Old 16th May 2008, 08:41   #1
Default strange problem in my palio D
i recently encountered a strange problem in my palio D 2007 model.
this has happened twice now in the past 20 days, and i wonder whats it about.
when i start the car it starts without any problem but engine sounds very heavy, as if its under tremendous load. also the car doesnt revv in this situation even if i press the accelarator.
if i switch it off and start again, it starts normally.
anyone has any idea?
thanks in advance
model: palio D 1.9L, 2007 model.
kms done 17.5k.
no other problems till now.
garychopper is offline   Reply With Quote
Old 19th May 2008, 16:54   #2
aditya.86's Avatar
Goto the authorized service station and get the fuel pump checked. If needed it might have to be calibrated. Even i have experienced the same problem in my 2003 palio 1.9D.
aditya.86 is offline   Reply With Quote
Old 19th May 2008, 17:02   #3
HotChillyPepper's Avatar
Thanked: 215 Times
Yes that could be the problem. Or else any of the intake sensors got damaged. Service it asap
HotChillyPepper is offline   Reply With Quote
Old 19th May 2008, 17:08   #4
mobike008's Avatar
Thanked: 7,890 Times
Even i had similar problem with my viva crdi a couple of months ago. When you press the accelarator it does not rev and the car kind of halts ( while in motion).
however, this could not be replicated when told to my service advisor, so just got normal service done and it has disappeared and never re-surfaced again. It certainly has to do with the fuel pump.
Old 19th May 2008, 21:10   #5
Thanked: 11 Times
Was the 1.9d still available in 2007 ?
Old 20th May 2008, 08:50   #6
i think it got discontinued in january 07. i bought it in april, one dealer had only only 1 piece left and i got a good discount. wonderful car i must say, i am very satisfied till now.
thank you all for the help.
Old 20th May 2008, 13:18   #7
Thanked: 11 Times
Great selection, its a very nice car to run and own!!!
'Strange'st electrical problem in Fiat Palio 1.2 extreme_torque Technical Stuff 30 21st May 2011 14:14
Strange problem with Palio 1.6 stile vidushak Technical Stuff 10 17th May 2009 23:18
Siena1.6 - Strange problem nitinbhag Technical Stuff 28 26th October 2007 08:32
Strange Palio Problem? 1.2 ELX extreme_torque Technical Stuff 7 2nd October 2007 23:05
