2010, 21:26   #165
prince_pervez's Avatar
Thanked: 31 Times
Ok I'm done with Exide now. My pulsar has seen 2 batteries in 2.5 years. I gave it for charging last week and it died today. I took it to the shop and he said that the battery is gone.
He suggested Amaron and quoted 1700 for it.
My Lancer also has a Amaron battery (INR 3500 with 300 INR for my old Exide).
Lets see how the new brand works out.
prince_pervez is offline   Reply With Quote
Bat Mobile - Exide on road Service amtak Technical Stuff 65 23rd April 2017 22:50
Free Jump starts & Battery help - Exide Batmobile, Mumbai (and other cities) GTO Mumbai 36 28th April 2016 23:50
Battery goin dead... again and again... COUGAR 4x4 Vehicles 21 1st August 2009 18:27
A minor but irritating issue after getting a new Exide battery finneyp Technical Stuff 11 13th February 2009 12:48
FS: EXIDE 32Ah Battery shrivz Shifting gears 3 24th July 2008 20:27
