Thread Tools
Old 15th May 2008, 13:18   #16 (permalink)
Infractions: 0/1 (4)
Well well, who said that she can't go mountaineering. Its just a clutch
This is one hell of an Indica!
And does the most beautiful routes!
Tanveer, hope you'll be getting the engine mounts done too.
(And the timing belt?).
anupmathur is online now   Reply With Quote
Old 15th May 2008, 13:19   #17 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Its the pressure plate giving away before the clutch plate. But since you need to down the tranny, change clutch, pressure plate, carbon, bearing etc etc. Will give you another "clutch life time" of peace of mind.
Chances are with weaker pressure plate the plate also will soon wear out.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 15th May 2008, 13:22   #18 (permalink)
Team-BHP Moderator
tsk1979's Avatar
@anup, the engine mount (LHS) got changed, other RHS was perfectly fine.
The timing belt was changed at 90K kms, 10K before schedule as I did not want to push luck
@jaggu, well thats what I feared.
A factory fitted clutch always has the best life. With refitting I am guessing a life of another 40-50K kms max.
Any idea whats the part cost of the same for an indica. Of course, I am not going to TASS.
__________________
Old 15th May 2008, 13:33   #19 (permalink)
Team-BHP Moderator
Jaggu's Avatar
I dont have much idea about Tata parts, guess estimate 5k job. Ask around and find which "make" is the best replacement part for the car, even the newer turbo cars clutch can be considered if its a straight fit since they will be designed to take more load.
Also while doing the job, clean and lubricate the shafts and replace the cable if they are old. Doesnt cost much but will give you great results.
__________________
Old 15th May 2008, 13:35   #20 (permalink)
Should give more than the dismal figure you are fearing!
Any half decent w'shop would do this job well enough, as long as you buy the parts and 'supervise' the job! One of the big advantages of driving THE most popular taxicab in the country!
Old 15th May 2008, 13:38   #21 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Ok, so that does it.
One question though. Can the problem be due to something else?
for example if I change pressure plate, clutch plate and release bearing, and the problem still persists?
I want to rule out all causes which can contribute to this behavior before opening the clutch.
__________________
Old 15th May 2008, 13:43   #22 (permalink)
I'll go down on record that this will cure my favourite Indica's problem! 95%.
Old 15th May 2008, 13:49   #23 (permalink)
Team-BHP Moderator
Jaggu's Avatar
If your engine is in tip top shape 99.99% its clutch. Check for all free play on the tranny when you open up, and flywheel, if its in shape, need phasing/replacement etc.
__________________
Old 15th May 2008, 14:23   #24 (permalink)
n_aditya's Avatar
I have the same problem where there is a lot of shudder and judder at very low rev's in first gear. Once the car has gained momentum its fine.
I got the clutch replaced at around 30k Kms (at a local garage and it cost me around 4.5k) and the car has done 53K kms now. I know the clutch is taking a beating due to the race spec headers. The low end torque is highly compromised. Contemplated on switching to street spec headers but since I rarely drive in stop and go conditions I have dropped the idea. Mainly i'm attached to the power of the race spec headers.
My guess is adjusting the clutch could solve the issue to some extent. The problem is lesser when the a/c is off during stop and go conditions so managing it that way.
Old 15th May 2008, 14:40   #25 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Too low rpm and hence car falling off power band, resulting in shudder. Solution do power launches
__________________
Old 15th May 2008, 15:18   #26 (permalink)
n_aditya's Avatar
I agree Jaggu. This should be done especially at night when the mogrels are all out to give a chase. Quite a sight.
But the cops wouldnt be too happy. Plus others get scared of the sound and glare menacingly.
Old 15th May 2008, 15:23   #27 (permalink)
Deeps's Avatar
I paid 2300 for clutch plates, pressure plate and bearings. Labour should be another 500 or so.
__________________
Stupidity is not a handicap! Park somewhere else!
Deeps is offline   Reply With Quote
Old 15th May 2008, 19:21   #28 (permalink)
iraghava's Avatar
If you replace all the 3 components & your flywheel doesn't have a problem then the problems should go away for good.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 24th June 2008, 23:33   #29 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Default New clutch!
Finally I took the plunge. After the gear lever linkage breakdown issue, I decided to go for the entire clutch change, and also some "local engineering" for gear lever instead of Tata "Pin".
Clutch plate kit cost me 2200. Clutch plate. Pressure Plate and Release bearing.
Clutch fork was bent, so the mechanic suggested indigo TDI fork as its a perfect fit and much thicker, so it won't get bent.
Other than that gear oil was changed(3 liters) and some welding was done(for a plate on the body).
My mechanic suggested that since even new plates on the housing start wobbling after a few kms and make noise, why not get for a small "taanka"
Apart from that he also suggested that since the gear lever linkage is supported by a narrow pin, its weak and play comes very soon.
So he got the hole widened by a machinist, and put a thick bolt there instead of narrow pin.
No more worries.
Anyways here are the pics
1. Gear box
2. Old plates. They were totally cooked. 100,000kms of torture shows. Click on images for full size
The End result is mind boggling. The clutch is ultra soft. Infact I had a hard time getting used to it. There is no judder. the pickup is better and she's a lot more comfortable to drive.
All parts used were TATA OEM, and I got castrol gear oil.
__________________
Old 25th June 2008, 09:16   #30 (permalink)
jav
can you upload more pics of the clutch change
jav is offline   Reply With Quote
Thread Tools
Severe back pain and driving! shivmarwaha A Collection of the best threads 82 9th June 2008 03:41
Judder while downshifting (Safari 2.2) rb2399 Technical Stuff 8 15th May 2008 00:44
Severe Gear problem in i10 amitjinds Technical Stuff 22 6th May 2008 19:18
terms and conditions streetlife Technical Stuff 1 6th October 2005 09:57
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
