| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Hello, i have an Indica DLS around 18 months old... the problem with is that when it is heated up, it will not start ... only after around 5- 10 minutes it gets back to normal !! the prob: arises mostly when it is run with AC.... i had met the mechanic, but they dissapointed me by remarking that it is a very usal problem... is that so ??? now that the service , oil \ coolant changes are over.. but still the problem persisits :( any suggestions???... cheers aNu
__________________ "Your future depends on your dreams"... |
| | #3 (permalink) |
| BHPian Join Date: Sep 2004 Location: Melbourne
| Hey Buddy, I too have the above mini truck and have experienced a similar problem.....to solve this issue from my experiences are 1.Get the wiring to the fan of the car checked,probably the fan may not or ocasionally be functioning hence the overheating. 2.Use a good coolant if not using one. 3.Lastly,in extreme case there there might be a leak in the water jacket(i had this prob) get it checked a new one costs around 750bucks. PS: Do let me know if you fiand a solution other than this to your problem,it will help me too.
__________________ Regards, Gaurav "I'm not lazy...just energy efficient!" © |
| | #4 (permalink) | |
| BHPian | Quote:
How much it will cost??? and wthat about the availability...?? cheers aNu
__________________ "Your future depends on your dreams"... | |
| | #5 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ Learning is a continuos job that keeps me busy. | |
| | #6 (permalink) | |
| BHPian | Quote:
and about the 2nd 1... can u tel me 1...??? thanks in advance cheers aNu
| | #7 (permalink) |
| Distinguished - BHPian ![]() | Off Topic. Have u seen the people at some of the service stations.?? They handle the cars so badly. They will never wait for that heating coil icon to go. When they start it before the icon vanishes...the car coughs. Sad!!
__________________ Patience is the Key |
| | #9 (permalink) |
| "MAK Super Kool "form BP ready to use is what i use..alternately there's two from HP 1.HP KOOLGARD, a concentrate is recommended at 30% - 50% concentrations with water. 2.HP THANDA RAJA is a ready to use coolant, which can be used as it is
| | #11 (permalink) |
| Team-BHP Support ![]() | It is a common problem but easily recitifiable. The problem here is not the engine overheating but the thermostat reporting wrong. Since your car is 18months old, they will change the thermostat only after the car goes out of warranty. Take it to the workshop and tell them to check the thermostat.
__________________ Reclaiming.....! |
| | #12 (permalink) |
| BHPian | may be that reason...service station pple told me that they will change something related to fan, sorry i don exactly remember what was that .. , after 40,000 kms!!!, then it will be out of the warrenty period !!!...and nw its only 20,000 kms .... so they may be reffering to thermostat... cheers aNU
| | #13 (permalink) |
| BHPian Join Date: Feb 2005 Location: Varkala
| Hello, I have an Indica V2 DLS with only 4300 Kms on clock. It is also showing the same problem for the past 2 weeks. I made a visit to the local service stn -Benz Automobiles- yesterday and they told me the following: a. The starter motor is the trouble maker b. This is a common problem for all Indicas. c. The motor is made by TVS. d. They (Benz guys) will send this motor to TVS, and TVS will replace it. This will take a couple of days. I am planning to send my car to the 'hospital' this weekend. I DON'T think this is a problem with the Fan or cooling system. Of course, the same problem can occur due to overheating, but in my case, and apparently in your case, overheating is not the issue. The temp gauge is showing a correct reading -as you have observed- which is well below the redline. I will keep you guys posted. thanks Sandeep Last edited by sandeepmdas : 17th February 2005 at 14:50. |
| | #14 (permalink) | |
Sandeep please do post in detail once the repair is done and if the problem is solved.
| | #15 (permalink) |
| BHPian | Psycho, there is a misunderstanding .... engine is not shutting off automatically in my case, but when i switch it off and then restart, then the problem occur....but as u mentiond, it is shutting off when i apply brakes, but only sometimes, and this was not there earlier.... and i changed the starter motor 3 months back and it is not showing any problem when i strat in the morning.... cheers aNu
« Does ABS require disk brakes on all the four wheels?
Why indicator/wiper on different sides in some cars? »
| Thread Tools | |
Similar Threads | ||||
| Indica starting problem | fariborzpz | Technical Stuff | 13 | 29th September 2008 19:25 |
| Cold starting with the new Indica NA | sidharths84 | Technical Stuff | 6 | 3rd September 2007 17:38 |
| palio D starting problem | garychopper | Technical Stuff | 7 | 19th August 2007 20:39 |
| Palio starting problem | amit | Technical Stuff | 29 | 28th February 2007 10:42 |
| Starting Problem. | zulfikar | Technical Stuff | 6 | 6th May 2005 10:04 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
