| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: May 2006 Location: ****
| Of late I've been facing this problem of a judder (for a split second) when I downshift from 3rd to 2nd (speed @ ~ 30 kmph & RPM near idling).This is not a consistent behaviour and happens every now and then. Am I doing something wrong here ? Also when I accelerate in 1st/2nd gear,I can sense slight engine movement as if the engine mounts are absent and the engine has been tied via ropes or something ;-)) Any ideas ? Thanks, rb2399 |
| | #4 (permalink) | |
| BHPian | Quote:
In my case (1990 Nissan) the original mounts were there for over 8 yrs (thats since I know the vehicle - the mechanic said these are originals) until the left side got ruptured probable cause could be due to high prssure power steering hose ruptured and oil on the mount. checking mounts need a technical eye - can be seen with hood open, look at the mount and ask someone to start / turn off / start / turnoff ignition you will notice engine movement forward backward on a defective mount. easy on rwds The mounts are damn expensive and since your vehicle is new should be under warranty get it checked / changed. Driving with a broken mount has very serious effects to the exhaust system especially the rubber hooks, clamps which will snap and worse it may tend to break at muffler joints.
__________________ Zindagi ek rangmanch hai aur humsab kathputliyan hain Sabki dor uparwaleke hatho mein hai kab kiski dor khch jaye koi nahi jaanta Last edited by Jr Godzilla : 14th May 2008 at 11:49. | |
| | #5 (permalink) |
| BHPian Join Date: Jun 2007 Location: Chennai
| ---Experienced in an old (much older than T-BHP abbreviations, in fact the original) Civic. Replaced exhaust due to general wear, but the new one broke at the manifold. When I went back to the fitters they dug a little deeper and found the reason to be worn out engine mounts. They replaced the part under warranty, as they had failed to diagnose the problem, which was decent. Of course, I got the mounts done first. But that was a fifteen-year-old car! |
| | #6 (permalink) | |
| Quote:
I've observed the engine movement.It is more on sideways rather than backward/forward as you mentioned though not too violent | |
| | #7 (permalink) |
| Senior - BHPian | @rb2399: check this thread out as well..- http://www.team-bhp.com/forum/modifi...placement.html (Sur 'mounting' Issues - Safari Engine Mount Replacement)
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx |
| | #9 (permalink) |
| Senior - BHPian | If you go through my previous post, the link mentioned there would give you the cost, that of course are from general market. I do not know the ASC rates.
« Using a battery tender to revive discharged battery
Ikon 1.6 : Apollo Acceleres : Early Tyre Wear Issues-Need Advice »
| Thread Tools | |
Similar Threads | ||||
| New Safari or Used Safari-Help EDIT: Booked New LX now | gops | SUVs, MUVs & 4x4s | 61 | 23rd April 2008 16:44 |
| New Safari soon? | jkdas | The Indian Car Scene!! | 10 | 22nd February 2008 12:24 |
| Why Safari? | GTO | The Indian Car Scene!! | 187 | 29th January 2008 03:53 |
| What to choose safari petrol or Safari diesel 2.2L | 007 Bond | SUVs, MUVs & 4x4s | 22 | 31st August 2007 21:56 |
| Safari TCIC LX or Safari DICOR LX | arindam | SUVs, MUVs & 4x4s | 19 | 10th January 2007 16:42 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
