Old 10th April 2011, 13:51   #211
anupam9557's Avatar
Thanked: 20 Times
Default Re: Oh No! Exide battery woes again
Just installed Exide Matrix Battery in my Getz Prime. The old one(Don't know the name) was replaced since it showed unstability of charge in it.This Exide matrix battery cost 6K.I had to pay 2k for the battery since the stock was came around 4k and it was under warranty. plus it has 5 years warranty. What do you say? Would it be reliable ?
anupam9557 is offline   Reply With Quote
Old 10th November 2011, 15:04   #212
myavu's Avatar
Thanked: 509 Times
Post Re: Oh No! Exide battery woes again
Originally Posted by Raccoon View Post
As I have mentioned earlier, the OEM Amco Yuasa that came with my Shogun lasted 7 years!!
Mine even more. Close to 9 years. On the 7th year one of the battery wire detached from the casing and it was a "jugaad" for next couple of year by my local TVS mechanic. I had to fix it once at Munnar on a solo trip. Unbelievably close to 9th year the cable was no more fixable and battery became useless, still it was fully charged. I never charged the battery externally and even kept the bike in garage 2 months (in year 2000) without even starting (battery disconnected). But I was regularly (weekly) topping battery water and terminals was always clean. Adding to that none of my electricals of Shogun failed through out my ownership of 10 years (1,11,000 KMS) Head light bulb was changed twice, OEM got fused in couple of year, then went for white Philips halogen which lasted many years then one day it's glass part detached from the connector so replaced with another same bulb. Sorry for posting long OT. I really miss my gun:(
Cheers!
Vinu
myavu is offline   Reply With Quote
Old 10th November 2011, 15:53   #213
Raccoon's Avatar
Thanked: 103 Times
^^^Wow, you outdid my record by a large margin! Thats how batteries can and should be made. On the other hand, one of the wires of my approx. 2 year old Base Terminal (in my gun) gave way few months ago. The dealer just soldered it back or something. Also, the battery as of now seems to be on its last legs. But bike has been very sparingly used, so not sure to what extent the battery can be blamed. At least it has not leaked even a tiny bit in 2 years, unlike ultra-crappy Exides and Amcos (not to be confused with the older, much better, Amco Yuasa) which belch like volcanoes.
As for the bulb, did the Philips Halogen seriously give better light output than a normal tungsen bulb in your gun? Surprisingly, I'v found tungsten filament bulbs to be better than halogens in my gun.
Old 10th November 2011, 17:53   #214
myavu's Avatar
Thanked: 509 Times
Light was not that good. But a white high-beam was good enough for the oncoming traffic to dip
Cheers!
Vinu
Old 31st December 2011, 17:54   #215
sajanpt's Avatar
Cheers!
Vinu
So what was the final outcome. Did the EXIDE MATRIX make it for more than 5 yrs as claimed. I am planning to change my M800 battery with this sealed no maintainence, no refill battery and want some testimonials. Please help. My other option is an Amaron. The MATRIX costs Rs. 5100 after the trade in of old battery (Bosch - 3 yrs old)
sajanpt is offline   Reply With Quote
Old 31st December 2011, 18:45   #216
gaurav_chopra04's Avatar
Thanked: 533 Times
Stock exide battery in my cedia lasted for just over 4 years, that in my friend's cedia lasted for just over 4 years and that in my cousin's cedia is still lasting after 5.5 years.. I am amazed...
But then My friend replaced the batter to Amaron (Rs.3k, 1.5 yr warranty and 1.5 yr guaranty) and I replaced it to Bosch (Rs.1.8k, 1 yr warranty, 1 yr guaranty).
gaurav_chopra04 is offline   Reply With Quote
Old 2nd January 2012, 11:03   #217
Thanked: 118 Times
Well, my OEM Exide lasted 4.5 years before one cell going weak. The replacement battery (1.5+1.5 warranty) is at 4.25 years, and probably will need replacement in a few months. So, its not surprising at all that Exide batteries last (as I had posted earlier in the thread). Of course, if one buys a battery with 1 year warranty, it lasts much lesser IMHO.
That said, it could be very possible that Amaron is longer lasting model for model!
lancer_rit is offline   Reply With Quote
Old 6th January 2012, 14:46   #218
Thanked: 118 Times
So, it was time to change my Exide battery - it was 3 year warranty (1.5yr + 1.5yr), and did do above 4 years. Charge was going down to 8.9V when checked today.
