Old 31st May 2010, 10:09   #181
sumeethaldankar's Avatar
Thanked: 882 Times
Infractions: 0/1 (5)
What the dealer seems to have done is a load test that cleared the battery and your alternator/charging circuit. If the battery was bad it wouldnt have cranked the engine at the second attempt.
Here's a common thing - some starters do not disengage from the flywheel when the car starts and the starter continues to turn at revs far beyond what it's designed for. The starter may be overheating coz of this. Get it checked, carbon brushes and all.
BTW, another suspect is the starter relay.
Let us know how it goes.
Cheers!
I had the alternator rebuild in 2006 and i am really hoping that is not the issue but i will get it checked out from the garage where i had got it done.However i also think could it be due to loose fan belt after all the same was changed in 2007 and there is a faint chin chin sound coming , will have that inspected as well.
sumeethaldankar is offline   Reply With Quote
Old 31st May 2010, 13:21   #182
Raccoon's Avatar
Thanked: 103 Times
Why don't you take a service battery from the dealer for a day and see how it goes? If your dealer does not have it, you can always go to any other battery dealer... most dealers rent out service batts for about 75 - 100 per day. Just make sure it good and fully charged.
Load test does not necessarily absolve the battery 100%.
Old 5th June 2010, 20:55   #183
Thanked: 882 Times
Unfortunaltely the garage owner from whom i got the alternator rebuilt is shut as he is out of town so will have to wait till next week till he arrives.Meanwhile i am still having starter getting stuck problems every alternate crank or so.
Does the battery amperage has to match with the alternator output or so.Eg If the alternator is of a bigger type will it need more juice from the battery.My prev a/c delco did not had any problems with the same alternator.Also the alternator is not a standard maruti but is slightly bigger in size with some parts from the esteem's as mentioned by my mechanic when he had fitted it more than 4 years ago.It also needs a slighly bigger fan belt for the pulley as the standard for the 800 gets loosened soon. My current battery is exide max.
Old 5th June 2010, 23:28   #184
R2D2's Avatar
Thanked: 755 Times
Sumeet, I dont think there's something wrong with the alt. If there was it wouldnt be charging the battery and over a period of time, your starter wouldn't crank the engine no matter how many times you turned the key.
Get the alt, starter and belt checked when you visit your electrical shop. And no, there's no such thing as 'matching' of battery + alternator. To give you an example, I have frequently use a 1.25A charger to 'top up' my car's 45AH battery. A M800's alt should be around 35A or so.
To maximise battery life what is key is how long the alt or charger takes to charge the battery. Car engines are not kept on continously for extended period every time so it becomes important for the alt to charge the battery to 100% state of charge ASAP to prevent sulphation and loss of capacity.
A battery is used as a reserve. In fact alts, the primary source of electricity in a vehicle, are sized according to total electrical load/consumption of the car when all circuits including accessories are switched on. It would include a portion of the alt's capacity being used for charging the batt and plus a margin to cater to peaks in demand. Remember, the sum of electric power for a load is first provided by the alt and, if it exceeds the alt's capacity, by the battery...not the other way round as many people believe.
Cheers!
Old 6th June 2010, 19:35   #185
Thanked: 882 Times
Pardon my ignorance,but are the alternator and starter motor 2 different components or the one and the same?
Old 6th June 2010, 19:55   #186
R2D2's Avatar
Thanked: 755 Times
They are 2 different components - the alternator generates electricity whilst working and provides electrical power to the entire car and charges the battery (AKA lead acid accumulator i.e. a storage device). The starter, as its name suggests, cranks/starts the engine.
Old 6th June 2010, 20:25   #187
R2D2's Avatar
Thanked: 755 Times
Default Exide Battery - TLC
Was travelling out of town for about 3 weeks hence removed the OEM Exide battery from the car and connected to an automatic 'microprocessor' controlled charger. The charger maintains the battery at 100% state of charge. Bit of tender loving care should go some way in extending its life. :-)
Cheers!
