Thread Tools
Old 14th May 2008, 19:14   #1 (permalink)
Default Using a battery tender to revive discharged battery
My 93 gypsy has been sitting for the past 3 months and wont start up. Can I use a battery tender that I use for my motorcycle? Its a 12V 1.25 amp Deltran tender that I use for my beemer and can plug into the cigaretter lighter socket to juice up the battery.
Here is the tender I have: Amazon.com: Deltran SuperSmart Battery Tender Plus 12-Volt 1.25 AMP Battery Charger: Automotive
P.S: Does the gypsy even have a cigarette lighter socket??
__________________
93 Gypsy
03 BMW F650 CS
07 C220 CDI
03 Santro
96 M800
Previously..
00 E55 AMG
05 RSX Type-S
95 Jetta III
94 Escort
xxaarraa is offline   Reply With Quote
Old 14th May 2008, 19:55   #2 (permalink)
Sankar's Avatar
Somewhere i read that battery tenders & optimizers that are intended for motorcycle batteries are not sufficient enough to restore a dead automobile battery.
You may nevertheless try it out, the only con being it might take a really really long time to charge up.
Doesn't the tender have the crocodile clips to connect it directly to the battery?
__________________
"Auto racing, bull fighting, and mountain climbing are the only real sports... all others are games."
Ernest Hemingway
Sankar is online now   Reply With Quote
Old 14th May 2008, 19:56   #3 (permalink)
Sam Kapasi's Avatar
This is fine for regular use. I do not think it will juice up a dead unused battery.
I suggest you hand over the battery to a battery- walla for charging. If the battery is still working, you will have it back the next day, fully charged.
But I suspect you may need a new battery.
__________________
Live the YetiLife®
MA-DONNA! MA-DONNA! MA-DONNA!
Thread Tools
OEM car battery life - How long did your OE battery last? shuvc Technical Stuff 125 16th July 2008 21:48
Which Battery ? abhibh Modifications & Accessories 23 29th July 2007 07:24
Battery Meter abhibh Technical Stuff 5 1st June 2007 14:02
battery issue premdiv Modifications & Accessories 0 7th July 2006 22:13
Battery Woes! sparkglow Technical Stuff 10 3rd July 2006 23:25
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
