Old 15th December 2014, 20:18   #181
Reinhard's Avatar
Thanked: 346 Times
Default re: Black smoke from diesel engines
Originally Posted by ISO View Post
That is why in Damam city of saudi Arabia Diesel vehicles are banned. Even Bus public transport is on petrol.
That + the situation that you get petrol when you open water tap in that part of the world
Reinhard is offline   Reply With Quote
Old 16th December 2014, 10:19   #182
vinayrathore's Avatar
Thanked: 287 Times
Can we give the writer of that article an Award?
Yeah right.
What a path-breaking article this must be.
I too was wondering how is that possible. But the way its written, the language lured me into believing it .
Anyways, I will surely get the EGR valve checked too.
vinayrathore is offline   Reply With Quote
Old 16th December 2014, 16:10   #183
Thanked: 365 Times
Vinay did you check with Naveen that if he can clean EGR and Intercooler first ? Intercooler cleaning is straightforward as it is similar to radiator.
I do not know about EGR though , Can experts on this thread comment if EGR cleaning is possible at FNG ? Also should EGR cleaning be done as preventive maintenance ?
amitk26 is offline   (1) Thanks Reply With Quote
Old 17th December 2014, 10:51   #184
Thanked: 287 Times
Hi Amit,
Naveen already checked and cleaned Intercooler and related plumbing but did not touch the turbo and EGR. I guess opening and cleaning EGR should be a straight forward job?
Old 17th December 2014, 11:04   #185
a4anurag's Avatar
Thanked: 11,008 Times
I'll suggest you open the EGR valve and get it cleaned. Please don't touch the Turbo as it is sensitive mostly, check the plumbing for the Turbo.
Anurag.
a4anurag is online now   (1) Thanks Reply With Quote
Old 20th May 2015, 13:25   #186
rmk
rmk's Avatar
I am facing a similar issue with my i20 crdi (the 5 gear one). The car is 4 years old with just 27k on the odo. 6 months back i noticed that the car was belching black smoke on red lights everytime i accelarated hard. The car was rarely used those days( once in a week or so), so i guessed that would be the issue. 2 months back, the issue was becoming worse, black smoke in every 1-4 gears during turbo spools visible in the ORVM. And thick black smoke during sudden revving during idle. Mileage also took a hit and dropped to 10+kms, initialy i was getting around 19+.
Took it to the service centre and they said it might be because of a block in the EGR. They cleaned it and i took it out for a drive, smoke wasnt very visible this time but the FE had improved and was now 19+ again. Was all happy, and then recently the ghost seems to have come back. Belching thick black smoke during accelaration (i never floor the pedal, rarely ever use turbo for the kick of it). I followed my car to see how bad it was, and it is really really bad. Ive never seen a new diesel car emitting this much smoke. And i am very very concerned. Can anyone post your valuable insights on this
Fact file.
1. 27000 on the ODO. 4 years old.
2. Cleaned the EGR. Still belching thick black smoke during revving (past 2000rpm)
3. Sedated driving style. Shifts gear at 1800-2000rpm (should i rev more?? )
4. Engine noise on idle has increased. Sounds like my friends 10 year Accent now.
rmk is offline   Reply With Quote
Old 20th May 2015, 13:32   #187
rakesh_r's Avatar
Thanked: 573 Times
Fact file.
Do you stick to one fuel station to fill Diesel? I suspect Adulteration.Try filling from a different well reputed fuel station (I always prefer BPCL).Also do check the fuel filter and air filter.
rakesh_r is offline   (1) Thanks Reply With Quote
Old 20th May 2015, 14:10   #188
a4anurag's Avatar
Fact file.
2. Cleaned the EGR. Still belching thick black smoke during revving (past 2000 rpm)
3. Sedated driving style. Shifts gear at 1800-2000 rpm (should I rev more?? )
Engine noise (read clatter) has increased; black smoke. How long has it been since you cleaned the EGR last?
I can think of:
  • Air filter needs a change;
  • Fuel filter needs a change and if possible get the fuel tank cleaned;
  • Get the MAF cleaned so that fuelling is correct to the engine;
  • EGR needs cleaning again;
  • Check if all injectors are working!
  • Last but not the least try changing the fuel station.
a4anurag is online now   (2) Thanks Reply With Quote
Old 20th May 2015, 14:24   #189
Thanked: 243 Times
... Belching thick black smoke during accelaration (i never floor the pedal, rarely ever use turbo for the kick of it). I followed my car to see how bad it was, and it is really really bad. ....
Almost certainly this is a turbocharger related issue. The engine simply isn't getting boost air from the turbo.
It could be connecting hoses, clogged intercooler, blower wheel or turbine caked with dirt/carbon, or whatever.
There is a remote chance that the HP fuel pump metering has gone awry; but this is very unlikely.
Old 20th May 2015, 16:54   #190
kpzen's Avatar
Thanked: 1,142 Times
In that case, would the engine show some signs of sluggishness ?
Asking this for my Getz, which is emitting black smoke under hard acceleration.
Last October, EGR cleaning sorted out this issue and I'm doubting if that could be the culprit again.
Car in total has done 154k kms and approx 14k kms post EGR wash.
Old 20th May 2015, 17:02   #191
akshay4587's Avatar
Thanked: 1,508 Times
Default Re: Black smoke from diesel engines
Was facing the same issue with my Linea sometime back.
Excessive smoke and lack of power every now and then.
Mechanic suggested to disconnect the EGR, did so, and no more black smoke,and lost power is back as well
Old 20th May 2015, 17:09   #192
kpzen's Avatar
Ironically, my car doesn't show any signs of power loss.
After EGR delete, did your mechanic delete the error code as well ?
Old 20th May 2015, 17:26   #193
Thanked: 243 Times
Hmm, this is confusing. If boost air is not reaching the cylinders there would be a noticeable loss of power/acceleration.
I think you better try what Akshay has suggested.
Old 20th May 2015, 17:38   #194
akshay4587's Avatar
I am lucky to have last of BSIII Linea MJD.
No Check engine light and error on MID.
BSIV cars have CEL on after disconnecting EGR.
Old 20th May 2015, 18:20   #195
kpzen's Avatar
Will clean the EGR and intercooler this weekend and check.
Do Diesel engines generate more Torque than Petrol engines? ex670c Technical Stuff 224 25th November 2013 12:20
Difference between old engines and new engines (petrol and diesel) srijit Technical Stuff 32 26th January 2011 10:20
black smoke from exhaust 2fast4u Technical Stuff 32 10th August 2010 13:48
(Royal Enfield) Thick black smoke when revved hard. ron_9191 Motorbikes 43 13th October 2009 13:50
Verna crdi: black smoke from exhaust live2drive Technical Stuff 32 26th November 2008 11:43
