Thread Tools
Old 18th February 2005, 07:19   #16 (permalink)
Team-BHP Moderator
Rudra Sen's Avatar
a. The starter motor is the trouble maker
b. This is a common problem for all Indicas.
This is something really abnormal!
Starter motor is doing nothing when the car is moving. So how that can be the cause for heating?
Coolant again, either good quality or bad has nothing to do with car heating up. Coolant has a much higher boiling point.Hence we use that instead of water. Off topic may be, but please check if your radiator cap is holding the right pressure.
It also can be and most likely so as tsk1979 says, it's thermostat switch problem. The only sure and easy way to solve this is to go with Psycho's solution.
Remove the original AC coil fan with a manual fan (switch it on as you start your AC).
But why all these with a new car?
I'll blame these service stations for this. Just go there and pile on. You're still within your warranty period.
Old 18th February 2005, 09:37   #17 (permalink)
sandeepmdas's Avatar
Hi All,
It seems that there is a misunderstanding as far as this topic discussion is concerned.
What Anu is trying to say is – and my problem is- the following scenario:
a. Cold-start your Indi(ca/go…whatever). It will start smoothly, waking up your neighbors.
b. Drive the car around for 20-30 minutes.
c. Now find an empty side street. We are about to start our test run and never do this in a busy street for godssake.
d. Stop the car without obstructing traffic. Take a deep breath and turn off the engine.
e. Try to start the car. Either it will not start or the starter will hesitate a lot before getting caught.
That’s our problem. The car starts in the morning -first attempt- but fails to start when the engine is hot.
Please read Anu’s first posting again. “(when) it is heated up, it will not start”. Apparently you guys mistook it as “it is heated up, it stops” or “it is heated up, it stalls”. All the remaining postings –thermostat, 9” fan, Thunda Raja-were based on this misunderstanding.
It is not a problem with heat exchange. This is electro-mech failure guys.
But I am a bit worried after reading that the problem persists even after a starter motor replacement. That’s real trouble.
I will keep you guys posted.
sandeepmdas is offline   Reply With Quote
Old 18th February 2005, 14:17   #18 (permalink)
Psycho's Avatar
Hey guys thanks for clearing that up:
1) Anyways if the case is not due to the starter motor, I would suggest that you get your deisel pumps pressure checked, it could be a bit high leading to the flooding of the cylinder, this usually results in the starter catching up and turning the engine without starting it... usually requires a few cranks before it starts.
2) Check for a air leak into your diesel lines.
3) If the starter motor does not start cranking the engine when it is hot then yes you will have to check both the electrical and the starter
By the way "Is the starter in the linked to this unit in such a way that it will not start cranking till the heater indicator goes off OR for a given period of time?" I need to know this as I do not own an indica and it will help troubleshoot this more accurately.
__________________
Learning is a continuos job that keeps me busy.
Old 18th February 2005, 15:55   #19 (permalink)
hianooo's Avatar
U should wait untill the heater indicator goes off and then start the car...
cheers
aNu
__________________
"Your future depends on your dreams"...
So go to sleep....
hianooo is offline   Reply With Quote
Old 19th February 2005, 08:57   #20 (permalink)
Psycho,
Thanks for your excellent inputs.
There is this LED light, which looks like an Anaconda that glows yellowish for some time, say 10 seconds. After that it goes off and then you can start. The car has 4 glow plugs, I learnt.
One more thing I noticed is that I can start the car if I try to start instantly –just immediately, literally- when the engine stops. For e.g the engine stopped while I was reversing, and I tried to start the moment it stopped, it restarted. But after completing the reverse, I deliberately allowed the engine to die and then tried to restart after 5 seconds. It refused to start.
Any clue?
sandeep
Old 10th March 2005, 08:55   #21 (permalink)
Team,
The problem with my car has been rectified.
Benz Automobiles –the best service facility for TATA in Trivandrum- did the following:
They replaced the Starter motor (made by Lucas-TVS).
The battery-to-motor wiring is freshly soldered and re-harnessed.
The car is now fine. Life is beautiful again, oops, not quite; there is the TDS cut from this month’s salary…
I think this is the right time to end my contributions to this thread.
