Old 19th May 2008, 21:28   #46
Eddy's Avatar
Thanked: 5,070 Times
Originally Posted by tush View Post
Are alignment and balancing 2 different things? If yes then you are right no balancing done. Just alignment. Most of my colleagues told me that alignment charges are somewhere between 150-300....
Yep, alignment and balancing are different. But if your problem is solved without balancing, then so be it. Update us tomorrow.
Eddy is offline   Reply With Quote
Old 21st May 2008, 22:06   #47
tush's Avatar
Hey sorry for the late reply... it does seem to be corrected a little bit... but the problem is not gone... let me drive another 150-200Kms i will then confirm if its gone... I did notice the car goes to the left slowly and steadily...
let me drive for few more days and confirm it....
tush is offline   Reply With Quote
Old 21st May 2008, 23:08   #48
Eddy's Avatar
That might be due to the banking of the road. Keep us updated though.
Old 22nd May 2008, 10:30   #49
tush's Avatar
Eddy have u ever encountered such issue with your swift... did check if it steers to any one side even though the alignment is done..?
Old 22nd May 2008, 10:38   #50
Eddy's Avatar
Yep. Did a temporary solution of rotating the tyre which has solved it.
Old 22nd May 2008, 11:33   #51
Jaggu's Avatar
Thanked: 8,685 Times
Hey guys please be sure its NOT the banking effect OR the torque steer you are getting. These are evident in almost any car.
To check for pull, road has to be flat (not banked for turns or for rain water run off) and the surface on both sides similar, and then the car should track straight.
Old 24th May 2008, 15:17   #52
tush's Avatar
Where to find such a flat road Jaggu... Arent the Cement Roads flat when they are straight for a stretch of 2-4 Kms....
Old 24th May 2008, 15:27   #53
Eddy's Avatar
Banking effect, I can understand. But what is torque steer ?
Also, if the situation improved after swapping tyres (in my case), then it can't be any of the two right ?
Old 24th May 2008, 17:51   #54
bharatbs's Avatar
Thanked: 109 Times
Hi Tush,
I have the same problem with my 2008 Swift VXI. The car is shod with 15" alloys on 195/60 tyres.
So I got my wheel alignment done at Madhus Tyre center (Computerised alignment near Richmond road flyover).
The wheel balancing on my car has been done earlier at Sai Iyengar, so did not go to do it again.
After the alignment the left steer reduced to an extent but it was still there. So I took the car back again to Madhu's, and this time they rotated the tyre front/back.
After this I havent been able to check the alignment properly though, thanks to Bangalore traffic. You need to hit speeds of atleast 70-80 to check the alignment correctly.
I will try to check soon and let you know.
PS: I know of another 4 colleagues who own swifts at work with the same problem as mine. They are all running stock tyres. None of them experince irregular tyre wear though.
bharatbs is offline   Reply With Quote
Old 24th May 2008, 23:01   #55
Jaggu's Avatar
Good ol wiki: Torque steering - Wikipedia, the free encyclopedia
Try swapping the RT tyre to LT by remounting the tyres (if uni directional), if its pulling too much.
Old 27th May 2008, 01:52   #56
tush's Avatar
Hey Bharatbs,
Thnx for putting up the snaps... the alignment that i got it done from had a somewhat similar system...
Guys this Sunday i did a driving to Pune-Lonaval-Pune(totaled 160Kms) and before that i got the tyre pressure checked... The wheel alignment dude had kept the tyre pressure a little more by atleast 4 points in the left front tyre i guess that was another reason the problem had reduced a little bit.... but before my trip to Lonavala i got it corrected to 36 as recommended by maruti in both front tyres... and c what... the issue is back with the same intensity of pulling on the left... the MY CAR maruti dealer ship had put a stall in my company... i told them about this problem... the sales group manager took a test drive of my car and he said yes the problems there but very mild and would be corrected by wheel balancing.... yeah n also whenever the car steers towards the left the steering also steers by a little more then fraction to the left....
another thing i am noticing since a couple of days is that my front bonnet has developed inconsistent surface uneven surface instead of a plain chik surface at the very front... like a very small up n down surface which can be seen from certain angel but no scratch on it...and another one to the right front door...how could this have, have happend...is the metal used is of very low gaze(whatever its called) or low quality...
Old 31st May 2008, 12:21   #57
Jaggu's Avatar
Replies inline in bold
Hey Bharatbs,
Tyres!! swap rotate tyres and your pull should be off for good.
Can be cricket fans with tennis ***** or the likes, i have some thanks to some local kids near office playing cricket in front of my car @ office :(
Old 31st May 2008, 19:23   #58
humyum's Avatar
Thanked: 2,502 Times
Hey Bharatbs,
Ha ha,maruti sure needs to employe better people for problem solving.Wheel balancing solving pulling problems..sheesh..!!
Old 10th June 2008, 15:24   #59
rajatsingh78's Avatar
Thanked: 27 Times
Just read the entire thread...and yes I am also the victim of the "swift-steering-to-left" virus, after numerous complains the issue is still there, I also got a tyre changed for irregular wear and tear, and I don't remember that whether this tyre was from the left side (now I will be looking for the same when I next go for tyre rotation).
rajatsingh78 is offline   Reply With Quote
Old 10th June 2008, 16:53   #60
Thanked: 2,470 Times
Guys,
This is a very familier problem with all Maruti's.
The monocoque shell that maruti's make is so damn susceptible to regular twists that over a period of time the shell doesnt remain factory fresh. This though is not a problem with other manufacturers apart from Hyundai.
My M-800 is facing the similar problem. Even though i've checked every damn thing from my suspension to my aprons and my balancing rods and also my calipers, knuckles. You name the parts i've gone ahead and changed them. Still the problem persists.
After lot of thinking and doing my rounds of R&D and discussing it with my Mechanical Engineering friend he says " Because the Strength of Material used is not of a great quality, if you have had a minor accident or would have had a headlong collision for your car, there seems to be a bit of chasiss twist.
The front portion at one point would have gone in by a negligible mm's.
Though its not a major scare, but your pulling towards left or right phenomenon continues.
Dont know how to get this rectified.
Help Choose: City vs Fiesta Diesel vs Verna Diesel vs Swift Diesel aseem Hatchbacks 21 11th October 2009 17:44
My Grand Vitara Veering towards Left GRV Technical Stuff 6 5th July 2009 11:18
Fiat Uno (non PS): Car steers by itself Abhiraj Technical Stuff 13 14th June 2009 00:49
Indica V2 Diesel: Most dash board light blink like left/right turn indicators! bhuvanmisra Technical Stuff 7 18th November 2008 11:56
