Thread Tools
Old 25th June 2008, 10:48   #31 (permalink)
Team-BHP Moderator
tsk1979's Avatar
No more pics.
The job is very labor intenstive. You have to unmount the engine, remove the gbox, open the gbox, replace the plates etc., and refit.
Total time taken = 4 hours with 2 people working.
__________________
Reclaiming.....!
Old 25th June 2008, 14:57   #32 (permalink)
No more pics.
in RWD also do you need to unmount engine or is it only the gearbox that comes apart?? would it be as labor intensive as fwd.
i guess my clutch is cooked up like urs. but its still doing its job +2 yrs now (i have reduced the idling to 600 from 650 so as to dump the clutch and crawl in traffic)
my next job is the clutch now.
__________________
Zindagi ek rangmanch hai aur humsab kathputliyan hain
Sabki dor uparwaleke hatho mein hai kab kiski dor khch jaye koi nahi jaanta
Jr Godzilla is offline   Reply With Quote
Old 25th June 2008, 15:00   #33 (permalink)
Team-BHP Moderator
tsk1979's Avatar
No idea about RWD, but I suspect the gearbox is attached to the engine in RWD also. From what I remember, the 118NE was a RWD and had gearbox in the front.
__________________
Reclaiming.....!
Old 25th June 2008, 15:05   #34 (permalink)
thanks for keeping the thread alive and the pics too. if you see my garage pics you will note the gearbox is almost under firewall.
kindly pm me the labor involved to get a rough idea of waht i should expect to fork out this side.
__________________
Old 25th June 2008, 15:17   #35 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Different cars require different things.
For example in the indica
1. Remove battery
2. Remove Air filter box
3. Remove engine and gbox mountings
4. Dislodge gearbox
5. Open gbox change parts
6. Refit all
In all 4 hours labor 2 people. cost is around 800rs. I paid 950 because of welding and machining custom job.
__________________
Reclaiming.....!
Old 26th June 2008, 11:02   #36 (permalink)
thanks for the info.
__________________
Old 26th June 2008, 11:12   #37 (permalink)
You seem tobe paying peanuts for your jobs, please post the address/ directions to your mechanic/ workshop.
1. Remove battery
4. Dislodge gearbox
6. Refit all
__________________
Remember, its a machine
Old 26th June 2008, 12:02   #38 (permalink)
rkbharat's Avatar
1. Remove battery
4. Dislodge gearbox
6. Refit all
tsk1979, I don't think you will have to do all that to open gear box. gear box can be dismounted from the lower end, without dismounting anything you mentioned above.
Generally local mechanic do it as mentioned by you because they do not have a hydraulic jack to lift the cars to a position.
__________________
Cheers.....Rajiv
SX4-ZXi, May 2008, 1500KM, FE City 10.5-12, 100% AC
Maruti 800, 1999, 7800 KM, 19KM/L
Indica V2, Sold at 97234KM
rkbharat is offline   Reply With Quote
Old 26th June 2008, 12:23   #39 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Yes rkbharat, in the Company service center where there is a hydraulic jack, the circus is less.
__________________
Reclaiming.....!
Old 29th June 2008, 01:24   #40 (permalink)
Hyundai A.S.S. had not been able to solve this problem at 1,00,000 KM service for my Santro 2001. I guess its time to unclutch the factory fitted clutch and hug a new one.
I think I'd get it done at a Local Workshop.
barcode is offline   Reply With Quote
Old 29th June 2008, 04:56   #41 (permalink)
DirtyDan's Avatar
A factory fitted clutch always has the best life. With refitting I am guessing a life of another 40-50K kms max.
Your new clutch will last like the original assuming that the replacement parts are of the same or better quality. Why would you think it would not last? I hope they also changed the pilot bearing. This holds the tranny input shaft.
__________________
The only tyrant I accept in this world is the still voice within. -Gandhi
DirtyDan is online now   Reply With Quote
Old 29th June 2008, 08:56   #42 (permalink)
vid6639's Avatar
Could be the clutch alignment. The factory alignment will have the best possible alignment so a better life. The manually aligned one may not always be proper and end up having a slightly shorter life due to misalignment.
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Old 29th June 2008, 12:28   #43 (permalink)
Team-BHP Moderator
tsk1979's Avatar
yup, everything was changed.
However the alignment thingy may be the reason?
Maybe it does last another 100,000 Km. But then I won't have the car for that long!
__________________
Reclaiming.....!
Old 29th June 2008, 12:44   #44 (permalink)
There's really not much that can be done by way of 'alignment' in the sense of concentricity of the involved parts. There is hardly any other alignment that comes into effect except 'free-play' of the pedal.
What might be happening is that SPARE parts are built with larger tolerances and hence concentricity itself is compromised more than at OEM level.
Looking for more gyan on this.
Old 29th June 2008, 12:52   #45 (permalink)
vid6639's Avatar
AFAIK the clutch alignment is extremely important. When the clutch is replaced the new plate is put in position by an alignment key. A wrong alignment and you will end up having premature clutch wear as in uneven wear. This was a problem which was observed in the early batch of swift's. There was clutch judder even when the car's had done only a few thousand kms. This problem was traced down to faulty alignment of the clutch. It was not the problem with the clutch as not all swifts had the problem.
I had done some r&d on this when I was looking at buying a small car. Found out about this from my MASS guy. Then when I bought my alto it had some clutch problem which was replaced under warranty. I saw the entire process with my MASS guy explaining how it was done. The alignment is very important.
__________________
(o.o)
( X )
Thread Tools
Bangalore Traffic police updates traffic at 40 odd junctions of city on its web site. balechaparka The Indian Car Scene!! 25 6th July 2008 01:31
Severe back pain and driving! shivmarwaha A Collection of the best threads 82 9th June 2008 03:41
Judder while downshifting (Safari 2.2) rb2399 Technical Stuff 8 15th May 2008 00:44
Severe Gear problem in i10 amitjinds Technical Stuff 22 6th May 2008 19:18
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
