Old 4th November 2008, 12:31   #121
Swifty2008's Avatar
I had the same issue with my Swift VXI ABS, Petrol. The car was steering to the left always when I take my hands off the steering. There was an issue with the shocks in the front. I got it resolved in Sai Service MASS, Funkewadi. If you want, I can give your details of the fix.
Swifty2008 is offline   Reply With Quote
Old 4th November 2008, 19:15   #122
white_vdi's Avatar
Thanked: 18 Times
@ swifty2008 : please give the details of the fix. it would be of help to many inc me.
white_vdi is offline   Reply With Quote
Old 4th November 2008, 20:20   #123
karankapoor's Avatar
some days back i was also having the same problem in my petrol swift
running on 195/60/15 es100,went to my tyre wala he did the rotation and the problem was solve
karankapoor is offline   Reply With Quote
Old 5th November 2008, 13:01   #124
Swifty2008's Avatar
Please wait till this weekend. I will get you the exact details from SA @MASS. I will be going to the MASS this weekend to get my ignitor replaced.
Old 5th November 2008, 17:52   #125
tush's Avatar
Originally Posted by Swifty2008 View Post
MRF Tyre tracks in Nagar Road is good.
Adjacent to it, you can find Darshan Tyres also.
You can take an appointment by calling them:
The MRF Tyre Tracks contact nos are:
020-65208002
MOB: 9850880088
Hope this helps
Thank you for this information Swifty2008.
Yes definitely, that will help everyone of us who has a similar problem in their car.
Yes that is correct and the very first step to try resolving this issue if it occured due to tyre rotation in the first place.
tush is offline   Reply With Quote
Old 10th November 2008, 16:34   #126
Swifty2008's Avatar
@tush
This time, when I went to MASS to replace my ignitor, I asked the SA about the last service in which he rectified the side pulling. He said, he replaced both front struts.
I even got a duplicate bill. If you want the part #, please let me know.
Old 14th November 2008, 14:05   #127
Mushroomz's Avatar
Wink
@Tush, any updates??
Mushroomz is offline   Reply With Quote
Old 15th November 2008, 00:17   #128
tush's Avatar
@tush
Good thing. If possible share the snap of the part if you happen to have it.
Hey why you laughing bro. Now i wont give any updates.
Old 18th November 2008, 09:39   #129
Swifty2008's Avatar
@tush: Please find the details below:
Part Code:
BSO
Part Description:
FR Both Strut O/H
I was not charged for them as it was covered by warranty. I had replaced this in Sai Service MASS, Phugewadi.
Old 28th September 2010, 11:44   #130
Thanked: 152 Times
I have swift 1.2 which has done 1500 kms( 6months since purchase) the car pulls to left though the steering remains straight. I had shown to maruti service centre and they did wheel balancing but still problem persist . There is a whoosh sound coming from front shocker whenever the car goes over bumps - what could be the problem? please could you help .
FrozeninTime is offline   Reply With Quote
Old 28th September 2010, 13:06   #131
Jaggu's Avatar
Thanked: 8,693 Times
Woosh sound is normal, that is the shockers working normal. Have you checked the wheel alignment, for pull to the sides that has to be checked first. Then try rotating tyres and see if it helps.
Old 28th September 2010, 22:47   #132
Thanked: 152 Times
@jaggu - I had done wheel alignment in MASS but the service center did not rotate the tyres. The whoosh sound was non existent initially when I bought the vehicle but after 1st service the sound become prominent so I showed it to another MASS - the service adviser said that he had cleaned the dirt accumulated in front shocker and for few months whoosh sound was reduced but now the whoosh sound is slightly more pronounced.
As per your advice I will get the tyres rotated and wheel alignment done once again but from an independent wheel alignment specialist .
lastly ,Should I change the stock JK tyres (185/70 R14 )? the tyres are noisy and small stones get embedded in the gap between tyre treads .
Old 29th September 2010, 10:22   #133
goandude's Avatar
Thanked: 455 Times
When I got my Dzire VDI in july 09 the car was pulling to the left. Went to maruti dealer in Whitefield road. And after a few minutes he brings out the car and said it is fixed as pressure was low. I found that a lot of bull as I check pressures regularly. However I did find the pulling to the left reduced but not dissapeared. Next time i checked the tyre pressures I found that the dealer guy had overinflated the left tyre with 4 psi above reccommended pressure.
Anyway during next service got the alignment and rotation done and now the irritating pulling to the left has gone.
goandude is offline   Reply With Quote
Help Choose: City vs Fiesta Diesel vs Verna Diesel vs Swift Diesel aseem Hatchbacks 21 11th October 2009 17:44
My Grand Vitara Veering towards Left GRV Technical Stuff 6 5th July 2009 11:18
Fiat Uno (non PS): Car steers by itself Abhiraj Technical Stuff 13 14th June 2009 00:49
Indica V2 Diesel: Most dash board light blink like left/right turn indicators! bhuvanmisra Technical Stuff 7 18th November 2008 11:56
