| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #31 (permalink) |
| BHPian | i used to maintain my exide battery very well. no extreme use. one day suddenly in the morning my car didnt crank. one cell from the battery had died . no clue how did this happen suddenly. now i have got amaron. no issues over amaron. i feel they are best for todays high performance cars.
__________________ " I dont Drive Fast , I Fly Slowly " |
| | #32 (permalink) |
| BHPian Join Date: Mar 2006 Location: Chennai
| I've replaced EXIDE batteries (3 of them including the OEM one) in the last 7.5 yrs. for my WagonR I was thinking that there was some thing wrong in my driving or using the battery. Now I changed to Amaron and hopefully things should look up. Regards, lsjey
__________________ ------------- 2000 - > Wagon R Lxi Pre 2000 -> Nataraja service |
| | #33 (permalink) |
| BHPian Join Date: Mar 2007 Location: Bangalore
| Battery can go Kaput based on multiple issues - 1. faulty battery 2. Faulty charging system 3. High usage of battery power 4. Non-usage of the car for long duration of time Faulty battery - one can do nothing but pray that you don't get a lemon. faulty charging system - Get the car A.S.S to check this out High usage of battery power - This is the most common reason for battery failure. The reason here are - 1. Frequent starts and stops (If you do start -stop for more than 6 times a day) and cover less distance during the day (<25 km) 2. High Load due to additional ICE and other battery Hoggers - An Amp and/or a Sub woofer are main culprits. Non-usage of the car for long time - If you do not use the car for more than 3 months then the battery would go down unless you have disconnected the connections to the battery. Even if you do disconnect and not use it for 4-6 months the battery would need additional charging before it can be put to use.
__________________ If you have not failed you have not tried enough. Swift Diesel VDI - Feb '07 onwards Santro LS- Mar '01-Feb '07(59000 KM) Sold. |
| | #37 (permalink) |
| BHPian Join Date: Jul 2006 Location: Bangalore
| People buying batteries for cars at least have other options. A friend has a Dio and the battery conked off just after the warranty period expired. bought another Exide as there are no options for two-wheelers. Exactly one year and 4 days since that was installed, it too died. Now, the Dio is being used without a working battery. Any options for two wheeler batteries ?
__________________ Long Live Schumacher !! The greatest there ever was or there ever will be !! Exams suck !! |
| | #38 (permalink) | |
| Senior - BHPian Join Date: Oct 2005 Location: Currently at Chennai. Originally from Blore.
| Quote:
The exide in the esteem lasted for over 4 years although it had run only some 35k KMS. The one in the 800 conked out in less than 24k KMS or 3 years. Now both have Amaron's and I'm pretty satisfied. Ensure to check the distilled water level and the charge once every month and more frequently in summer. For the Amaron's I check the water level at a local batter shop once every 3-4 months. The indicator on the vattery may not be very accurate you know. ![]() | |
| | #40 (permalink) | |
| Senior - BHPian | Its been 3 years since i changed to Amaron & i have actually forgotten that there is a battery in the engine bay. ![]() Amazing performer
__________________ Quote:
| | #41 (permalink) | |
| BHPian Join Date: Feb 2005 Location: Varkala
| Quote:
After that, even my simple ICE setup sounds way better... I am sure Johnson Controls (Amaron collaborator) has a far better image there.
__________________ Remember, you are unique like everybody else. Last edited by sandeepmdas : 6th May 2008 at 16:08. | |
| | #43 (permalink) |
| BHPian Join Date: Nov 2007 Location: Hyderabad
| My Exide had gone off in my Victor in just 15K Kms :( But have no other options i guess. Had to replace it soon.
__________________ :: Indica Xeta 1.2 GLS :: 26 Dec 2007 :: ~15 Kmpl :: TVS Victor GL 110CC :: 24 Jan 2004 :: ~72 Kmpl |
| | #44 (permalink) |
| BHPian Join Date: Apr 2007 Location: Slumbai
| Our experience with Exide has been pretty good. Our car has been fitted with an Exide maintenance free battery and its running trouble free for more than three years. We also have an Exide battery for an inverter which has been running without trouble for 4 years even though we haven't checked the water level in its lifetime (I know thats a bad practice). |
| | #45 (permalink) | |
| BHPian | Quote:
Prophesy fulfilled. Got a sluggish start in the morning. Got her to the battery guy for a check up. Found that the water had dried up again. Will be replacing the battery this weekend. Options: Amaron, Exide or Tata Green. Tata Green with 15 months warranty was quoted at 2800.
__________________ Be your own Hero. RE TBird 2003, no speedo, no range limits. Wagon R, 2004. | |
| Thread Tools | |
Similar Threads | ||||
| FS: EXIDE 32Ah Battery | shrivz | Shifting gears | 3 | 24th July 2008 20:27 |
| OEM car battery life - How long did your OE battery last? | shuvc | Technical Stuff | 125 | 16th July 2008 21:48 |
| Battery woes!? | rocksterraghu | Ask the Gurus | 20 | 7th January 2008 23:10 |
| Bat Mobile - Exide on road Service | amtak | Accessory/Parts Reviews | 14 | 27th November 2007 16:35 |
| Battery Woes! | sparkglow | Technical Stuff | 10 | 3rd July 2006 23:25 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
