Thread Tools
Old 3rd May 2008, 10:54   #1 (permalink)
Tapan's Avatar
Angry Problems in my Alto!!!
I got Alto last year in June 2007. And its not even a year yet and the engine has started knocking. Upon taking the car for service the mechanic told me that as i am using premium petrol thats why the engine is knocking. Is this in real ?
The mechanic checked engine timing etc. said it was all okay. So he has told me to use simple petrol and not premium at all. I mean is the engine so (can't find the word) that it is not able to consume premium petrol ?
Secondly there's a humming sound coming from the car when the car is in gear but when i have not stepped on the race paddle. Its like "ghoon ghoon ghoon" upon checking with dealership they are just saying its the tyre noise.
What i am wondering is how can the tyres suddenly start making a sound like this. After this I got the wheel alignment, balancing, rotation but to no avail. Abhishek from Chandigarh here told me that its the bearing noise but dealership told me that bearings are very long lasting and they are sealed so there's no chance of humming sound coming from bearings.
Please suggest. I have started to regret why i did'nt got spark or santro etc.
Thanks.
__________________
Achtung Baby!
I am NOT driving FAST. I am FLYING LOW.
Tapan is offline   Reply With Quote
Old 3rd May 2008, 11:59   #2 (permalink)
You can look at changing your service station – many a times the guys just give excuses or say they have done a job when they have actually have not even bothered. If it’s a regular service they just stick to the process.
The sound you are referring to is due to your car running in gear at a low engine RPM (correct me if I am wrong), this would also happen if you drive in, say, 4th gear at 20 kmph.
I had a problem in my alto too. The engine would shudder violently when starting off in first gear at times. This used to happen when the car had run for a while - the service station guys could not figure it out (2-3 stations). But hey, the alto is otherwise a great car - very low on maintenance, amazing ac, good economy, etc.
wanderluster is offline   Reply With Quote
Old 3rd May 2008, 12:20   #3 (permalink)
Team-BHP Moderator
Jaggu's Avatar
You need to find a good service center/dealer and then you should be fine. As far as petrol goes, all the indian cars are designed for normal petrol, so more than knocking it might be waste of money to use premium fuel. Better option will be to find "good quality" petrol
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 5th May 2008, 11:15   #4 (permalink)
Tapan's Avatar
wanderluster: Yes the sound comes when the car is running in gear but i have not pressed the race paddle. The speed does'nt matters. If i am pressing the race paddle then the sound dose'nt comes. But as soon as I take off from the paddle the humming sound starts coming instantly and keeps on coming till the speed is not less than 10 km.
I will change dealership now. I went to Chitoso motors, Mohali. They called me today for check up but I will go in few days.
Regarding maintainance cost the 4th paid service costed me Rs. 3548.00 they changed: Spark plugs. Was that really necessary ? The service advisor insisted that spark plugs must be changed after 20000 kms.
I did all the things service advisor suggested thinking that it will get rid of the sound eg.
Spark plugs (159.99), Oil filter (66.09) was changed, Wheel alignment, balancing and rotation was done costed (405 including weights etc.). (If it was a tyre problem then it would have rectified after rotation etc.) Anyways coolant was changed (314), engine oil (400), engine flushing treatment (this is new one - 3rd most expensive thing in bill costed Rs. 375), brake oil (115.56) was changed, gear oil (456), disc brakes cleaning (another new thing costed Rs. 100), Brake bleeding (another one lol Rs. 100), Fuel injector cleaning (270).
Okay so please clear me now:
What is Engine Flushing Treatment ?
What is Disc Brake Cleaning ?
What is Brake Bleeding ?
Thanks.
__________________
Achtung Baby!
Old 5th May 2008, 17:35   #5 (permalink)
Originally Posted by Tapan View Post
Thanks.
Does the sound come when you are decelerating only, if yes, then try pressing the clutch immediately when the sound starts coming. This happens in my alto too and would be interesting to know if its the same problem in your car too.
Anand.S
anandtheleo is offline   Reply With Quote
Old 5th May 2008, 18:05   #6 (permalink)
Location: Chennai (formerly Madras, even more formerly Chenna Patnam)
Arrow Please change the title : the Alto is a great VFM car !!!
Secondly there's a humming sound coming from the car when the car is in gear but when i have not stepped on the race paddle. Its like "ghoon ghoon ghoon" upon checking with dealership they are just saying its the tyre noise....
The "ghoon ghoon ghoon" sound can be heard when you are coasting along ( the vehicle is moving without the accelerator {'race paddle'} being pressed), and the speed of the car is near or below the minimum speed for that gear (eg. the minimum speed in 3rd gear is 20kmph : so you will get this sound if you car is at or below 20kmph in 3rd gear, and you are not pressing the accelerator). This is a perfectly normal sound : you just need to take the car above the minimum speed for the current gear.
Please do change the title : the Alto is definitely not sucky
PS --> thanx for the title change !!!
Blue Thunder is offline   Reply With Quote
Old 5th May 2008, 18:14   #7 (permalink)
Originally Posted by wanderluster View Post
...The sound you are referring to is due to your car running in gear at a low engine RPM (correct me if I am wrong), this would also happen if you drive in, say, 4th gear at 20 kmph...
...The engine would shudder violently when starting off in first gear at times. This used to happen when the car had run for a while - the service station guys could not figure it out (2-3 stations). ...
We have the same problem with our Alto, but it happens very rarely. So I have not told the service guys : they may unnecessarily replace the clutch components.
... But hey, the alto is otherwise a great car - very low on maintenance, amazing ac, good economy, etc.
Old 5th May 2008, 18:23   #8 (permalink)
Sush's Avatar
Calm down Tapan. There are small problems at times. Afterall we are talking about mechanical parts and there can always be issues.
Sush is offline   Reply With Quote
Old 5th May 2008, 23:14   #9 (permalink)
Tapan's Avatar
No its not speed related. And its not like that I am driving in a higher gear at lower speeds. It comes even if i am at 60+ in fifth great..as soon as the i take my foot off the paddle the silly sound starts coming and as soon as i press it back the sound goes off. This happens till the speed is 10 or less. Now obviously i can't drive alto in top gear at 10 kmpl. I have corsa also and I never had any type of problem with that. Only I drive both of the cars and only Alto makes this kind of sound.
This also has started when 1 day I bumped into a pit at very high speed. The wheel cover flew away and I never found it back. I think from that day onward the sound has started but I am not 100% sure. I think i have to get it checked throughly.
Thanks.
__________________
Achtung Baby!
Old 3rd June 2008, 22:41   #10 (permalink)
Hello there,
I have been following up on this thread for quote some time especially because I was having the same problem with my Alto.
After repeated attempts to isolate the problem, I think I may have found the solution.
The humming irritating noise that actually drowns the entire passenger cabin especially at higher speed could because of a faulty/ worn-out wheel bearing. It can be found out if you feel the suspension with the wheel spinning and you can feel a disturbing vibration.
Tapan, if you think it is worth a try, suggest a wheel bearing change while you service your car next time and it shouldn't cost you more than Rs 500.
Thank .
Kris_risk is offline   Reply With Quote
Thread Tools
Ebay problems Revvhead Shifting gears 3 12th March 2008 23:35
Please help me with Alto repair problems sabret00the Indian Car Loans & Insurance 2 7th September 2007 16:39
Some problems raja748 Technical Stuff 6 15th June 2007 10:29
Three problems with my vtec sunith Technical Stuff 24 10th October 2006 13:35
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