Old 6th June 2010, 20:54   #188
Cheers!
What are the brand options available in the case of battery charger?
janitha is offline   Reply With Quote
Old 6th June 2010, 21:06   #189
R2D2's Avatar
Thanked: 755 Times
Hi..this charger is the Battery Tender international (1.25A). It is made by Deltran Corp.
Rgds,
Old 6th June 2010, 21:58   #190
Thanked: 882 Times
ok that clears up much of my confusion , so i guess maybe the battery or the alternator may not be a fault.I will have to get the starter motor fixed , which means more money drained out my wallet again. But i guess a 13 year old car will have it's problems.
Old 6th June 2010, 23:04   #191
R2D2's Avatar
Thanked: 755 Times
You're right, a 13 year old car will certainly have its problems. I recommend you get the starter checked first along with the starter relay. You can also check the alternator, battery and timing belt tension at the same time.
From what you've said so far looks like this is the 1st time the starter is giving problems. 13 years of service IS a long time for any component whether electrical or mechanical.
Cheers!
Old 7th June 2010, 13:05   #192
Thanked: 882 Times
Cheers!
Yup this is the first time in 13 years that the starter motor has given problem ,never had issues with the same before.Guess it was due for some attention after all those years.I had the timing belt replaced last year so i hope there is no problem with that.Will definitley get the starter motor checked this saturday.
thanks
Old 7th June 2010, 14:22   #193
sgiitk's Avatar
Thanked: 3,555 Times
The number of batteries changed when the real culprit was the starter must be legend. A quick test - crank the engine for 30 seconds, while monitoring the voltage. It should drop to ~6V and then quickly recover to 9+ and in a couple of minutes become 11+. If so then the battery is Ok.
Loose belt is another. I myself changed the battery in my old Escory Mk I in 1973/4. Only when the new one also went flat did I check and find the loose belt.
Old 17th June 2010, 13:35   #194
R2D2's Avatar
Thanked: 755 Times
Default OEM Exide Yellow Flag raised
Cheers!
Confirmation that my 20-21 month old Exide OEM batt (mfred Aug '08) may have been built to a price.
Came home from my outstation journey for a few days and it remained fully charged courtesy the charger. I used the car for completing local errands that my better half had in store for me once I returned. The car wasnt used for 2 days and this morning the starter was turning over noticeably slower. After measuring the alt charging voltage (at idle) using a DVM and a few hours later an OCV test, I was suspicious. I took it to the near by Exide dealer this morning who did a SpGr test and confirmed that the battery is partially discharged. Yikes!
He volunteered to recharge and observe/test it over the next few days whilst I travel out of town again. Its fate will be known on Monday.
Here's hoping.
Rgds,
Old 20th June 2010, 20:18   #195
R2D2's Avatar
Thanked: 755 Times
Right, the dealer tells me that it kind of cleared the load test immediately after charging. He said I could 'try to use it'. But it's not retaining a charge over a period of time (days).
Well, I am not someone who can use a battery that is on death row. So it is sayonara to my OEM batt that lasted for 1 year 8 months. Way to go Exide!
My dealer tells me that Exide offers only the Matrix in 45AH capacity range. This is a sealed battery which you cannot monitor other than via its OCV. Should it run low on water you cannot top it up, which in turn does not make me feel confident. It is possibly time to say bye bye Exide.
Considering either Tata Green and Amaron as replacements. There's not much of a difference in price. I will purchase the battery in the next few days.
Cheers!
Bat Mobile - Exide on road Service amtak Technical Stuff 65 23rd April 2017 22:50
Free Jump starts & Battery help - Exide Batmobile, Mumbai (and other cities) GTO Mumbai 36 28th April 2016 23:50
Battery goin dead... again and again... COUGAR 4x4 Vehicles 21 1st August 2009 18:27
A minor but irritating issue after getting a new Exide battery finneyp Technical Stuff 11 13th February 2009 12:48
FS: EXIDE 32Ah Battery shrivz Shifting gears 3 24th July 2008 20:27
