Thread Tools
Old 10th June 2008, 20:26   #61 (permalink)
tush's Avatar
Had given the car to the maruti service station again. This time they did "Cross Member" adjustment. I dont know what it means but the workstation manager said its the platform on which the steering assembly resides and some bla bla bla which i dont remeber. I insisted him to show me what it is. He did show me for a petrol swift which was being serviced when i reached there. He said it was adjusted by somewhere between 0.5mm to 1mm as specified by maruti as they started getting these complains for swift.
We took a drive but was not sure if its rectified as the road near the workstation is all uneven. I dont know how they checked my car as the road outside their workshop as all is tar and no cement. Hope they might have taken to other roads as well for test drive.
Lets see now after driving on different roads i will finally come to know if its resolved.
__________________
_________________________
Swift DDIS ABS Silky Silver__
Achtung Baby__
My Thread - swift diesel steers towards the left
tush is offline   Reply With Quote
Old 10th June 2008, 20:36   #62 (permalink)
bharatbs's Avatar
Some updates:
Since I was getting regular mails from Maruti asking for detailed feedback about the vehicle. I mentioned about my car steering to the left and presto within two weeks I get frantic calls from Bimal Auto, Bangalore (dealer) asking me to get my car so that they can get it checked.
Today I went for a drive with the technician and after a little bull****ting he agreed that the car is pulling to the left. So I have to take it to the dealer on the weekend and they will do the alignment. I have feeling that this will not help considering that wheel alignment is already done outside, but lets see whet happens. Will keep you guys posted.
Pavan, your message is beleiveable and a scary proposition. I recently drove a friends Getz. The car has a much smoother suspension and no steering pull issues. Wonder when Maruti will start making flawless cars?
__________________
"None of my wars went according to plan, but then, I never went to a war without planning".
-Napoleon Bonaparte.
bharatbs is offline   Reply With Quote
Old 10th June 2008, 23:21   #63 (permalink)
Jaggu's Avatar
Originally Posted by rajatsingh78 View Post
Just read the entire thread...and yes I am also the victim of the "swift-steering-to-left" virus, after numerous complains the issue is still there, I also got a tyre changed for irregular wear and tear, and I don't remember that whether this tyre was from the left side (now I will be looking for the same when I next go for tyre rotation).
You have an issue with suspension setting, unfortunately there is no other way apart from jugad work (making ovel the holes that hold the wheel assembly to strut) to solve the issue. Text book approach is to replace the defective strut which is showing the error.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 11th June 2008, 00:06   #64 (permalink)
Thanks Jaggu...I am looking for a laser based wheel alignment center near my place and will get it checked and documented before I approach the dealer or Maruti for a replacement.
rajatsingh78 is offline   Reply With Quote
Old 12th June 2008, 02:33   #65 (permalink)
tush's Avatar
Jaggu and anyone else has any take on this.
__________________
Achtung Baby__
Old 12th June 2008, 04:10   #66 (permalink)
punterccrx8s's Avatar
I have a swift too,2008 model. There is no such problem in my car.But in my zen i had faced this problem. First i took it to wheel alignment centre and got the problem fixed.But then , it still continued. Then i realised that the problem was with the fact that my steel rim was slightly bent. Got it hammered and into shape and then my problem was solved.
__________________
"Bugatti Veyron 16.4 Grand Sport = Heaven"
punterccrx8s is offline   Reply With Quote
Old 12th June 2008, 11:57   #67 (permalink)
Jaggu's Avatar
There is a cross member but i dont remember any adjustments for that, is it possible for you to take a snap of the part they referred to? This would help.
If you have cleared the alignment check, only thing that can help is swapping tyres, these tyre pulls are sometimes very painful to diagnose.
__________________
Old 14th June 2008, 18:49   #68 (permalink)
tush's Avatar
Jaggu check this image of Cross Member. Its from a Pertol Swift and its same for Diesel Swift. The image below that is from the manual which the maruti workshop has it.
__________________
Achtung Baby__
Old 16th June 2008, 18:00   #69 (permalink)
Default I too have the same problem
I got my Swift VDI on 8th of May 2008. My car has been pulling to the left from the day I bought it. I guessed it may be due to the wheels being aligned incorrectly. I got the first service done from Pratham Motors. They did the wheel alignment. The problem persists. Pratham motors people told me that this problem exists in all swift diesels.
Please indicate if this information is correct? and what should be done to correct this issue?
I have changed the tyres and rims. I am confident that nothing is wrong with them. Wheel balancing was done on the new alloys.
This problem is not there with all Marutis as my WagonR does noto have this issue.
I have written to maruti Suzuki also but there is no reply.
I can manage driving with the car pulling to the left, but I am afraid of uneven tyre wear.
I asked other people about it, they told me that the car should pull about 1m to the left for every 30m, but my car pulls much more. It is very easily noticed, it shows up at about 40kmph.
__________________
Float like a Cadillac, Sting like a Beamer..