Thank you guys, thank u all…
-Sandeep
Old 14th April 2007, 12:46   #22 (permalink)
nikhilv12's Avatar
I have the same problem with my indica.. The authorised dealer, here in trivandrum, blamed it on the starter motor, and replaced it.
It was working fine for around 2 months after that, when the same problem started again. But, now that i have a k&n air filter and a free flow exhaust, it does not happen all the time!!!
I took it to a local mechanic last week, he said it is the problem with the glow plugs!!!!
could you please help me out in this!!!
__________________
TOO FAST TOO FURIOUS!!!!
nikhilv12 is offline   Reply With Quote
Old 14th April 2007, 13:12   #23 (permalink)
hi,
Little off the topic ( not indica) but i am also facing same problem with my Ford lair with 20K done on meter.My car stops nearly after 15-20 kms of driving with AC on,but then i switch off the AC it goes fine! I went to the service station twice n they checked n cleaned n decarbonised things,but the problem still exists.I went to them again and now they came saying that my Fuel pump has to be replaced,as it gets over heated with AC load.Any suggestion ?
Vineet panwar is offline   Reply With Quote
Old 14th April 2007, 15:02   #24 (permalink)
zenopio's Avatar
get your heating plugs checked ..even my frends indigo has the same problem. he changed his heating plugs.its normal now
zenopio is offline   Reply With Quote
Old 14th April 2007, 15:35   #25 (permalink)
nitrous's Avatar
[QUOTEnikhilv12]But, now that i have a k&n air filter and a free flow exhaust, it does not happen all the time!!![/quote]
Is it a Petrol Indica or a Turbo diesel one?
__________________
hindu.com/mp/2008/08/25/stories/2008082522220200.htm
Old 14th April 2007, 21:01   #26 (permalink)
nikhilv12's Avatar
its a diesel, non turbo....
__________________
Old 14th April 2007, 21:18   #27 (permalink)
vivekiny2k's Avatar
Location: Loveland, OH (cincinnati area), jabalpur, chennai
i have had exactly thew same problem.
http://www.team-bhp.com/forum/techni...ont-start.html
the problem was starter motor, which wears out with time electrically (insulation getting weaker) and mechanically. Replaced it and it worked fine. before doing that you may want to check if battery is the culprit, by replacing the battery and observing the behaviour. highly unlikely though.
another thing people have suggested is hitting hard with a bat on the starter motor, which may release and start. i cud not try because it was not so easily accessible, and identifiable, didn't want to dent my engine :-D
the reason it starts instantenously is it's it's not as hot, but leaving it off for a few mins allows the engine to dissipate it's heat and starter absorbs it (is it called heat soak?)
__________________
______________________________________
with great power, comes great responsibility.
bigger the car, longer the cleaning time.
vivekiny2k is offline   Reply With Quote
Old 14th April 2007, 21:23   #28 (permalink)
vivekiny2k's Avatar
by the way, another component that fails is the solenoid (eletromagnet that momentarily completesthe circuit, built with the starter).
on net, there are step by step procedures on troubleshooting it. one of the links is given below.
Diagnose Engine No Start or Run
__________________
Old 17th April 2007, 09:45   #29 (permalink)
Hello all, same problem happened with my indica, the culprit is starter motor bush.
Get either stater motor replaced or atleast bushes cleaned or replaced, which has to be done by lucas-tvs, it is very very common to indicas.
appears nearly at 40,000 kms, if warranty is over simply get the bushes cleaned. If still in warranty get the motor replaced.that is the solution, do not go for battery change, as TATA guys will suggest, unless you have got your battery checked & declared dead.
__________________
Arun
arunforu1 is offline   Reply With Quote
Old 17th April 2007, 18:15   #30 (permalink)
vivekiny2k's Avatar
and get it done before it fails completely, having you to get it towed.
__________________
Thread Tools
palio D starting problem garychopper Technical Stuff 7 19th August 2007 20:39
Palio starting problem amit Technical Stuff 29 28th February 2007 10:42
starting problem of my zen zenopio Technical Stuff 2 14th February 2007 19:37
palio 1.2 starting problem. passionpurple Technical Stuff 8 8th June 2006 23:24
Starting Problem. zulfikar Technical Stuff 6 6th May 2005 10:04
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