It seems the Exide 3 year battery costs same as Amaron 4-year battery (Amaron 3-year is 300 bucks cheaper). Also, Exide 4 year battery is 1500 bucks more expensive than Exide 3 year.
I thought to try out Amaron 3-year, with discount was charged 3.3k
Old 6th January 2012, 16:31   #219
AvinashV's Avatar
Thanked: 33 Times
The exide battery on my Pulsar 150 has died for the 3rd time in 7 years.
Any suggestions on what my next bike battery should be?
Does Amaron also make bike battery?
AvinashV is offline   Reply With Quote
Old 6th January 2012, 16:54   #220
vnabhi's Avatar
Thanked: 1,181 Times
Originally Posted by vnabhi View Post
I too have had a pleasant experience with Exide so fars. My Exide in my 800 lasted for nearly 6 years! On my WagonR, it lasted 4 yrs, 2 months.
Why are people complaining?
Further to my post made around 2 years back, my WagonR's battery finally conked off after serving me for 6 years and 2 months! It has exceeded my expectations, and beaten my earlier record of 5 years 11 months on the M800!
Having had 2 very pleasant experiences, I naturally went for an Exide again.
Old 6th January 2012, 17:49   #221
Thanked: 16 Times
I had replaced battery of my Pulsar 180 with Amaron. If your 150 is a self start model, you can get the same. I am not sure of the battery of w/o self start model and I think it is smaller than the other.
Prass is offline   (1) Thanks Reply With Quote
Old 6th January 2012, 17:56   #222
AvinashV's Avatar
Thanked: 33 Times
Yeah, it's the self start model & it's the first thing that conks off & then slowly the rest.
How long you been having the battery? Cost & warranty?
Old 6th January 2012, 18:06   #223
Thanked: 16 Times
Hi, I bought it 2 years back and after 2 months sold the bike to a friend . But it is still being used by my friend very often and battery is very good. I think that it cost ~1200 rs and 2 Yr warranty or so that time, cant remember exactly.
Before replacing the battery, please check the regulator of the bike and check the charging also. I had to replace a faulty regulator once.
Old 14th January 2012, 15:16   #224
2 Weeks on the road and my Linea went dead; the car had to be jump started. Post the dealershipís (VST, Chennai) failed attempt to fix the issue by exide service, got the battery replaced under warranty. But, there is no warranty on the new battery now. The SA claims that the warranty becomes void on replacement.
I just donít get this, this being a new battery why does not exide provide a warranty on it, are its products so much prone to issues that they cannot afford to provide a warranty on a new battery? Or, is this the case with all OEM ones.
Has anyone faced this issue before?
ranjithpd is offline   Reply With Quote
Old 14th January 2012, 16:57   #225
amartya sinha's Avatar
Thanked: 15 Times
Yes, the same problem was faced by me. 2 months into buying the toyota altis D4D, the battery went dead, with hardly 1000 kms on the odo. Jump started it, initially thought that the battery might not have sufficiently charged, in the small ride after a week of the car not being started, but later realised, if that was the case, then the car should not start in the first case, and also that, a new battery should not discharge this quickly. When got stuck the 2nd time and had to jump start the car, took it to the toyota dealer, who informed us that its a battery problem. One of the exide battery cells was not functioning. it took Exide a 3 days to replace the battery under warranty. initially, as in ranjithpd's case, Exide said that the warranty would not be applicable for the new replaced battery. But after toyota dealers intervention and a lot of foul mouthing by us, Exide extended a years warranty on the replaced battery from the date of replacement.
amartya sinha is offline   Reply With Quote
Bat Mobile - Exide on road Service amtak Technical Stuff 65 23rd April 2017 22:50
Free Jump starts & Battery help - Exide Batmobile, Mumbai (and other cities) GTO Mumbai 36 28th April 2016 23:50
Battery goin dead... again and again... COUGAR 4x4 Vehicles 21 1st August 2009 18:27
A minor but irritating issue after getting a new Exide battery finneyp Technical Stuff 11 13th February 2009 12:48
FS: EXIDE 32Ah Battery shrivz Shifting gears 3 24th July 2008 20:27