RacerByHeart is offline   Reply With Quote
Old 16th June 2008, 18:39   #70 (permalink)
Jaggu's Avatar
Thanks tush for the pics, that is the subframe i guess, but am not sure any adjustment facility is available on that. If you observe closely its mounted using fixed bolts with no provision for adjustment, unless there is some specific mod that Maruti has suggested over internal circulars. This part helps in isolating chassis from heavy impacts from the suspension giving a relatively plush feel.
Any other suspension experts please comment.
@racerbyheart: my car doesnt pull to any side. Wheel balancing is definitely not the issue, try swapping tyres from front to back or switching side if they are non directional. If properly set car will NOT pull to any side.
Go through these pages for more info Car Bibles: Wheels, tyres and tyre markings.
__________________
Old 17th June 2008, 19:37   #71 (permalink)
tush's Avatar
Let me mention first. I have drove my car for about 70-80KMS after bringing it from the workstation. But the problem is still there. The steering turns to the left a little bit even if there is slight change in road surface or increase or decrease the speed of the car and the car starts going to left.
Its plain simple, if i leave the hand of the steering for even 3-4 seconds the steering doesnt stay stable, will steer a bit to left and the car would slowly go to the left of road. I even feel mild pressure on my left hand to keep the steering straight to keep the car going straight. And i realise this after driving for a while.
Thanks for your inputs Jaggu. The service station said they grind the hole where the bolts get inserted around about 0.5 to 1 mm so that they can adjust the Cross Member. And they said this is suggested by maruti itself for the left pulling problem. I don't understand one thing, everytime i tell them about this problem they give the reason of road banking.
They even say this is not called pulling. Pulling means there is sudden steer towards a particular side. HELP NEEDED PEOPLE!!!!!
Where the hell should i test my car, on what kind of road. I have one chance of express highway, but then doesnt that have a little banking for rain water to drain at the sides.
The other maruti dealer ship technician said that they have a circular from maruti which specifies what they can do. However no circular has anything mentioned about cross member. He confirmed with the alignment guy in their workstation and he said that they do the cross member adjustment for left pulling in swift. But he also mentioned that they do not grind the hole to increase its diameter. They do the adjustment in the default play that it has.
No Maruti dealership has the right information i guess. Is this ever going to get resolved.
@racerbyheart: I had gone to another dealer ship of maruti to discuss this. They said they had a customer who had this similar problem for Swift Diesel. They did every dam thing. Even adjusted the Cross Member but it didnt resolve. They played on it for a month and finally they found it was the alloy wheels causing problem. They fitted the stock wheels and the issue was resolved. So u might want to check the same.
__________________
Achtung Baby__
Old 17th June 2008, 22:52   #72 (permalink)
Jaggu's Avatar
Find any regular road with flat surface, newly laid tarmac will be ideal. Pune why not try the MG road? Sorry last time i drove there was some 8 years back
__________________
Old 18th June 2008, 23:34   #73 (permalink)
bharatbs's Avatar
Update on my earlier post:
I had been to Bimal Service Station last week, I spoke to the chief engineer.
The chief engineer took a test drive and then admitted that my car steered less, they had cars which steered to the left a lot more and they have done a lot of R&D to solve this issue in house at Bimal. For some cars they have been able to solve it, for others they just not been able to. They are saying that it is an issue with Swift body/chasis i.e. manufacturing defect from Maruti.
They ran several test drives. Once before tweaking the setup, once after and then without alloys. After fitting the stock tyres according to Bimal the car was steering correctly. However IMO it was not. In the end we had done more than 50 kms of testing and I was tired. I decided to call it a day and test it out on a proper well asphalted highway and then get back to Bimal.
They told me that if I was still not satisfied, they will esclate my case to Maruti and they will send a service engineer to check my car.
__________________
Old 19th June 2008, 00:01   #74 (permalink)
Jaggu's Avatar
Just take a drive to our new airport, devnahalli. You will surely know if the car is pulling to the side.
__________________
Old 21st June 2008, 21:04   #75 (permalink)
tush's Avatar
@bharatbs -
Did they do Cross Member adjustment for your car. The printout they give you for the work they have done can you just let us know what is mentioned on that. And also cross check that information with what is mentioned in the job card. On request they will show you the job card.
Update on my earlier post -
I discussed this issue with another "x" maruti dealership works manager and he said, its not pulling basically its called drag. And they solve it by adjusting the cross member and change the tyre inside out and do the alignment. And he said its not considered as a problem. Even if maruti engineers come down to check the car they will say its Drag and they would first thing question you why you leave your hands while driving. Which is not appropriate. And then it becomes tu tu mein mein.....
__________________
Achtung Baby__
Thread Tools
Swift Diesel, Saga continues. The DIESEL experience! Part II Jaggu Long-Term Ownership Reviews 295 7th October 2008 08:58
ZING ZING Sound @ SWIFT ZXI Front Left Tyre. Travelbug Technical Stuff 11 19th September 2008 17:15
Long drives on my swift..left knee pain rajshenoy Technical Stuff 24 26th November 2007 09:37
Confusion between getz Diesel and swift diesel ? rreddy18 Hatchbacks 24 20th July 2007 13:14
Help Choose: City vs Fiesta Diesel vs Verna Diesel vs Swift Diesel aseem Hatchbacks 18 13th April 2007 15:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
