| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Team-BHP Moderator ![]() | My Indica has started giving severe clutch judder in crawling traffic conditions. For example in very slow traffic when I am slowly releasing clutch and doing half clutching(needed in crawl conditions), the whole car shakes like crazy. However there is no power loss or clutch slippage and the car still touches 130+ given a long enough stretch of road. Even pickup is pretty good and mileage is fine. Since this is the original clutch I am not in favor of opening the gearbox, and since the clutch plates are fine, why replace them(the car has done 104000+ kms.) So I am wondering what is the cause of this judder. Is it the springs? Can I get the springs changed or do I need to change the clutch plates. Or is it something else? The transmission oil is almost 20K kms only and is due for replacement next service, could this be the cause of judder? There is judder also if I floor the accelerator on a slightly higher gear than necessary, for example If I am doing 25 and engage thrid gear So the solution is now to rev her to a slightly higher range before engaging the next gear.
__________________ .--- ..- ... - - .-- --- -- --- .-. . -.. .- -.-- ... - --- --. --- !! |
| | #3 (permalink) |
| Senior - BHPian |
__________________ Remember, its a machine |
| | #4 (permalink) | |
| Senior - BHPian | Quote:
__________________ Land's end, journey's beginning - Safari Dicor VX 3.0L 4x4 | |
| | #5 (permalink) |
| Team-BHP Moderator ![]() | If the clutch plate is gone, won't this mean other symptoms like power loss etc., I think I will go ahead with the transmission oil change, and get the gearbox mounts etc., checked, if it involves gbox opening and stuff..... Well Then so be it.
| | #6 (permalink) |
| Senior - BHPian | You have a point. Try something on an open stretch (highway/expressway) if possible - in 4th gear, let go the accelerator pedal completely & let the car coast on its own revs. I'm not sure at what rpm this would be for the Indica but just try it. If your clutch is otherwise OK, the car will trundle along at a steady speed without any jerks. If there is a problem, the speed will fluctuate as will the revs & the car will stall.
| | #7 (permalink) | |
| BHPian Join Date: May 2007 Location: Noida
| Quote:
Upon asking, the mechanic expalined me that this happens when there is a 'flat spot' on the clutch plate just as in tyres. He showed me the damaged clutch plate in which there was a part of the asbestos lining missing (a burnt clutch). In such cases, there is no loss in power once the clutch is engaged properly. Hope this expalins your problem.
__________________ "Alcohol doesnt solve any problems", but if you think again, neither does milk... | |
| | #8 (permalink) | |
| BHPian | TSK exactly facing the similar problem and this is a Nissan. all your above findings same as mine. Those judders shudders are real scary not only for the driver but on two occassions I scared pedestrians at a Zebra crossing. It is awful. I did show the mechanic who said that it is clutch problem. But as you I am feeling no power loss and this will happen only at start or being in 2nd gear city driving. I HAVE AN EASY WAY TO AVOID THE NOISE - if your rpm is perfect (as required) in idle, slowly release all clutch, no throttle and let it move slowly quite hard in bumper to bumper situation but still better than the violent judder. Also in my case(hydraulic clutch self adjusting) I have a doubt (no time yet to get it done though) is the clutch fluid which on one occasion was empty letting the pedal loose but i may not have had air in as i immediately topped and the clutch was fine. on second occassion the fluid was all black pointing to possibly master cylinder, just soaked all of the fluid with tissue paper , topped up with new fluid, checked later fluid is clean no leak on firewall or driver pedal inside car. Also noted the judder happens when the engine is reasonably hot mostly in traffic on open highways its there but very lightly felt. Also this judder happens in reverse gear when engine is hot. Suman done the 3rd / 4th gear movements no probs at all. TSK looking to hear from you. kindly update when u get it resolved. Quote:
or did you have to change pressure plate, release bearing, is it recommended to change the above and i guess there is some job to be done on flywheel also pls share your views.
__________________ Zindagi ek rangmanch hai aur humsab kathputliyan hain Sabki dor uparwaleke hatho mein hai kab kiski dor khch jaye koi nahi jaanta Last edited by Technocrat : 15th May 2008 at 12:44. | |
| | #9 (permalink) |
| Team-BHP Moderator ![]() | @Suman, I don't think the NA indica has enough low end torque to idle through 4th gear, though 3rd gear should be okay @Jr Godzilla, exact same problem here, and I also do the same, release clutch slowly at idle. But when AC is on the idle rate is high, and this problem comes. @akash, well this could be the problem here too, I have burned the clutch partially on many himalayan adventures due to getting stuck. Guess I will live with it and go for clutch plate opening at 110000kms
| | #10 (permalink) |
| Since it was a complete clutch overhaul, the pressure plate and the bearings were also changed. But as told my the mechanic, the culprit was the clutch plate only & could have rectified the judder by itself..
| | #11 (permalink) |
| Team-BHP Moderator ![]() | Since we are on the topic, The Alto faces this issue as well. Initially I was under impression that my clutch has worn out but there was no difference in pick up\top speed\mileage. Recently when I took my car to Tune up Plus(recommended by Pune TBhpians for servicing) He said this is common in all the Altos & only in newer generation cars they have changed the design & its fixed now. This involves changin fly wheel etc i.e. the whole assembly which is an expensive affair. Its not very frequent but whenever happens it is bad So what I would recommend is that check out if there are similar upgrades in clutch design for your car's clutch.
__________________ 180, 225, 150, ??? -> 159? |
| | #13 (permalink) |
| Team-BHP Moderator ![]() | Well well, who said that she can't go mountaineering. Its just a clutch ![]() @TEchnocrat, if it was a design problem the judder would have come earlier, not after 100000kms!
| | #14 (permalink) | |
| BHPian Join Date: Dec 2007 Location: Bangalore
| Quote:
So what is suggested - live with it or fix it? Techno, what did you do? | |
| | #15 (permalink) |
| Team-BHP Moderator ![]() | well even in alto it doesnt show initially but only after 25k-27k on odo & then there are some who havent faced it. EDIT: in HW's case after 43k Just posted as a pointer didnt mean that it is the same\similar issue ![]() @HW: I am not fixing it as its costs 4.5k or so, basically needs to replace with new clutch setup. Since this isnt much frequent I am not changing.
__________________ 180, 225, 150, ??? -> 159? Last edited by Technocrat : 15th May 2008 at 13:17. |
| Thread Tools | |
Similar Threads | ||||
| Severe back pain and driving! | shivmarwaha | A Collection of the best threads | 82 | 9th June 2008 03:41 |
| Judder while downshifting (Safari 2.2) | rb2399 | Technical Stuff | 8 | 15th May 2008 00:44 |
| Severe Gear problem in i10 | amitjinds | Technical Stuff | 22 | 6th May 2008 19:18 |
| terms and conditions | streetlife | Technical Stuff | 1 | 6th October 2005 09:57 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
