Thread Tools
Old 5th May 2008, 18:36   #1 (permalink)
Default ikon ac: water condensation & engine jerk
2 problems i'm encountering in my 1.6:
1) water dripping from under the dashboard on the left side. seems to be condensation on the AC i'm guessing.
2) engine jerking with the AC on. now i know that with the AC on there will be a loss of power but will i notice it so much that when the engine speed drops a bit the car starts jerking? i mean i'm supposed to have 91 ponies. i find at slower speeds i have to drop a gear lower than when i have the AC off. incidentally i noticed a slight jerking a little earlier. coolant top up seemed to cure that, though there is still a bit of that with the AC off... not too bad though.
sorry if these topics have been discussed earlier but i find it difficult searching AC topics because of the word length restriction :(
silver_shadow is offline   Reply With Quote
Old 5th May 2008, 19:05   #2 (permalink)
water dripping can be due to pipe after evaporator being blocked
check to see if vaccum pipe which runs to inlet manifold is connected.
__________________
Zindagi ek rangmanch hai aur humsab kathputliyan hain
Sabki dor uparwaleke hatho mein hai kab kiski dor khch jaye koi nahi jaanta
Jr Godzilla is offline   Reply With Quote
Old 5th May 2008, 19:10   #3 (permalink)
ramie2400's Avatar
Hey man I also faced the same problem in my 1.3exi Ford ikon 2002,i still remember i drove my car at the max speed of 70kmpl to alibagh with full jerking issues.I showed my car to almost 3 service centers in Mumbai,but none of them were able to find the cause of it,even changed the Hi-tension cables,filters,oil-pump,spark plugs,opened the tapet head did settings,re-flashed ecm still the problem used to start after 3-4days after the car came from servicing,in last 6months the average dropped rapidly and last i remember in 500rs fuel it only ran 23kms finally sold the car for 1L
Thread Tools
ikon water pump cost? silver_shadow Technical Stuff 11 16th September 2008 20:54
SWIFT Petrol Engine jerk subbarao Technical Stuff 15 19th July 2008 07:36
Ford Ikon: A/c Water Diverter Valve problem Absar Technical Stuff 12 16th May 2007 02:38
water condensation in oil tank? babe_on_wheels Technical Stuff 6 24th August 2006 19:18
Engine jerk/glitch Abhay Technical Stuff 17 8th July 2006 22:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
