Old 12th April 2009, 00:02   #106
moralfibre's Avatar
Thanked: 6,461 Times
I have been running the original Exide battery on my car for the last 2 and a half years. No problems whatsoever. It includes leaving the cabin light switched ON overnight.
The battery is due for a replacement when I return since the car hasn't been used for 3 months now. The battery must have died on me.
Old 12th April 2009, 08:00   #107
Thanked: 145 Times
Originally Posted by moralfibre View Post
...The battery is due for a replacement when I return since the car hasn't been used for 3 months now. The battery must have died on me.
If you have disconnected the battery, you might still have a chance!
HappyWheels is online now   Reply With Quote
Old 12th April 2009, 10:10   #108
R2D2's Avatar
Thanked: 1,811 Times
You are right. A batt over 2 1/2 years old and not used for 3 months should theoretically be a candidate for replacement. But before you replace the batt, give it to a dealer who can charge and test it for you. If it accepts a charge and tests ok, you will save some money.
Rgds,
R2D2 is online now   Reply With Quote
Old 23rd April 2009, 19:10   #109
moralfibre's Avatar
Rgds,
I got the car started today with a friends help and it came to life in the first crank.
Old 23rd April 2009, 21:43   #110
R2D2's Avatar
Great! Good to know this. Did you jump start your car?
Either way, it's important to have the battery checked and, if deemed necessary by a batt dealer, fully charged at the earliest. You may be able to extend its life more than a bit.
Cheers!
Old 23rd April 2009, 22:43   #111
nitrous's Avatar
Thanked: 285 Times
I dont think he jump started.
Old 24th April 2009, 00:02   #112
moralfibre's Avatar
Cheers!
No I did not get the car jump started. Just reconnected the battery and it was good to go.
Old 1st May 2009, 01:06   #113
nvldvr's Avatar
Thanked: 276 Times
My wagon r battery died out on me today after almost 4 years. Was an exide. Need to get it replaced tomorrow. From all the posts on this thread, amaron seems to be the one i should go for. If i am not wrong, there's one amaron pro series available with 5 years warranty. Is that good? And how much should it cost?
nvldvr is online now   Reply With Quote
Old 1st May 2009, 18:59   #114
maestro's Avatar
The first Exide battery I bought lasted just 15 days after the warranty expired. That was in 1980. Since then, I have switched to AMCO and then Amaron, both of which lasts me 5 years atleast. My present Amaron was bought in March 2003, making it over 6 years old. At least, it is comforting to know that I have made the right decision, as Excide has not improved even now.
maestro is offline   Reply With Quote
Old 2nd May 2009, 10:36   #115
nvldvr's Avatar
Thanked: 276 Times
Bought an amaron flo battery. Zero maintenance battery with 4 years warranty (2 years replacement + 2 years pro rata). With all the exide battery woes mentioned here, i am hoping it will give me better service.
Old 2nd May 2009, 13:46   #116
What is the AH capacity and cost?
janitha is offline   Reply With Quote
Old 2nd May 2009, 17:28   #117
nvldvr's Avatar
Thanked: 276 Times
342 AH. I got it for 3250/- from a services depot.
Old 2nd May 2009, 18:42   #118
Note from the Team-BHP Support Staff : Post Deleted. Typing a message which is not a value-addition to the topic being discussed, or is just entirely irrelevant is considered as “Spam” on this community. Spamming is STRICTLY prohibited on Team-BHP.
Old 27th September 2009, 17:10   #119
MuzzledMoose's Avatar
Thanked: 29 Times
Unhappy OE Exide Battery
Hi Guys,
I just had a problem with the Battery and replaced it on my Logan. The OE battery is exide from Renault. Exide guys say that the OE battery will not last more than 2 years (Freedom brand Maintenance Free). Also i find the voltage from the charging terminals is about 12.8 volts only when the battery is connected. If i raise the engine it goes to about 13V. Is really the Battery is culprit or Regulator/Alternator is culprit (there is no indication of anything faulty in the console)
The OE battery is just 22 months old
MuzzledMoose is offline   Reply With Quote
Old 27th September 2009, 19:12   #120
R2D2's Avatar
Originally Posted by MuzzledMoose View Post
Hi Guys,
OE batteries are notoriously flaky when it comes to service life. But that's not surprising considering car mfrs pay bottom of the barrel prices for OEM batts. You get what you pay for.
That aside, 12.8 at idle and 13v at higher speeds is low. Voltage at the terminal should read between 13.8 and 14.2 volts at engine idle speeds (~800 RPM). Higher revs (~2000-2500 RPM) should produce about 14.4v.
I'd get the alternator's regulator checked ASAP if I were you. You say you replaced the battery, the new one will also be undercharged and wont last very long. Didnt your dealer check the charging system whilst fitting the new battery? They normally do.
Rgds,
Bat Mobile - Exide on road Service amtak Technical Stuff 65 23rd April 2017 22:50
Free Jump starts & Battery help - Exide Batmobile, Mumbai (and other cities) GTO Mumbai 36 28th April 2016 23:50
Battery goin dead... again and again... COUGAR 4x4 Vehicles 21 1st August 2009 18:27
A minor but irritating issue after getting a new Exide battery finneyp Technical Stuff 11 13th February 2009 12:48
FS: EXIDE 32Ah Battery shrivz Shifting gears 3 24th July 2008 20:27
