Old 25th August 2016, 10:15   #316
R2D2's Avatar
Thanked: 1,224 Times
Default Re: Oh No! Exide battery woes again
Originally Posted by vinit.merchant View Post
Now I am trying to find out the terms of this pro-rata warranty online but I cannot find them anywhere. I cannot find the original warranty leaflet and I do not want to get cheated by the dealer.
You will need that warranty card if you are to avail of a warranty replacement
If it is not produced Exide may refuse the replacement. You should always preserve your warranty card AND invoice/bill carefully. Try your best to locate these documents.
PS - the Exide Matrix in my Palio 1.6 is now 5.5 years old. I notice a slight hesitation when starting. That may be because the car isn't used much OR water is running low. This is a hassle with the Matrix. One can only top up 1 cell using the magic eye. If this battery fails I will be buying an Amaron.
R2D2 is online now   Reply With Quote
Old 25th August 2016, 10:46   #317
Thanked: 215 Times
Yesterday my Innova's exide suddenly stop handling central locking and startup. Its exactly 23 months old as OEM. Tried to find a matrix for innova but no battery dealer said that there is any matrix battery for innova, even though few online sites show this exide matrix to be compatible.
http://www.powerwale.com/store/exide...-battery/76914
Ultimately had to go for Amaron.
I run a compressor based car fridge, two dash cams, 200W inverter in innova. So i think 23 months life for OEM exide is fair expectation? But surely would have gone for matrix, had it been available in Delhi.
PS: The Toyota helpline guy who came to jump start the innova had only an old battery. He then requested a Fortuner wala to lend battery for jump start. Innova spluttered for few seconds then stopped. Then the helpline guy told me that alternator is gone bust and i should allow him to tow it away to Galaxy Toyota workshop. I called my regular mechanic and he told me that these helpline people want the cars to be towed away as they make more money and that its rare for Innova's alternator to conk within 2 years. I heeded to his advice and am happy that after battery change, everything works fine.
DwarkaDelhiWala is offline   Reply With Quote
Old 25th August 2016, 10:51   #318
Durango Dude's Avatar
Thanked: 730 Times
Infractions: 0/1 (5)
I've had an Exide in my Elantra GLS that lasted around 8 years before it died! I replaced it with an Exide! Is Exide that bad??!!
Durango Dude is offline   Reply With Quote
Old 25th August 2016, 13:50   #319
vinit.merchant's Avatar
Thanked: 934 Times
The new procedures are quite different. You just put the product & its unique code on a specified Exide site for registration and then one no longer needs the warranty card to claim warranty.
vinit.merchant is offline   Reply With Quote
Old 25th August 2016, 17:10   #320
R2D2's Avatar
That's a good customer friendly step.
The warranty card specifies the # rebate you will get on a new battery v/s the age or time elapsed since purchase.
Since you don't have the card, using Amaron's formula as a guide and based on fact your battery is in the 24 months pro rated warranty period, (purchase date May '14, warranty claim Aug '16) you should expect to get a discount of approx. 45% on the cost of a new battery. This is only indicative and your dealer/Exide will give you the correct discount value.
Good luck with the warranty claim.
R2D2 is online now   (1) Thanks Reply With Quote
Old 26th February 2017, 13:30   #321
R2D2's Avatar
To my pleasant surprise the Exide Matrix DIN55 (OE fitment is DIN45) installed in the Palio completes 6 years this month and enters its 7th year. I can sense the 'hesitation' sometimes whilst cranking the engine but this duration of trouble free operation has been a real bonus compared to my recent experiences with Exide Matrix.
Yeah, a replacement will still be Amaron or a Tata Green for the simple reason I can top up all the cells with distilled water if required.
Old 7th April 2017, 21:20   #322
R2D2's Avatar
The Exide Matrix battery has started hesitating to even begin cranking the engine indicating it's on its last legs. Took the battery to the dealer and had it load tested. It failed. I am pleased with the life of 6 years and 2 months.
A new one will be ordered on Sunday. Still debating whether I should go in for an Amaron 50AH or 45AH.
Old 15th August 2017, 11:30   #323
R2D2's Avatar
A quick update. I simply don't want sealed batteries any more. So the Matrix was replaced by an Amaron DIN50. This is the OEM spec for the 1.6 GTX while the Palio 1.2 takes a DIN45.
Old 29th October 2017, 14:20   #324
vnabhi's Avatar
Thanked: 1,240 Times
I've had great experience with the replacement Exide batteries on my WagonR. The first replacement lasted around 6 years 3 months and the second around 5 years 4 months.
On the Fiesta, the stock Amaron battery lasted 5 years 3 months, and the replacement Amaron lasted the same.
On the Suzuki Access, the replacement Exide lasted 4 years 7 months, while the replacement Amaron lasted 3 years 10 months.
So Exide wins in my opinion.
Old 29th October 2017, 14:36   #325
sagarpadaki's Avatar
Thanked: 1,271 Times
I think the woes of exide are not present since past few years. In fact, I have used both exide and amaron on our vehicles and both have performed equally well with similar longevity. I think this thread title is misleading now.
sagarpadaki is offline   (3) Thanks Reply With Quote
Old 15th December 2017, 18:07   #326
Thanked: 185 Times
Agree. I think we dont have an verdict on this.
I think we need a poll on this which will capture battery and life, both.
2000rpm is offline   Reply With Quote
Old 17th January 2018, 17:24   #327
shashank.nk's Avatar
Thanked: 734 Times
+1 to this.
I've used Amaron and Exide on each car at home replace and none performed better than the other, the only advantage with Amaron being better voltage at crank so there's no slow start. Infact on my bike the Amaron gave up waay too early, happily swapped with an Exide.
shashank.nk is offline   Reply With Quote
Old 17th January 2018, 17:34   #328
condor's Avatar
Thanked: 4,412 Times
On a note related to the above posts - while Amaron looks a safe bet, I have taken an Exide for the Storme this time. One of the reasons was the slightly higher Ah rating of the Exide battery.
Bat Mobile - Exide on road Service amtak Technical Stuff 65 23rd April 2017 22:50
Free Jump starts & Battery help - Exide Batmobile, Mumbai (and other cities) GTO Mumbai 36 28th April 2016 23:50
Battery goin dead... again and again... COUGAR 4x4 Vehicles 21 1st August 2009 18:27
A minor but irritating issue after getting a new Exide battery finneyp Technical Stuff 11 13th February 2009 12:48
FS: EXIDE 32Ah Battery shrivz Shifting gears 3 24th July 2008 20:27
