Old 14th August 2010, 18:43   #31
dhanushs's Avatar
Thanked: 4,504 Times
Originally Posted by gd1418 View Post
Two Ford Ikons reporting ignition coil failure. Something very rare. Coils are known to last long, very long.
My '73 model Amby, sold in '90 had its original Lucas coil intact and working beautifully..
Well, this a problem most common to Ford IKONs. There are numerous ignition coils gone kaput in this forum itself. Some went dead within just 2-3 years of ownership and about 25-35k kms. But I guess Ford has now solved this issue and the newer versions are much more durable (hopefully). - Just like Honda's fuel pump.
Old 14th August 2010, 20:12   #32
mooza's Avatar
Thanked: 271 Times
Yes, there is another Ikon owner I know, who recently changed his ignition coil here in Bangalore.
I hope my new coil lasts at least until I upgrade to the next set of wheels in a couple of years !
mooza is offline   Reply With Quote
Old 31st July 2011, 19:26   #33
sportz_kruzer's Avatar
Default '98 daewoo cielo vibrating at idle
well, I have 98 model cielo GLE euro 1 model (w/o egr) distributor type ignition, clocked 1,10,000 km. CNG w/o emulator & w/o timing advancer.
The problem is the car vibrates at idle- enough to cause irritation. the vibration is at around 950-980 rpm. its worse when ac is on and more so when in cng mode. the vibes VANISH at 1000rpm onwards - dead smooth!
idle vibes are both in cng and petrol modes - at 950rpm
apart from this the car is is great condition -
17km per kg on CNG city/24km per kg on highway
18kmpl on petrol highway/ city not sure.... (tankful 2 tankful methods)
have checked/done the following:
replaced throttle body including tps sensor and iac valve - reset ecu
replaced engine mounts.(but not original)
replaced rotor dist ignition wires spark plugs - reset ecu
air filter fine, engine oil - castrol edge
tried increasing idling - but ecu adamantly brings it back sooner than later no matter how high i set the idle.
compression 210psi on all 4 cyls - but on adding oil it was something like 240 270 250 270
i can physically see the engine vibrate in the bay. problem is only at 950rpm, more so with AC on. the car feels like dhrrrrrrrrrrrrrrrrrrr at idle.
experts please help! i am obsessed on solving this problem just love this car - the way she glides.
BTW i'll also be happy if some one can teach me how to permanently increase idle to about 1100 rpm.
NOTE: I don't want to sell this car or get rid of it - related suggestions will not be appreciated.
sportz_kruzer is offline   Reply With Quote
Old 1st August 2011, 11:23   #34
Default Re: '98 daewoo cielo vibrating at idle
Note from Team-BHP Support : We do NOT permit bumping up your own query. Such posts are classified as SPAM. Please do NOT inconvenience other users by bumping up your own posts.
sportz_kruzer is offline   Reply With Quote Received Infraction
Old 1st August 2011, 13:26   #35
Excuse me??? My query was posted as a new topic and has been "moved" in to this discussion without me doing anything...kindly check and revert the operation...i am looking for a solution to my problem ,i aint bumping into nobody. thanks!
Speedometer Needle: Shaking & vibrating Styler Technical Stuff 12 21st February 2016 16:05
Clutch friction plate hub shaking: Root cause? dhanushs Technical Stuff 32 15th December 2015 20:13
Puzzling (and expensive) problem with Idle Speed ISA in Santro silverbyte Technical Stuff 0 15th July 2009 18:28
IKON 1.3 - Engine Dies, gets back to almost normal !! pkumar Technical Stuff 14 19th January 2009 17:34
Shaking Vehicle while filling petrol - will it help? kdeepakk The Indian Car Scene 70 30th July 2007 11:34
