Old 21st May 2008, 16:42   #16
Shashank.A's Avatar
Ok burning smell definitely means clutch.
Something else could be a simple fuel delivery issue
Thanks for confirming my doubt...what do you think would be the expense to get a new set ? and what all needs to be changed ?
Shashank.A is offline   Reply With Quote
Old 21st May 2008, 17:30   #17
esteem_lover's Avatar
Thanked: 451 Times
Dont think it is a fuel delivery issue when you can revv upto 5k rpm without any problems.
Old 21st May 2008, 17:35   #18
Shashank.A's Avatar
I will get the clutch done. Any suggestions ? how much shud it cost ? any precautions ?
Old 21st May 2008, 17:47   #19
simply_sunny001's Avatar
Thanked: 15 Times
Esteem clutch plate/pressure plate should cost you somewhere near 1500 Rs and add some labour and i think in all 2000 should be the cost.
simply_sunny001 is offline   Reply With Quote
Old 21st May 2008, 17:56   #20
Thanked: 451 Times
Entire clutch replacement costs around 5-6k, replacing only the essentials might work out a little less.
Regarding FE, driving at 80kmph at 5th gear will fetch you 15-18 kmpl on the highway, anything over will make it 12 or lesser.
Old 21st May 2008, 18:00   #21
But the main question is, has any Esteem climbed the Jakhu hill?
Shimla in my 97 Carb Esteem, it did very well, on hills and plains both.
However when I wanted to visit Jakhu Temple, then it refused to climb even on the first gear. Infact all those Altos and Indicas were merrily chugging along.
diabloo is offline   Reply With Quote
Old 21st May 2008, 18:15   #22
Shashank.A's Avatar
I wrote Indicas and Altos were Chugging along and Esteem even at this age is lot more powerful that these two cars...
Old 21st May 2008, 18:36   #23
itwasntme's Avatar
Thanked: 1,735 Times
Could fried brakes temporarily 'sticking' to the shoes/discs add to the problem?
itwasntme is online now   Reply With Quote
Old 21st May 2008, 18:41   #24
Shashank.A's Avatar
What do you mean by fried brakes ? If it means heated up or something, then no, I had just started driving the car, and had driven hardly for 20 minutes..
Old 21st May 2008, 18:46   #25
aaggoswami's Avatar
Thanked: 1,542 Times
If you had burning smell, its clutch. Replace it and see the what happens.
More over also check/clean/overhaul and service the carb.
aaggoswami is offline   Reply With Quote
Old 21st May 2008, 18:54   #26
Shashank.A's Avatar
was done recently...approx 2.5 k km back..
Old 21st May 2008, 18:58   #27
Thanked: 60 Times
i think the problem is as others mentioned, it could be a worn out clutch.
kaush666 is offline   Reply With Quote
Old 21st May 2008, 19:02   #28
rks
rks's Avatar
Most probably clutch. I am also thinking whether the burning smell could be from tyres failing to grip the road, which is possible on a dirt track or if tyres are worn out. Some tricks one can try is to move diagonally instead of straight up and try to maintain some speed on the sharp inclines (not always feasible).
Old 21st May 2008, 19:37   #29
bblost's Avatar
Thanked: 6,980 Times
Was your car running with low tire preasure and more than 5 heavy adults
In that case your car would suffer during climbing.
Old 21st May 2008, 20:04   #30
Thanked: 253 Times
Shashank, your Esteem might not be suffering from a damaged clutch plate.
Before you do that, you could have the timing altered (possibly advanced).
The problem is: How would you test whether this has 'solved' the problem?
You'd have to go to Shimla again (Oh what a wonderful idea!).
If your car is working fine here, my advice would be to do nothing yet.
In the hills it is best to ask a local mechanic to check your vehicle. They know best what tuning settings work best in the hills. I assure you the timing advance is set quite differently by them, compared with what a Delhi mechanic considers 'normal'.
Possible to climb over HUGE sand dunes ? '72 Bullet 4x4 Technical 13 24th June 2010 16:40
Bangalore Hill Climb Dates speedfreak7116 Indian Motorsport 73 15th April 2009 09:35
One drive you'll love - Coimbatore - Asanur Hill Climb Harrie The Team-BHP Meet Section 18 31st March 2008 21:32
Mysore Hill Climb - PICS ADDED: Pg 2 onwards! shailu Indian Motorsport 89 11th March 2008 12:13
